13 Replies Latest reply: Mar 19, 2014 9:47 PM by Tom Frode RSS
    Performance crippled by 7.2 update - GPU Acceleration
    522 edit
      Moved from "RGB Curves crashing Premiere after update"
      Here is a description of my problem
      I am having the same issue with any sort of effect added to a clip.
      it happens with curves, 3 way color, and lumetri looks from speed grade.
      with effects off, playback is fine with GPU accelleration enabled but as soon as i turn any effect on, it will not even play back at 1/4 res.
      If i turn off gpu accelleration i can play back all footage seamlessly at 1/2 resolution, but at full res it chokes.
      before updating to 7.2 i could playback all at full res with GPU accelleration enabled. I reverted back to 7.1 and all went back to normal.
      i am on
      iMac 3.4 Ghz i7
      16gb Ram 1333 Mhz DDR3
      AMD Radeon HD 6970M 2048 MB
      the footage is
      DSLR h.264 footage
      and AVCHD from sony FS700
      What changed with respect to the GPU accelleration?
      Why did it work in 7.1 and not in 7.2?
      Thanks for the help!
