Not sure if this is a bug or a feature. I wanted to use the chapter title name in the footer of my master pages so I went to the master page, deleted some static text i found there then tried to add the building block <$chaptertitlename> but what i got was the short file name instead. Is there a fix for this?
See: Chapter Title Name variable in FM10
I'd go with Running H/F 1 or 2 myself, depending on how you implement chapter titles in body text.
The <$chaptertitlename> building block wasn't really designed for what you're trying to use it for. It's for hierarchical books where you're using folders and templates.
From the Help:
Associate a template with a folder to publish a cover page for the files in the folder. Any template associated with a folder is published like any other file in a book. Use the <$chaptertitlename> variable to include the folder name in the template associated with the folder. You can use this variable for a folder occurring at any level in a book.
See also:
http://blogs.adobe.com/techcomm/2009/09/fm9_hierarchical_books_new_variable.html
http://blogs.adobe.com/techcomm/2009/06/numbering_in_hierarchical_books.html
As Error suggests, use a running header/footer variable to reference the paragraph text of the chapter title tag.
