I'm using Flash on my Mac (OS X 10.9.1) and it's stopped working. I get the following error message:
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Volumes/VOLUME/Clinical Examination.app/Contents/MacOS/Flash Player
__TEXT 0000000000001000-00000000005f4000 [ 6092K] r-x/rwx SM=COW /Volumes/VOLUME/Clinical Examination.app/Contents/MacOS/Flash Player
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_c.dylib 0x947ac785 strlcpy + 53
1 com.apple.CoreServices.CarbonCore 0x92aa7901 UTF8ToFSSpecName + 50
2 com.apple.CoreServices.CarbonCore 0x92a4606d FSRefCreate + 423
3 com.apple.CoreServices.CarbonCore 0x92a46510 PBGetCatalogInfoSync + 1025
4 com.apple.CoreServices.CarbonCore 0x92a46107 FSGetCatalogInfo + 53
5 com.apple.CoreFoundation 0x99be8b5e filePathToHFSPath + 526
6 com.apple.CoreFoundation 0x99be7a27 URLPathToHFSPath + 151
7 com.apple.CoreFoundation 0x99abae3d CFURLCreateStringWithFileSystemPath + 477
8 com.apple.CoreFoundation 0x99ab750a CFURLCopyFileSystemPath + 426
9 com.macromedia.Flash Player.app 0x002ab2e0 0x1000 + 2794208
10 com.macromedia.Flash Player.app 0x002acd44 0x1000 + 2800964
11 com.macromedia.Flash Player.app 0x002c68b1 main + 2001
12 com.macromedia.Flash Player.app 0x00002892 0x1000 + 6290
13 com.macromedia.Flash Player.app 0x000027b9 0x1000 + 6073
Any advice?
Do a "clean install": How to perform a "clean install" of Flash Player in Mac OS X
What is ClinicalExamination app? Is that what you were using when it crashed?
It may require the standalone Player (Projector) Macintosh Flash Player 12 Projector
You'd need to copy that (standalone player) to the Contents/MacOS folder of the ClinicalExamination app by right clicking it and selecting "Show Package Contents"
Thanks Mike. I'd already done the 'clean install' twice... but still got that error message.
Yes, Clinical Examination is a DVD. It had worked previously using flash (this was the default option) but doesn't work now (i've upgraded to Mavericks in the meantime, but not sure if that's the problem).
I downloaded the flash projector as you suggested. I found the Content/MacOS folder as you suggested too (it contains a Flash Player 'Unix Executable File'). I tried to copy the new standalone player to this folder, but it wouldn't let me drop it in.
Any further ideas?
"I tried to copy the new standalone player to this folder, but it wouldn't let me drop it in."
Nope... You CAN'T copy it to the DVD. It's a "read only" medium.
What you'd need to do is copy the contents of the DVD to your HD and THEN replace the Projector with version 12.
You could then make a DMG of the contents and run the app from there.
More thsan likely, it's finding a version conflict between the Projector in the Contents/MacOS fodler and the newer one you've installed.
Does ClinicalExamination run in its own UI or does it use Safari?
