In a web app that is displaying personal profiles, (so enter the page, select the person, their details show) I need to have buttons on that detail page allowing users to move to the next DETAIL page and the previous one. This is so they can browse at the detail level without returning the to the list view. I cannot see a module to allow this - is this doable?
Hi
This is doable only with some custom scripting.
If you use {module_webapps,XXXXX,a} it will list all your webapp items(with links to detail view) in an ordered list.
1. Item_1
2. Item_2
3. Item_3
You should be able to put this module in a hidden div and use a script to match the current url with the position of the respective item in the list. So if your current url is "yourdomain.com/webappname/item_2", the script should see that it maches the 2nd entry in webapp items list, so it would assign the "next" button with the href value of "item_3", and for the "previous" button it would pass "item_1"'s href.
Hope this helps.
Kind Regards,
Alex
This solution isn't ideal. We have a client with 600+ properties in a web app and they want to be able to navigate between items.
Is this something that can be added in a future release? It's a pretty basic feature in other CMS platforms.
Cheers,
Klaye
This tutorial should do the trick
http://kiyuco.com/tutorials/create-web-app-detail-page-pagination-2-0
