1. Re: Alignment Grids for Titler in PrE & PrPro
Bill Hunt Aug 27, 2012 12:41 PM (in response to Bill Hunt)[Edit] Erroneous URL removed.
Oops, please ignore the URL that appears below. It is left over from a reply to a request for a converter in the Pr forum. It did not appear on the editing screen here, and I only saw it when I posted. I cannot find a way to edit it out and hope that Steve G. or other MOD will do this for me.
Sorry about that,
Hunt
2. Re: Alignment Grids for Titler in PrE & PrPro
able123 Dec 30, 2009 9:29 AM (in response to Bill Hunt)Thanks for grid files, downloaded, and will check it out...
Rod
ps, I just posted, used back key on browser to get back to forum message, clicked refresh and was able to edit this mssg OK...
Rod
3. Re: Alignment Grids for Titler in PrE & PrPro
Bill Hunt Dec 30, 2009 10:20 AM (in response to able123)Rod,
I use similar, when doing a lot of PiP work. I do not use PiP Presets, as I am usually doing something that is not covered by the Presets. In those cases, I will create a similar image, but create "boxes" in the position that I will be using. These "boxes" are just Shapes that get a Stroke, so I can see them, and are sized and positioned, as is required. Often, when I create those, I'll do an Export>Frame from my Video, and use it as a "guide" in PS to position my PiP's. When I Save the alignment guide image, I just turn off visibility for that Video Frame, so that it does not interfere with my alignment guide.
Back in PrE/PrPro, I use the fixed Effect>Motion>Position and Scale to adjust my PiP material to match my alignment guides.
Good luck,
Hunt
4. Re: Alignment Grids for Titler in PrE & PrPro
able123 Dec 30, 2009 10:04 PM (in response to Bill Hunt)Hi
I tested the grid idea...works well. I ended up layering stills with transparency to see the grid and line up ...I did a test title page and stills in the same psd file...and I didn't create an overall background image...but left the screen black (black video) in premiere...can do background image later...this was first time doing a layered psd to premiere...
I found the grid (especially with the various "weights" of letters in different fonts ( like the letter T or the letter O ) need to be shifted a bit for balance and the grid helps a lot with that, as well as the horizontal postition of the images. For some reason the images appear to go into layer OK vertically (centered at least, and can adjust from there depending again on "weight" issue), but horizontally they are off a bit (not centered exactly) all the time.
At any rate, I can see how the grid helps to get a reference for lining things up...so thanks for uploading that and sharing it.
I ended up using the eyeball and transparency a lot in psd, finally turning everything on and opaque before saving for import to premiere, and when in premiere I did what you suggested..put the grid on top video channel and it worked well.
Rod
ps. I'm finding it fun to do my own cross dissolves...so they aren't all the same exactly. Takes time though...so I can see big benefit to just using preset with a lot of images to deal with.
5. Re: Alignment Grids for Titler in PrE & PrPro
Bill Hunt Jan 1, 2010 12:39 PM (in response to able123)For some really Fun Transitions, try Keyframing Effect>Levels. Now, there are a lot of possible variations, but with patience, experimentation and a bunch of Keyframes, you can get some neat effects.
Good luck,
Hunt
6. Re: Alignment Grids for Titler in PrE & PrPro
Bill Hunt Dec 29, 2010 7:57 AM (in response to Bill Hunt) -
7. Re: Alignment Grids for Titler in PrE & PrPro
N.A.Majeed Apr 5, 2012 4:45 AM (in response to Bill Hunt)Hai Bill Hunt,
Your postings are very helpful...
I have one requirement in Picture in Picture format as below,
I want to play the first window video first, then second and so on in this configuration and while playing one of them others have to show as still.
amn
8. Re: Alignment Grids for Titler in PrE & PrPro
Bill Hunt Apr 5, 2012 7:43 AM (in response to N.A.Majeed)Ann,
To have the PiP Videos appear to be "paused," you would just add a Frame Capture Still Image, of the necessary Duration, to the Head of the Video. The process for doing the Frame Capture Still Image will differ by the version of Premiere that you have. In some versions, it's as simple as clicking on a little "camera" icon, to a rather convoluted process, involving Adobe Media Encoder (AME). One must check the Help File for their particular version for doing Frame Capture.
Note: if, when the individual PiP Videos have run, if you then want them to appear "paused," just do a Frame Capture of the last Frame, and add that Still Image to the end, and extend it for the necessary Duration.
Good luck, and hope that helps.
Hunt
9. Re: Alignment Grids for Titler in PrE & PrPro
N.A.Majeed Apr 6, 2012 6:55 AM (in response to Bill Hunt)Many Many Thanks........
It is very very helpful... I will use it soon for my coming project...
I hope I am not inturrepting you!!!!!
I have one more doubt...
I have one project in adobe pre.pro CS5, with the aspect ratio of 15:9 and rendered to DVD. My problem is when I am seeing this video on normal TV, missing some portion of video from left and right. So is there any solution to adjust it automatically according to the TV screen size. Or how can I render this project to the ratio of 4:3 by putting blank space on top and bottom.
I am very thankful to you for your great support..
amn
10. Re: Alignment Grids for Titler in PrE & PrPro
Bill Hunt Apr 6, 2012 9:42 AM (in response to N.A.Majeed)Amn,
I would post to the PrPro CS 5 & 5.5 Forum, with the full specs. of your Source Footage, and your Sequence Preset, plus your output settings.
That would be a better place to address your issue, than here, as almost no one will see your post, and respond. The PrPro Forum will get you a lot more "eyes," and help.
Good luck, and will see you in the PrPro Forum.
Hunt
11. Re: Alignment Grids for Titler in PrE & PrPro
N.A.Majeed Apr 7, 2012 2:42 AM (in response to Bill Hunt)thanks a lot for your time...
amn,
12. Re: Alignment Grids for Titler in PrE & PrPro
Bill Hunt Apr 7, 2012 8:20 AM (in response to N.A.Majeed)You are most welcome, and looks like you got the info needed on the PrPro forum.
Hunt
13. Re: Alignment Grids for Titler in PrE & PrPro
Bill Hunt Oct 3, 2012 8:02 AM (in response to Bill Hunt)One can also use such Grids/Guides to create custom Title Safe and Action Safe Areas. Just remember to NOT Export with that custom Guide!
Hunt
14. Re: Alignment Grids for Titler in PrE & PrPro
Brett Delmage Jan 15, 2014 6:31 PM (in response to Bill Hunt)Thanks for this Bill! Just saved me creating my own.
Brett
15. Re: Alignment Grids for Titler in PrE & PrPro
Bill Hunt Jan 19, 2014 8:04 AM (in response to Brett Delmage)Brett,
Glad that those alignment grids worked for you.
Aside from the more "general" grids, I create custom ones, when doing something like PiP, so that I can hit the exact Position and Scale, over and over.
Good luck,
Hunt
16. Re: Alignment Grids for Titler in PrE & PrPro
silviaedgar Apr 30, 2014 3:37 PM (in response to Bill Hunt)Wow, this solved a huge dilemma I was having. Thank so much not only for the info on how to do this, but for also providing the grids as well!
17. Re: Alignment Grids for Titler in PrE & PrPro
Bill Hunt May 20, 2014 3:10 PM (in response to silviaedgar)You are most welcome, and glad that the article and the grids have helped.
Happy editing,
Hunt
