quote:
Originally posted by: KenY77
The problem is that there will be numerous links between chapters, and I don't believe Robohelp will be able to track these links if they link to pages in other projects.
RH will track the links as long as you have [copies of] those "external" (external to the project you're in) projects on your machine. So, a link to "projects/subprojectA" from subprojectB will get converted to "mergedProjects/subprojectA" and will work fine.
See Peter Grainge's web site for the most efficient method of constructing your merged project. My experience with it has been very positive. I also believe that VSS is the best product to use with RoboHelp.
Good luck,
Leon
