SOLVED
Need field to be read only once saved...
Avatar
Level 4
I have altered the current date field to create a unique ID for a form. What I need it to do is to become READ ONLY once the user clicks the Submit button. Below is my current FormCalc code
$.rawValue = Concat(Num2Date(Date(), "MMDDYY"), "-", Num2Time(Time(), "hMMSS"))
Any ideas? THanks!
1 Accepted Solution
Avatar
Correct answer by
Level 10
put it into an if expression.
if ($.isNull) then
     $ = Concat(Num2Date(Date(), "MMDDYY"), "-", Num2Time(Time(), "hMMSS"))
else
     $.access = "readOnly"
endif
Avatar
Correct answer by
Level 10
if ($.isNull) then
else
endif
Avatar
Level 4
As a followup, how would I make a plain text field become read only once a value is entered and the field is exited?
Avatar
Level 10
It's solution is similar.
Add this script to thr fields exit event.
if (not $.isNull) then
endif
Avatar
Level 4
Is there a way to make it so that when the submit button is clicked it makes all form fields read only? Thanks!
Avatar
Level 10
you can use a recursive loop to find all field objects in your form.
Here's an example.
function lockFields(vNode) {
    if (vNode.className == "field") {
        vNode.access = "readOnly";
    for (var i = 0; i < vNode.nodes.length; i += 1) {
        lockFields(vNode.nodes.item(i));
lockFields(xfa.form);
