Tells me that FP is part of IE 11, when I test it, it tells me not installed or enabled. FP does not show up when I go to the uninstall programs. Just want to load it so can use it
Flash Player is integrated into IE for Windows 8 & 8.1 by Microsoft. Since it's a "plug-in" and NOT a program, you'll NEVER find it listed as a program. It's located in C/Windows/System32/Macromed/Flash and C/Windows/SysWOW64/Macromed/Flash.
The problem with IE11 is that Microsoft not only screwed up the code, but they refuse to admit it doesn't work. The pages can't recognize the browser, so they don't recognize any of the plugins, like Flash Player. So far, Microsoft has made NO indication that they have any plan to fix it soon.
Microsoft's recommendation is to use Compatibility View for affected pages, and "pretend" you're using an different browser. Trouble with that is it has seen limited success at best, and you have to individually enable it for EVERY page that has problems.
I'm not big on "pretending" so I recommend actually using another browser.
ANY of those will work where IE11 won't, with the Flash Player Plug-in (For all other browsers), and Chrome doesn't even need that because it has its own Flash Player plugin built in.
