I'm running Os X 10.6.8 with 2 x 2.26 Quad core Intel Xeon - 6GB DDR3 Ram and have repeatedly tried to update to the latest version of Flash Player Version 11.9.900.170
After downloading and opening up the dmg file, I run the installer, I agree to the License terms, click install, enter my password and hit OK.
Password window closes, nothing happens. No progress bar, nothing but the installer window with the terms checkbox and install or quit button.
If I click install again, same thing continues to happen.
I have shut down and restarted, downloaded again, etc and always the same result.
I tried running the uninstaller so I could perform a clean install, but the result is the same with the uninstaller.
Help please!
Download the offline installer: Flash Player (Mac OS X)
Mount the DMG and right click the installer. Choose "Show Package Contents"
In Contents/Resources double click the Adobe Flash Player.pkg
Let it run.
I've tried doing this, and while it ways it installed, it actually hasn't. So I went back in, uninstalled it to try it again, and now it's saying I cannot install it on my computer at all.
What's the specific error you're seeing?
I followed the instructions above.
It went through the installation process and it said that it successfully installed, but even after a restart, flash is not playing and the flash status check page is saying flash is not installed on this system.
If yiu're using Safari, check the Preferences under Security to be sure "Allow Plugins" or "Allow all other plugins" is checked. If it is, Follow the illustrated instructions here: http://forums.adobe.com/thread/1343084 to do a complete clean install.
I followed the instructions, deleted all of the files, emptied the trash and ran the DMG.
I still had to view package contents in order to run the installer.
Said it was successful, but Flash is still not installed on Firefox or Safari.
Now when I do a spotlight search for Flash Player.plugin, the only result is "Flash player.plugin.izma"
Create a new (admin) user account and try the install.
If it works under another account, your account permissions are "pooched" and you'll need to repair them using Disk Utility.
Please do not install Flash Player from the file 'Adobe Flash Player.pkg' located in 'Install Adobe Flash Player.app/Contents/Resources'. Not only does this not install Flash Player correctly, it is not supported.
Thank you.
Maria
Hi Maria,
Can you offer any suggestions, how I can fix this problem?
I'm still unable to install Adobe Flash Player.
Hello,
It could be a permissions issue as Mike mentions.
Please follow the instructions to perform a clean install as posted here. When finished, if the install is still unsucessful, please post the contents of the /Library/Logs/FlashPlayerInstallManager.log file for the last several install attempts.
Maria
Here is the install log after unsucessfully installing flash player:
2010-06-23 13:55:41 -0400 ---------- log start ----------
2010-06-23 13:55:41 -0400 All install checks pass
2010-06-23 13:55:51 -0400 User has 1 process that needs to be closed before the Flash Player can be installed.
2010-06-23 13:56:08 -0400 [install started]
installer: Package name is PlugIn
installer: Upgrading at base path /
installer: The upgrade was successful.
2010-06-23 13:56:19 -0400 [install completed]
2010-06-23 13:56:19 -0400 [install succeeded]
2010-06-23 13:56:21 -0400 ---------- log end ----------
2010-09-08 13:27:42 -0400 ---------- log start ----------
2010-09-08 13:27:42 -0400 All install checks pass
2010-09-08 13:28:21 -0400 User has 1 process that needs to be closed before the Flash Player can be installed.
2010-09-08 13:28:37 -0400 [install started]
2010-09-08 13:28:52 -0400 [install completed]
2010-09-08 13:28:52 -0400 [install succeeded]
2010-09-08 13:28:55 -0400 ---------- log end ----------
2010-10-21 11:39:17 -0400 ---------- log start ----------
2010-10-21 11:39:17 -0400 All install checks pass
2010-10-21 11:39:26 -0400 User has 1 process that needs to be closed before the Flash Player can be installed.
2010-10-21 11:39:53 -0400 [install started]
2010-10-21 11:40:03 -0400 [install completed]
2010-10-21 11:40:03 -0400 [install succeeded]
2010-10-21 11:40:05 -0400 ---------- log end ----------
2011-03-07 09:29:04 -0500 ---------- log start ----------
2011-03-07 09:29:04 -0500 All install checks pass
2011-03-07 09:29:13 -0500 User does not have any processes that need to be closed before the Flash Player can be installed.
2011-03-07 09:29:14 -0500 [install started]
2011-03-07 09:29:26 -0500 [install completed]
2011-03-07 09:29:26 -0500 [install succeeded]
2011-03-07 09:29:28 -0500 ---------- log end ----------
2011-03-14 11:39:56 -0400 ---------- log start ----------
2011-03-14 11:39:56 -0400 All install checks pass
2011-03-14 11:40:08 -0400 User does not have any processes that need to be closed before the Flash Player can be installed.
2011-03-14 11:40:08 -0400 [install started]
2011-03-14 11:40:33 -0400 [install completed]
2011-03-14 11:40:33 -0400 [install succeeded]
2011-03-14 11:40:36 -0400 ---------- log end ----------
2011-04-28 18:02:25 -0400 ---------- log start ----------
2011-04-28 18:02:25 -0400 All install checks pass
2011-04-28 18:02:34 -0400 User does not have any processes that need to be closed before the Flash Player can be installed.
2011-04-28 18:02:34 -0400 [install started]
2011-04-28 18:02:48 -0400 [install completed]
2011-04-28 18:02:48 -0400 [install succeeded]
2011-04-28 18:02:51 -0400 ---------- log end ----------
2011-11-23 10:27:39 -0500 ---------- log start ----------
2011-11-23 10:27:39 -0500 All install checks pass
2011-11-23 10:28:09 -0500 User has 1 process that needs to be closed before the Flash Player can be installed.
2011-11-23 10:28:52 -0500 [install started]
2011-11-23 10:29:20 -0500 [install completed]
2011-11-23 10:29:20 -0500 [install succeeded]
2011-11-23 10:29:25 -0500 ---------- log end ----------
2012-02-24 09:26:32 -0500 ---------- log start ----------
2012-02-24 09:26:34 -0500 1568
2012-02-24 09:26:45 -0500 14782799
2012-02-24 09:26:46 -0500 verifySignatureWithData : Message Verified!
2012-02-24 09:27:11 -0500 ERROR: DMG unmount failed.
2012-02-24 09:27:12 -0500 ---------- log end ----------
2012-02-24 09:27:15 -0500 ---------- log start ----------
2012-02-24 09:27:15 -0500 All install checks pass
2012-02-24 09:27:38 -0500 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-02-24 09:27:38 -0500 [install started]
2012-02-24 09:28:06 -0500 [install completed]
2012-02-24 09:28:06 -0500 [install succeeded]
2012-02-24 09:35:03 -0500 ---------- log end ----------
2012-04-02 08:59:34 -0400 ---------- log start ----------
2012-04-02 08:59:38 -0400 1583
2012-04-02 08:59:47 -0400 11211713
2012-04-02 08:59:48 -0400 verifySignatureWithData : Message Verified!
2012-04-02 09:00:02 -0400 ---------- log end ----------
2012-04-02 09:00:06 -0400 ---------- log start ----------
2012-04-02 09:00:06 -0400 All install checks pass
2012-04-02 09:00:19 -0400 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-04-02 09:00:20 -0400 [install started]
2012-04-02 09:00:41 -0400 [install completed]
2012-04-02 09:00:41 -0400 [install succeeded]
2012-04-02 09:00:44 -0400 ---------- log end ----------
2012-04-16 13:41:20 -0400 ---------- log start ----------
2012-04-16 13:41:21 -0400 1583
2012-04-16 13:41:24 -0400 ---------- log end ----------
2012-04-23 17:25:14 -0400 ---------- log start ----------
2012-04-23 17:25:16 -0400 1583
2012-04-23 17:25:22 -0400 11211575
2012-04-23 17:25:24 -0400 verifySignatureWithData : Message Verified!
2012-04-23 17:25:38 -0400 ---------- log end ----------
2012-04-23 17:25:50 -0400 ---------- log start ----------
2012-04-23 17:25:50 -0400 All install checks pass
2012-04-23 17:26:05 -0400 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-04-23 17:26:39 -0400 [install started]
2012-04-23 17:26:59 -0400 [install completed]
2012-04-23 17:26:59 -0400 [install succeeded]
2012-04-23 17:27:06 -0400 ---------- log end ----------
2012-05-08 09:00:05 -0400 ---------- log start ----------
2012-05-08 09:00:08 -0400 1583
2012-05-08 09:00:15 -0400 11210280
2012-05-08 09:00:15 -0400 verifySignatureWithData : Message Verified!
2012-05-08 09:00:31 -0400 ---------- log end ----------
2012-05-08 09:00:34 -0400 ---------- log start ----------
2012-05-08 09:00:34 -0400 All install checks pass
2012-05-08 09:01:01 -0400 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-05-08 09:01:02 -0400 [install started]
2012-05-08 09:01:52 -0400 [install completed]
2012-05-08 09:01:52 -0400 [install succeeded]
2012-05-08 09:02:12 -0400 ---------- log end ----------
2012-06-13 09:36:45 -0400 ---------- log start ----------
2012-06-13 09:36:47 -0400 1106
2012-06-13 09:37:24 -0400 11580012
2012-06-13 09:37:25 -0400 verifySignatureWithData : Message Verified!
2012-06-13 09:37:39 -0400 ---------- log end ----------
2012-06-13 09:37:48 -0400 ---------- log start ----------
2012-06-13 09:37:48 -0400 All install checks pass
2012-06-13 09:38:05 -0400 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-06-13 09:38:06 -0400 [install started]
sudo: no tty present and no askpass program specified
2012-06-13 09:38:49 -0400 [install completed]
2012-06-13 09:38:49 -0400 [install succeeded]
2012-06-13 09:39:04 -0400 ---------- log end ----------
2012-06-13 09:39:03 -0400 Changing update mode to 1
2012-07-16 15:28:37 -0400 ---------- log start ----------
2012-07-16 15:28:39 -0400 664
2012-07-16 15:28:49 -0400 11582449
2012-07-16 15:28:49 -0400 verifySignatureWithData : Message Verified!
2012-07-16 15:28:59 -0400 ---------- log end ----------
2012-07-16 15:29:10 -0400 ---------- log start ----------
2012-07-16 15:29:10 -0400 All install checks pass
2012-07-16 15:29:42 -0400 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-07-16 15:30:41 -0400 [install started]
2012-07-16 15:31:40 -0400 [install completed]
2012-07-16 15:31:40 -0400 [install succeeded]
2012-07-16 15:32:15 -0400 ---------- log end ----------
2012-07-16 15:32:15 -0400 Changing update mode to 0
2012-08-14 15:01:28 -0400 ---------- log start ----------
2012-08-14 15:01:30 -0400 664
2012-08-14 15:09:19 -0400 11583286
2012-08-14 15:09:19 -0400 verifySignatureWithData : Message Verified!
2012-08-14 15:09:39 -0400 ---------- log end ----------
2012-08-14 15:09:45 -0400 ---------- log start ----------
2012-08-14 15:09:45 -0400 All install checks pass
2012-08-14 15:10:01 -0400 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-08-14 15:10:18 -0400 [install started]
2012-08-14 15:10:44 -0400 [install completed]
2012-08-14 15:10:44 -0400 [install succeeded]
2012-08-14 15:12:03 -0400 ---------- log end ----------
2012-08-14 15:12:02 -0400 Changing update mode to 0
2012-08-21 15:10:05 -0400 ---------- log start ----------
2012-08-21 15:10:06 -0400 602
2012-08-21 15:10:12 -0400 ---------- log end ----------
2012-08-29 09:10:52 -0400 ---------- log start ----------
2012-08-29 09:10:53 -0400 602
2012-08-29 09:25:33 -0400 11861772
2012-08-29 09:25:33 -0400 verifySignatureWithData : Message Verified!
2012-08-29 09:25:47 -0400 ---------- log end ----------
2012-08-29 09:25:50 -0400 ---------- log start ----------
2012-08-29 09:25:50 -0400 All install checks pass
2012-08-29 09:26:05 -0400 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-08-29 09:26:18 -0400 [install started]
2012-08-29 09:26:35 -0400 [install completed]
2012-08-29 09:26:35 -0400 [install succeeded]
2012-08-29 09:47:03 -0400 ---------- log end ----------
2012-08-29 09:47:03 -0400 Changing update mode to 0
2012-11-12 12:02:26 -0500 ---------- log start ----------
2012-11-12 12:02:28 -0500 580
2012-11-12 12:02:40 -0500 16875066
2012-11-12 12:02:41 -0500 verifySignatureWithData : Message Verified!
2012-11-12 12:03:42 -0500 ---------- log end ----------
2012-11-12 12:11:10 -0500 ---------- log start ----------
2012-11-12 12:11:11 -0500 All install checks pass
2012-11-12 12:16:01 -0500 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-11-12 12:16:20 -0500 [install started]
2012-11-12 12:17:22 -0500 [install completed]
2012-11-12 12:17:22 -0500 [install succeeded]
2012-11-12 12:17:26 -0500 ---------- log end ----------
2012-11-12 12:17:26 -0500 Changing update mode to 0
2012-12-11 13:29:26 -0500 ---------- log start ----------
2012-12-11 13:29:27 -0500 580
2012-12-11 13:29:28 -0500 580
2012-12-11 16:22:17 -0500 16881565
2012-12-11 16:22:17 -0500 verifySignatureWithData : Message Verified!
2012-12-11 16:23:03 -0500 ERROR: DMG unmount failed.
2012-12-11 16:23:04 -0500 ---------- log end ----------
2012-12-11 16:23:13 -0500 ---------- log start ----------
2012-12-11 16:23:14 -0500 All install checks pass
2012-12-11 16:23:35 -0500 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-12-11 16:23:35 -0500 [install started]
2012-12-11 16:24:23 -0500 [install completed]
2012-12-11 16:24:23 -0500 [install succeeded]
2012-12-11 16:24:31 -0500 ---------- log end ----------
2012-12-11 16:24:31 -0500 Changing update mode to 0
2013-02-08 09:08:17 -0500 ---------- log start ----------
2013-02-08 09:08:17 -0500 580
2013-02-08 09:08:19 -0500 580
2013-02-08 09:08:35 -0500 16881352
2013-02-08 09:08:36 -0500 verifySignatureWithData : Message Verified!
2013-02-08 09:08:51 -0500 ---------- log end ----------
2013-02-08 09:08:55 -0500 ---------- log start ----------
2013-02-08 09:08:55 -0500 All install checks pass
2013-02-08 09:09:10 -0500 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-02-08 09:09:10 -0500 [install started]
2013-02-08 09:09:34 -0500 [install completed]
2013-02-08 09:09:34 -0500 [install succeeded]
2013-02-08 09:09:43 -0500 ---------- log end ----------
2013-02-08 09:09:43 -0500 Changing update mode to 0
2013-02-15 09:32:47 -0500 ---------- log start ----------
2013-02-15 09:32:47 -0500 1214
2013-02-15 09:32:56 -0500 16931999
2013-02-15 09:32:57 -0500 verifySignatureWithData : Message Verified!
2013-02-15 09:33:07 -0500 ---------- log end ----------
2013-02-15 09:33:12 -0500 ---------- log start ----------
2013-02-15 09:33:12 -0500 All install checks pass
2013-02-15 09:33:28 -0500 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-02-15 09:33:28 -0500 [install started]
2013-02-15 09:33:44 -0500 [install completed]
2013-02-15 09:33:44 -0500 [install succeeded]
2013-02-15 09:33:47 -0500 ---------- log end ----------
2013-02-15 09:33:47 -0500 Changing update mode to 0
2013-03-01 12:43:27 -0500 ---------- log start ----------
2013-03-01 12:43:32 -0500 1214
2013-03-01 12:43:33 -0500 1214
2013-03-01 12:43:45 -0500 16931542
2013-03-01 12:43:46 -0500 verifySignatureWithData : Message Verified!
2013-03-01 12:44:00 -0500 ---------- log end ----------
2013-03-01 12:44:03 -0500 ---------- log start ----------
2013-03-01 12:44:03 -0500 All install checks pass
2013-03-01 12:44:19 -0500 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-03-01 12:44:28 -0500 [install started]
2013-03-01 12:45:01 -0500 [install completed]
2013-03-01 12:45:01 -0500 [install succeeded]
2013-03-01 12:46:10 -0500 ---------- log end ----------
2013-03-01 12:46:10 -0500 Changing update mode to 0
2013-03-18 08:12:00 -0400 ---------- log start ----------
2013-03-18 08:12:01 -0400 1214
2013-03-18 08:12:02 -0400 1214
2013-03-18 08:12:14 -0400 16931938
2013-03-18 08:12:14 -0400 verifySignatureWithData : Message Verified!
2013-03-18 08:12:25 -0400 ---------- log end ----------
2013-03-18 08:12:29 -0400 ---------- log start ----------
2013-03-18 08:12:29 -0400 All install checks pass
2013-03-18 08:12:47 -0400 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-03-18 08:12:47 -0400 [install started]
2013-03-18 08:13:24 -0400 [install completed]
2013-03-18 08:13:24 -0400 [install succeeded]
2013-03-18 08:13:53 -0400 ---------- log end ----------
2013-03-18 08:13:53 -0400 Changing update mode to 0
2013-04-15 13:54:33 -0400 ---------- log start ----------
2013-04-15 13:54:33 -0400 1214
2013-04-15 13:54:34 -0400 1214
2013-04-15 13:54:40 -0400 ---------- log end ----------
2013-04-22 19:30:09 -0400 ---------- log start ----------
2013-04-22 19:30:10 -0400 1214
2013-04-22 19:30:14 -0400 ---------- log end ----------
2013-04-29 20:56:45 -0400 ---------- log start ----------
2013-04-29 20:56:46 -0400 1214
2013-04-29 20:56:47 -0400 1214
2013-04-29 20:56:54 -0400 ---------- log end ----------
2013-04-29 21:06:16 -0400 ---------- log start ----------
2013-04-29 21:06:16 -0400 All install checks pass
2013-04-29 21:06:32 -0400 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-04-29 21:06:39 -0400 [install started]
2013-04-29 21:06:57 -0400 [install completed]
2013-04-29 21:06:57 -0400 [install succeeded]
2013-04-29 21:10:13 -0400 ---------- log end ----------
2013-04-29 21:10:13 -0400 Changing update mode to 0
2013-05-21 12:58:23 -0400 ---------- log start ----------
2013-05-21 12:58:25 -0400 1214
2013-05-21 12:58:26 -0400 1214
2013-05-21 12:59:45 -0400 18007571
2013-05-21 12:59:47 -0400 verifySignatureWithData : Message Verified!
2013-05-21 13:00:09 -0400 ---------- log end ----------
2013-05-21 13:00:13 -0400 ---------- log start ----------
2013-05-21 13:00:13 -0400 All install checks pass
2013-05-21 13:00:35 -0400 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-05-21 13:00:51 -0400 [install started]
2013-05-21 13:01:22 -0400 [install completed]
2013-05-21 13:01:22 -0400 [install succeeded]
2013-05-21 13:01:32 -0400 ---------- log end ----------
2013-05-21 13:01:32 -0400 Changing update mode to 0
2013-05-28 15:38:16 -0400 ---------- log start ----------
2013-05-28 15:38:16 -0400 1214
2013-05-28 15:38:18 -0400 1214
2013-05-28 17:41:58 -0400 18007986
2013-05-28 17:41:59 -0400 verifySignatureWithData : Message Verified!
2013-05-28 17:42:12 -0400 ---------- log end ----------
2013-05-28 17:42:35 -0400 ---------- log start ----------
2013-05-28 17:42:35 -0400 All install checks pass
2013-05-28 17:42:51 -0400 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-05-28 17:42:52 -0400 [install started]
2013-05-28 17:43:54 -0400 [install completed]
2013-05-28 17:43:54 -0400 [install succeeded]
2013-05-28 17:44:59 -0400 ---------- log end ----------
2013-05-28 17:44:59 -0400 Changing update mode to 0
2013-06-12 08:30:01 -0400 ---------- log start ----------
2013-06-12 08:30:05 -0400 1214
2013-06-12 08:30:06 -0400 1214
2013-06-12 13:31:52 -0400 ---------- log end ----------
2013-06-19 08:53:39 -0400 ---------- log start ----------
2013-06-19 08:53:39 -0400 1214
2013-06-19 08:53:52 -0400 18012237
2013-06-19 08:53:52 -0400 verifySignatureWithData : Message Verified!
2013-06-19 08:54:03 -0400 ---------- log end ----------
2013-06-19 08:54:08 -0400 ---------- log start ----------
2013-06-19 08:54:08 -0400 All install checks pass
2013-06-19 09:00:16 -0400 ---------- log end ----------
2013-06-26 14:25:20 -0400 ---------- log start ----------
2013-06-26 14:25:21 -0400 1214
2013-06-26 14:25:24 -0400 1214
2013-06-26 17:30:15 -0400 18012237
2013-06-26 17:30:18 -0400 verifySignatureWithData : Message Verified!
2013-06-26 17:30:32 -0400 ---------- log end ----------
2013-06-26 17:30:39 -0400 ---------- log start ----------
2013-06-26 17:30:39 -0400 All install checks pass
2013-06-26 17:31:33 -0400 ---------- log end ----------
2013-07-08 08:38:36 -0400 ---------- log start ----------
2013-07-08 08:38:36 -0400 1214
2013-07-08 09:28:18 -0400 ---------- log end ----------
2013-07-15 09:51:27 -0400 ---------- log start ----------
2013-07-15 09:51:27 -0400 1213
2013-07-15 09:51:29 -0400 1213
2013-07-15 10:45:02 -0400 ---------- log end ----------
2013-07-15 10:45:49 -0400 ---------- log start ----------
2013-07-15 10:45:49 -0400 All install checks pass
2013-07-15 10:47:03 -0400 ---------- log end ----------
2013-07-22 10:51:38 -0400 ---------- log start ----------
2013-07-22 10:51:39 -0400 1213
2013-07-22 10:51:44 -0400 ---------- log end ----------
2013-07-29 14:47:41 -0400 ---------- log start ----------
2013-07-29 14:47:42 -0400 1213
2013-07-29 14:47:43 -0400 1213
2013-07-29 14:47:48 -0400 ---------- log end ----------
2013-08-05 15:28:15 -0400 ---------- log start ----------
2013-08-05 15:28:16 -0400 1213
2013-08-05 15:28:32 -0400 ---------- log end ----------
2013-08-05 15:29:20 -0400 ---------- log start ----------
2013-08-05 15:29:21 -0400 All install checks pass
2013-08-05 15:29:59 -0400 ---------- log end ----------
2013-08-05 15:30:07 -0400 ---------- log start ----------
2013-08-05 15:30:07 -0400 All install checks pass
2013-08-05 15:31:14 -0400 ---------- log end ----------
2013-08-05 15:31:24 -0400 ---------- log start ----------
2013-08-05 15:31:24 -0400 All install checks pass
2013-08-05 15:32:04 -0400 ---------- log end ----------
2013-08-05 16:17:06 -0400 ---------- log start ----------
2013-08-05 16:17:06 -0400 All install checks pass
2013-08-05 16:18:07 -0400 ---------- log end ----------
2013-08-12 16:17:01 -0400 ---------- log start ----------
2013-08-12 16:17:01 -0400 1213
2013-08-12 16:17:02 -0400 1213
2013-08-12 16:17:12 -0400 ---------- log end ----------
2013-08-19 17:01:05 -0400 ---------- log start ----------
2013-08-19 17:01:05 -0400 1213
2013-08-19 17:01:06 -0400 1213
2013-08-19 17:05:18 -0400 ---------- log end ----------
2013-09-02 11:15:20 -0400 ---------- log start ----------
2013-09-02 11:15:20 -0400 1213
2013-09-02 11:15:21 -0400 1213
2013-09-02 18:22:41 -0400 18126965
2013-09-02 18:22:43 -0400 verifySignatureWithData : Message Verified!
2013-09-02 18:23:00 -0400 ---------- log end ----------
2013-09-02 18:23:05 -0400 ---------- log start ----------
2013-09-02 18:23:05 -0400 All install checks pass
2013-09-02 19:40:31 -0400 ---------- log end ----------
2013-09-09 12:17:39 -0400 ---------- log start ----------
2013-09-09 12:17:41 -0400 1213
2013-09-09 12:17:42 -0400 1213
2013-09-09 12:17:46 -0400 ---------- log end ----------
2013-09-16 12:24:29 -0400 ---------- log start ----------
2013-09-16 12:24:30 -0400 1214
2013-09-16 12:24:31 -0400 1214
2013-09-16 13:08:21 -0400 ---------- log end ----------
2013-09-23 14:59:11 -0400 ---------- log start ----------
2013-09-23 14:59:11 -0400 1214
2013-09-23 14:59:12 -0400 1214
2013-09-23 14:59:14 -0400 ---------- log end ----------
2013-09-30 15:32:03 -0400 ---------- log start ----------
2013-09-30 15:32:03 -0400 1214
2013-09-30 15:32:09 -0400 ---------- log end ----------
2013-10-07 15:32:56 -0400 ---------- log start ----------
2013-10-07 15:32:56 -0400 1214
2013-10-07 15:32:58 -0400 1214
2013-10-07 15:56:36 -0400 ---------- log end ----------
2013-10-15 09:05:48 -0400 ---------- log start ----------
2013-10-15 09:05:48 -0400 1389
2013-10-15 09:05:49 -0400 1389
2013-10-15 09:05:58 -0400 ---------- log end ----------
2013-10-22 10:36:22 -0400 ---------- log start ----------
2013-10-22 10:36:22 -0400 1389
2013-10-22 10:36:25 -0400 ---------- log end ----------
2013-10-29 11:10:24 -0400 ---------- log start ----------
2013-10-29 11:10:24 -0400 1389
2013-10-29 11:10:25 -0400 1389
2013-10-29 11:10:28 -0400 ---------- log end ----------
2013-11-05 15:16:17 -0500 ---------- log start ----------
2013-11-05 15:16:17 -0500 1389
2013-11-05 15:16:18 -0500 1389
2013-11-05 15:18:27 -0500 ---------- log end ----------
2013-11-12 15:59:38 -0500 ---------- log start ----------
2013-11-12 15:59:39 -0500 1389
2013-11-12 15:59:40 -0500 1389
2013-11-12 15:59:44 -0500 ---------- log end ----------
2013-11-26 18:41:14 -0500 ---------- log start ----------
2013-11-26 18:41:15 -0500 1389
2013-11-26 18:41:22 -0500 ---------- log end ----------
2013-12-04 11:37:33 -0500 ---------- log start ----------
2013-12-04 11:37:33 -0500 1389
2013-12-04 11:37:34 -0500 1389
2013-12-04 11:37:39 -0500 ---------- log end ----------
2013-12-11 11:54:18 -0500 ---------- log start ----------
2013-12-11 11:54:18 -0500 1389
2013-12-11 11:54:19 -0500 1389
2013-12-11 11:54:22 -0500 ---------- log end ----------
2013-12-18 12:01:22 -0500 ---------- log start ----------
2013-12-18 12:01:23 -0500 1389
2013-12-18 12:01:33 -0500 ---------- log end ----------
2013-12-27 11:35:42 -0500 ---------- log start ----------
2013-12-27 11:35:43 -0500 1389
2013-12-27 11:35:46 -0500 ---------- log end ----------
2014-01-03 12:14:29 -0500 ---------- log start ----------
2014-01-03 12:14:30 -0500 1389
2014-01-03 12:14:31 -0500 1389
2014-01-03 12:14:53 -0500 18417494
2014-01-03 12:14:55 -0500 verifySignatureWithData : Message Verified!
2014-01-03 12:15:14 -0500 ---------- log end ----------
2014-01-03 12:15:20 -0500 ---------- log start ----------
2014-01-03 12:15:20 -0500 All install checks pass
2014-01-03 12:16:06 -0500 ---------- log end ----------
2014-01-08 21:44:33 -0500 ---------- log start ----------
2014-01-08 21:44:33 -0500 All install checks pass
2014-01-08 21:46:22 -0500 ---------- log end ----------
2014-01-08 21:46:12 -0500 1389
2014-01-08 21:46:15 -0500 ---------- log start ----------
2014-01-08 21:46:16 -0500 1389
2014-01-08 21:46:33 -0500 18417494
2014-01-08 21:46:34 -0500 verifySignatureWithData : Message Verified!
2014-01-08 21:46:46 -0500 ---------- log end ----------
2014-01-08 21:46:49 -0500 ---------- log start ----------
2014-01-08 21:46:50 -0500 All install checks pass
2014-01-08 21:47:03 -0500 ---------- log end ----------
2014-01-08 21:50:22 -0500 ---------- log start ----------
2014-01-08 21:50:22 -0500 All install checks pass
2014-01-08 21:51:00 -0500 ---------- log end ----------
2014-01-08 21:51:44 -0500 ---------- log start ----------
2014-01-08 21:51:45 -0500 1389
2014-01-08 21:51:47 -0500 ---------- log start ----------
2014-01-08 21:51:47 -0500 1389
2014-01-08 21:51:48 -0500 1389
2014-01-08 21:52:09 -0500 18417494
2014-01-08 21:52:14 -0500 verifySignatureWithData : Message Verified!
2014-01-08 21:52:26 -0500 ---------- log end ----------
2014-01-08 21:52:26 -0500 ---------- log start ----------
2014-01-08 21:52:26 -0500 All install checks pass
2014-01-08 21:56:00 -0500 ---------- log end ----------
2014-01-08 22:01:16 -0500 ---------- log start ----------
2014-01-08 22:06:26 -0500 ---------- log end ----------
2014-01-08 22:06:34 -0500 ---------- log start ----------
2014-01-08 22:07:12 -0500 ---------- log end ----------
2014-01-08 22:07:19 -0500 ---------- log start ----------
2014-01-08 22:07:36 -0500 ---------- log end ----------
2014-01-08 22:15:22 -0500 ---------- log start ----------
2014-01-08 22:15:37 -0500 ---------- log end ----------
2014-01-08 22:15:59 -0500 ---------- log start ----------
2014-01-08 22:16:08 -0500 ---------- log end ----------
2014-01-08 22:18:43 -0500 ---------- log start ----------
2014-01-08 22:18:43 -0500 All install checks pass
2014-01-08 22:19:11 -0500 ---------- log end ----------
2014-01-08 22:22:25 -0500 ---------- log start ----------
2014-01-08 22:22:25 -0500 All install checks pass
2014-01-08 22:22:39 -0500 ---------- log end ----------
2014-01-08 22:35:29 -0500 ---------- log start ----------
2014-01-08 22:35:29 -0500 All install checks pass
2014-01-08 22:36:06 -0500 ---------- log end ----------
2014-01-08 22:36:35 -0500 ---------- log start ----------
2014-01-08 22:36:35 -0500 All install checks pass
2014-01-08 22:36:55 -0500 ---------- log end ----------
2014-01-08 22:38:35 -0500 ---------- log start ----------
2014-01-08 22:38:35 -0500 All install checks pass
2014-01-08 22:39:39 -0500 ---------- log end ----------
2014-01-08 22:43:19 -0500 ---------- log start ----------
2014-01-08 22:47:45 -0500 ---------- log start ----------
2014-01-08 22:47:57 -0500 ---------- log end ----------
2014-01-08 22:48:06 -0500 ---------- log start ----------
2014-01-08 22:48:06 -0500 All install checks pass
2014-01-08 22:48:17 -0500 ---------- log end ----------
2014-01-08 23:21:03 -0500 ---------- log start ----------
2014-01-08 23:21:03 -0500 All install checks pass
2014-01-08 23:21:23 -0500 ---------- log end ----------
2014-01-10 16:20:23 -0500 ---------- log start ----------
2014-01-10 16:20:23 -0500 All install checks pass
2014-01-10 16:29:13 -0500 ---------- log end ----------
2014-01-11 00:21:12 -0500 ---------- log start ----------
2014-01-11 00:21:23 -0500 ---------- log end ----------
2014-01-11 00:23:23 -0500 ---------- log start ----------
2014-01-11 00:23:35 -0500 ---------- log end ----------
2014-01-11 00:31:39 -0500 ---------- log start ----------
2014-01-11 00:31:50 -0500 ---------- log end ----------
2014-01-11 00:42:36 -0500 ---------- log start ----------
2014-01-11 00:42:46 -0500 ---------- log end ----------
2014-01-13 15:08:31 -0500 ---------- log start ----------
2014-01-13 15:08:31 -0500 All install checks pass
2014-01-13 15:08:41 -0500 ---------- log end ----------
2014-01-13 17:07:48 -0500 ---------- log start ----------
2014-01-13 17:07:48 -0500 All install checks pass
2014-01-13 17:08:00 -0500 ---------- log end ----------
2014-01-13 17:25:37 -0500 ---------- log start ----------
2014-01-13 17:25:37 -0500 All install checks pass
2014-01-13 17:25:54 -0500 ---------- log end ----------
2014-01-13 17:43:22 -0500 ---------- log start ----------
2014-01-13 17:43:22 -0500 1389
2014-01-13 17:43:25 -0500 ---------- log start ----------
2014-01-13 17:43:25 -0500 1389
2014-01-13 17:43:26 -0500 1389
2014-01-13 17:43:33 -0500 18417494
2014-01-13 17:43:34 -0500 verifySignatureWithData : Message Verified!
2014-01-13 17:43:43 -0500 ---------- log end ----------
2014-01-13 17:43:44 -0500 ---------- log start ----------
2014-01-13 17:43:44 -0500 All install checks pass
2014-01-13 17:44:22 -0500 ---------- log end ----------
2014-01-13 17:44:47 -0500 ---------- log start ----------
2014-01-13 17:44:47 -0500 1389
2014-01-13 17:44:48 -0500 ---------- log start ----------
2014-01-13 17:44:48 -0500 1389
2014-01-13 17:44:49 -0500 1389
2014-01-13 17:44:55 -0500 18417494
2014-01-13 17:44:56 -0500 verifySignatureWithData : Message Verified!
2014-01-13 17:45:04 -0500 ---------- log end ----------
2014-01-13 17:45:04 -0500 ---------- log start ----------
2014-01-13 17:45:04 -0500 All install checks pass
2014-01-13 17:45:18 -0500 ---------- log end ----------
2014-01-13 17:47:09 -0500 ---------- log start ----------
2014-01-13 17:47:09 -0500 1389
2014-01-13 17:47:10 -0500 ---------- log start ----------
2014-01-13 17:47:10 -0500 1389
2014-01-13 17:47:11 -0500 1389
2014-01-13 17:47:20 -0500 18417494
2014-01-13 17:47:21 -0500 verifySignatureWithData : Message Verified!
2014-01-13 17:47:30 -0500 ---------- log end ----------
2014-01-13 17:47:30 -0500 ---------- log start ----------
2014-01-13 17:47:30 -0500 All install checks pass
2014-01-13 17:47:40 -0500 ---------- log end ----------
2014-01-13 17:48:04 -0500 ---------- log start ----------
2014-01-13 17:48:16 -0500 ---------- log end ----------
2014-01-13 17:48:32 -0500 ---------- log start ----------
2014-01-13 17:49:15 -0500 ---------- log end ----------
2014-01-13 18:18:23 -0500 ---------- log start ----------
2014-01-13 18:18:23 -0500 All install checks pass
2014-01-13 18:18:32 -0500 ---------- log end ----------
2014-01-13 18:19:23 -0500 ---------- log start ----------
2014-01-13 18:19:23 -0500 All install checks pass
2014-01-13 18:19:33 -0500 ---------- log end ----------
2014-01-13 18:26:35 -0500 ---------- log start ----------
2014-01-13 18:26:35 -0500 1389
2014-01-13 18:26:38 -0500 ---------- log start ----------
2014-01-13 18:26:38 -0500 1389
2014-01-13 18:26:44 -0500 18417494
2014-01-13 18:26:44 -0500 verifySignatureWithData : Message Verified!
2014-01-13 18:26:53 -0500 ---------- log end ----------
2014-01-13 18:26:53 -0500 ---------- log start ----------
2014-01-13 18:26:53 -0500 All install checks pass
2014-01-13 19:08:00 -0500 ---------- log end ----------
2014-01-13 20:01:16 -0500 ---------- log start ----------
2014-01-13 20:01:16 -0500 1389
2014-01-13 20:01:17 -0500 ---------- log start ----------
2014-01-13 20:01:18 -0500 1389
2014-01-13 20:01:24 -0500 18417494
2014-01-13 20:01:25 -0500 verifySignatureWithData : Message Verified!
2014-01-13 20:01:33 -0500 ---------- log end ----------
2014-01-13 20:01:33 -0500 ---------- log start ----------
2014-01-13 20:01:33 -0500 All install checks pass
2014-01-13 20:01:44 -0500 ---------- log end ----------
2014-01-13 22:22:15 -0500 ---------- log start ----------
2014-01-13 22:22:28 -0500 ---------- log end ----------
2014-01-13 22:22:46 -0500 ---------- log start ----------
2014-01-13 22:22:46 -0500 All install checks pass
2014-01-13 22:22:49 -0500 ---------- log end ----------
2014-01-13 22:22:57 -0500 ---------- log start ----------
2014-01-13 22:22:57 -0500 All install checks pass
2014-01-13 22:23:06 -0500 ---------- log end ----------
2014-01-13 22:23:55 -0500 ---------- log start ----------
2014-01-13 22:23:55 -0500 1389
2014-01-13 22:23:57 -0500 ---------- log start ----------
2014-01-13 22:23:57 -0500 1389
2014-01-13 22:24:08 -0500 18417494
2014-01-13 22:24:09 -0500 verifySignatureWithData : Message Verified!
2014-01-13 22:24:18 -0500 ---------- log end ----------
2014-01-13 22:24:18 -0500 ---------- log start ----------
2014-01-13 22:24:18 -0500 All install checks pass
2014-01-13 22:26:11 -0500 ---------- log end ----------
2014-01-14 08:29:52 -0500 ---------- log start ----------
2014-01-14 08:29:52 -0500 1389
2014-01-14 08:29:53 -0500 ---------- log start ----------
2014-01-14 08:29:54 -0500 1389
2014-01-14 08:30:08 -0500 18417494
2014-01-14 08:30:11 -0500 verifySignatureWithData : Message Verified!
2014-01-14 08:30:20 -0500 ---------- log end ----------
2014-01-14 08:30:20 -0500 ---------- log start ----------
2014-01-14 08:30:20 -0500 All install checks pass
2014-01-14 08:30:53 -0500 ---------- log end ----------
2014-01-14 21:56:25 -0500
2014-01-14 22:56:25 -0500
2014-01-14 23:56:25 -0500
2014-01-15 00:56:25 -0500
2014-01-15 01:56:25 -0500
2014-01-15 02:56:25 -0500
2014-01-15 03:56:25 -0500
2014-01-15 04:56:24 -0500
2014-01-15 05:56:24 -0500
2014-01-15 06:56:24 -0500
2014-01-15 07:56:24 -0500
2014-01-15 20:48:44 -0500 IM: ---------- log start ----------
2014-01-15 20:49:02 -0500 IM: ---------- log end ----------
2014-01-15 20:59:01 -0500 IM: ---------- log start ----------
2014-01-15 20:59:15 -0500 IM: ---------- log end ----------
2014-01-15 21:00:55 -0500 IM: ---------- log start ----------
2014-01-15 21:00:55 -0500 IM: All install checks pass
2014-01-15 21:01:06 -0500 IM: ---------- log end ----------
2014-01-15 21:06:50 -0500 IM: ---------- log start ----------
2014-01-15 21:06:50 -0500 IM: All install checks pass
2014-01-15 21:07:05 -0500 IM: ---------- log end ----------
2014-01-15 21:08:33 -0500 IM: ---------- log start ----------
2014-01-15 21:08:33 -0500 IM: 1386
2014-01-15 21:08:34 -0500 IM: ---------- log start ----------
2014-01-15 21:08:34 -0500 IM: 1386
2014-01-15 21:08:38 -0500 IM: ---------- log end ----------
2014-01-15 21:09:19 -0500 IM: ---------- log start ----------
2014-01-15 21:09:20 -0500 IM: All install checks pass
2014-01-15 21:09:31 -0500 IM: ---------- log end ----------
