Locked
Internal update server and flash player 12
Jan 15, 2014 Jan 15, 2014
We've been using an internal update server and a deployed mms.cfg to point internal client machines to a local webserver hosting Flash Player updates extracted from the background update .cab file, as detailed in the Administration Guide.
This has been working well for Windows & OS X clients.
For Flash Player 12, I've created a "12" folder at the same level as the 11 folder:
https://servername.domain/pub/flashplayer/update/current/sau/12/xml/version.xml
However, clients (that are currently running 11) are looking for:
https://servername.domain/pub/flashplayer/update/current/sau/11/xml/version.xml
So I copied the "12" folder to the "11" folder and manually triggered the scheduled task on a couple of clients and they've grabbed the newer version (except for the plugin-based browser, which haven't updated and are still using 11.9.*).
My flashinstall.log shows the following:
<code>
2014-1-15+16-40-27.23 [info] 1620
2014-1-15+16-41-57.757 [info] 1628 server.domain
2014-1-15+16-41-57.820 [info] 1629 server.domain
2014-1-15+16-41-57.820 [info] 1614
2014-1-15+16-41-57.820 [info] 1615
2014-1-15+16-41-57.820 [info] 1618
2014-1-15+16-41-57.820 [info] 1619 1063
2014-1-15+16-41-57.835 [info] 1628 server.domain
2014-1-15+16-41-57.835 [info] 1629 server.domain
2014-1-15+16-41-57.835 [info] 1614
2014-1-15+16-41-57.835 [info] 1615
2014-1-15+16-41-57.835 [info] 1618
2014-1-15+16-41-57.835 [info] 1608
2014-1-15+16-41-57.835 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/version.xml
2014-1-15+16-41-57.835 [info] 1604
2014-1-15+16-41-57.960 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/patch.xml
2014-1-15+16-41-57.960 [warning] 1445
2014-1-15+16-41-57.960 [warning] 1442
2014-1-15+16-41-57.960 [info] 1601
2014-1-15+16-41-58.507 [error] 1215 32
2014-1-15+16-41-58.507 [warning] 1416 6
2014-1-15+16-41-58.507 [error] 1300 183
2014-1-15+16-41-58.507 [info] 1612
2014-1-15+16-41-58.507 [info] 1620
2014-1-15+16-41-59.367 [error] 1226 1062
=O====== M/12.0.0.38 2014-01-15+16-40-26.961 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 9
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/12.0 2
0002 00000011 1
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_12_0_0_38.ocx
0005 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_38_ActiveX.exe
0006 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_38_ActiveX.dll
0007 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0008 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0009 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0010 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
0011 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0012 00001106
0013 00001106
0014 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
0015 00000012
=X====== M/12.0.0.38 2014-01-15+16-42-00.945 ========
</code>
My questions:
1) Is this the expected method for getting version 11 to upgrade to 12 without much intervention?
2) What's triggering the error codes - the hack-ish way I've forced the update, or something else?
3) What knock-on effects will the Flash Player version renumbering have on the local webserver deployment method?  And is it documented anywhere?
1.9K
Guest
We have just deployed this to our organisation and waiting for the first scheduled update by around 1200 machines some time today.
The latest Adobe instructions available to download here http://www.adobe.com/devnet/flashplayer/articles/flash_player_admin_guide.html still state it should be in folder '11' and not '12', but I guess we'll soon find out if it has worked or not.
Hopefully someone from Adobe can answer your question as it is likely to impact a large number of enterprise users.
Adobe Employee ,
Hello qegs,
The version number to use in the URL path is '11', not '12'.  The Flash Player 12.0 Admin Guide has been updated to indicate this in the pertinent section.
When both ActiveX and Plugin are installed, the Background Updater first updates the ActiveX player and then the Plugin player is updated within the hour, therefore, you won't see both player types updated at the same time.
I am investigating the error you are seeing. Can you please post an expanded install.log file, containing the logging before and after what you have posted already?
Thank you in advance.
Maria
Jan 16, 2014 Jan 16, 2014
Hi Maria,
The rest of the install log is below and it does install the plugin later and the log is clean of errors thereafter.
I created "12" because the previous install guide noted that the folder should be named for the major version and I assumed that guidance still held (though thinking about it you've abandoned that distinction with the recent re-numbering).
<log>
<snip idential entries for brevity>
<At this point the client is looking in the "11" folder at the 11.9.* version>
2014-1-15+15-45-8.728 [info] 1614
2014-1-15+15-45-8.728 [info] 1615
2014-1-15+15-45-8.728 [info] 1618
2014-1-15+15-45-8.728 [info] 1608
2014-1-15+15-45-8.728 [info] 1612
2014-1-15+15-45-8.728 [info] 1620
2014-1-15+15-45-8.728 [info] 1604
<Around this time, the contents of the "12" directory get moved to the "11" directory after it becomes clear from webserver logs that the client is explicitly looking for the 11 directory.>
2014-1-15+16-4-0.155 [info] 1628 server.domain
2014-1-15+16-4-0.499 [info] 1629 server.domain
2014-1-15+16-4-0.561 [info] 1614
2014-1-15+16-4-0.561 [info] 1615
2014-1-15+16-4-0.561 [info] 1618
2014-1-15+16-4-0.561 [info] 1619 1063
2014-1-15+16-4-0.577 [info] 1628 server.domain
2014-1-15+16-4-0.577 [info] 1629 server.domain
2014-1-15+16-4-0.577 [info] 1614
2014-1-15+16-4-0.577 [info] 1615
2014-1-15+16-4-0.577 [info] 1618
2014-1-15+16-4-0.577 [info] 1608
2014-1-15+16-4-0.577 [info] 1604
2014-1-15+16-4-0.640 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/version.xml
2014-1-15+16-4-0.905 [warning] 1411
2014-1-15+16-4-0.905 [warning] 1409
2014-1-15+16-4-0.905 [info] 1612
2014-1-15+16-4-0.905 [info] 1620
2014-1-15+16-15-45.5 [info] 1628 server.domain
2014-1-15+16-15-45.239 [info] 1629 server.domain
2014-1-15+16-15-45.302 [info] 1614
2014-1-15+16-15-45.302 [info] 1615
2014-1-15+16-15-45.302 [info] 1618
2014-1-15+16-15-45.302 [info] 1619 1063
2014-1-15+16-15-45.317 [info] 1628 server.domain
2014-1-15+16-15-45.317 [info] 1629 server.domain
2014-1-15+16-15-45.317 [info] 1614
2014-1-15+16-15-45.317 [info] 1615
2014-1-15+16-15-45.317 [info] 1618
2014-1-15+16-15-45.317 [info] 1608
2014-1-15+16-15-45.317 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/version.xml
2014-1-15+16-15-45.333 [info] 1604
2014-1-15+16-15-45.395 [warning] 1411
2014-1-15+16-15-45.395 [warning] 1409
2014-1-15+16-15-45.395 [info] 1612
2014-1-15+16-15-45.395 [info] 1620
2014-1-15+16-30-31.253 [info] 1628 server.domain
2014-1-15+16-30-31.253 [info] 1629 server.domain
2014-1-15+16-30-31.254 [info] 1614
2014-1-15+16-30-31.254 [info] 1615
2014-1-15+16-30-31.254 [info] 1618
2014-1-15+16-30-31.262 [info] 1608
2014-1-15+16-30-31.269 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/version.xml
2014-1-15+16-30-31.754 [warning] 1411
2014-1-15+16-30-31.754 [warning] 1409
2014-1-15+16-30-31.754 [info] 1612
2014-1-15+16-30-31.754 [info] 1620
2014-1-15+16-32-25.56 [info] 1628 server.domain
2014-1-15+16-32-25.56 [info] 1629 server.domain
2014-1-15+16-32-25.56 [info] 1614
2014-1-15+16-32-25.71 [info] 1615
2014-1-15+16-32-25.71 [info] 1618
2014-1-15+16-32-25.71 [info] 1608
2014-1-15+16-32-25.71 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/version.xml
2014-1-15+16-32-25.228 [warning] 1411
2014-1-15+16-32-25.228 [warning] 1409
2014-1-15+16-32-25.228 [info] 1612
2014-1-15+16-32-25.228 [info] 1620
2014-1-15+16-40-24.867 [info] 1628 server.domain
2014-1-15+16-40-24.867 [info] 1629 server.domain
2014-1-15+16-40-24.867 [info] 1614
2014-1-15+16-40-24.867 [info] 1615
2014-1-15+16-40-24.867 [info] 1618
2014-1-15+16-40-24.867 [info] 1608
2014-1-15+16-40-24.867 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/version.xml
2014-1-15+16-40-25.195 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/patch.xml
2014-1-15+16-40-25.195 [warning] 1445
2014-1-15+16-40-25.195 [warning] 1442
2014-1-15+16-40-25.195 [info] 1600
2014-1-15+16-40-26.930 [info] 1602
2014-1-15+16-40-26.930 [info] 1609
2014-1-15+16-40-26.930 [info] 1612
?=O====== M/12.0.0.38 2014-01-15+16-40-26.961 ========
0002 00000011 1
0012 00001106
0013 00001106
0015 00000012
2014-1-15+17-4-0.153 [info] 1628 server.domain
2014-1-15+17-4-0.232 [info] 1629 server.domain
2014-1-15+17-4-0.232 [info] 1614
2014-1-15+17-4-0.247 [info] 1615
2014-1-15+17-4-0.247 [info] 1618
2014-1-15+17-4-0.247 [info] 1619 1063
2014-1-15+17-4-0.263 [info] 1628 server.domain
2014-1-15+17-4-0.263 [info] 1629 server.domain
2014-1-15+17-4-0.263 [info] 1614
2014-1-15+17-4-0.263 [info] 1615
2014-1-15+17-4-0.263 [info] 1618
2014-1-15+17-4-0.263 [info] 1608
2014-1-15+17-4-0.263 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/version.xml
2014-1-15+17-4-0.263 [info] 1604
2014-1-15+17-4-0.528 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/patch.xml
2014-1-15+17-4-0.528 [warning] 1445
2014-1-15+17-4-0.528 [warning] 1442
2014-1-15+17-4-0.528 [info] 1601
2014-1-15+17-4-2.857 [info] 1602
2014-1-15+17-4-2.857 [info] 1610
2014-1-15+17-4-2.857 [info] 1612
2014-1-15+17-4-2.935 [info] 1620
2014-1-15+17-5-31.732 [error] 1226 1062
?=O====== M/12.0.0.43 2014-01-15+17-04-02.872 ========
0001 00000011 1
0002 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0003 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0004 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0005 00001036 Software\Opera Software/Last CommandLine 2
0006 00001036 Software\Opera Software/Last CommandLine 2
0007 00001036 Software\Opera Software/Plugin Path 2
0008 00001036 Software\Opera Software/Plugin Path 2
0009 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_12_0_0_43.dll
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_43_Plugin.exe
0011 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
0012 00000017 C:\Windows\SysWOW64\Macromed\Flash
0013 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_12_0_0_43.exe
0014 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0015 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0016 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
0017 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0018 00001106
0019 00001106
0020 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
0021 00000012
=X====== M/12.0.0.43 2014-01-15+17-05-34.091 ========
2014-1-15+18-4-0.204 [info] 1628 server.domain
2014-1-15+18-4-0.204 [info] 1629 server.domain
2014-1-15+18-4-0.204 [info] 1614
2014-1-15+18-4-0.204 [info] 1615
2014-1-15+18-4-0.220 [info] 1618
2014-1-15+18-4-0.220 [info] 1619 1063
2014-1-15+18-4-0.220 [info] 1628 server.domain
2014-1-15+18-4-0.220 [info] 1629 server.domain
2014-1-15+18-4-0.220 [info] 1614
2014-1-15+18-4-0.220 [info] 1615
2014-1-15+18-4-0.220 [info] 1608
2014-1-15+18-4-0.235 [info] 1604
2014-1-15+18-4-0.407 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/version.xml
2014-1-15+18-4-0.689 [info] 1612
2014-1-15+18-4-0.689 [info] 1620
2014-1-15+19-4-0.157 [info] 1628 server.domain
2014-1-15+19-4-0.157 [info] 1629 server.domain
2014-1-15+19-4-0.157 [info] 1614
2014-1-15+19-4-0.157 [info] 1615
2014-1-15+19-4-0.157 [info] 1618
2014-1-15+19-4-0.157 [info] 1619 1063
<snip identical entries for brevity>
</log>
Adobe Employee ,
Jan 17, 2014 Jan 17, 2014
Hello,
It appears the issue has cleared itself up after setting the path to '11', instead of 12.  Based on the logs, both ActiveX and Plugin are installed.
Maria
