hi. new here. my daughter has been having troouble on webassign--not being able to read all of the questions. have been trying to download( free version) to update my flash player. have gotten it to active x version 12.0.0.38 and plug in to 12.0.043. when downloading, the page reads that i have a 64-bit system, then i get a 32-bit download. could this be my problem? if so, how do i get the 64-bit to load? all my system reqirements excede what webassign calls for, but still probs. is the 32-bit an issue? thanks mike
There is no separate 32-bit and 64-bit installer. On a 32-bit system the installer will install the 32-bit player; on a 64-bit system it will install both 32-bit and 64-bit versions.
You can verify it by checking the contents of
On what browser do you experience these problems?
on ie 11. then would it show 32-bit on my control panel? actually I found my daughter ( I guess) had installed google chrome which I think has a higher ver of flash because webassign will display properly when using it.
The Flash Player (32 bit) in the control panel refers to the Global Settings Manager, which is a 32 bit app.
ok thanks for clearing that up. mike
