I am posting this again. Besides the fact that it took me
bloody ages to write the first time, I thought it would concern
more than a few users. Maybe there's just not enough people using
it yet?
It is in response to David's article at
http://www.adobe.com/devnet/captivate/articles/filesize.html.
I'm just after a little more information than what he gave. If
anyone think I should, or want to themselves point David to this
post, please let me know. Truth is he probably doesn;t have time,
but it would make quite a comprehensive list of answers for us
beginners:
1. Minimize file size by reducing the recording area in
Captivate:
Sure, but what is the relationship between recording area and
file size? I know there's a relationship between total number of
pixels x bytes per pixel, but there must be more to it than that.
2. Reduce the amount of background noise;
OK - easily done.
3. Reduce the color gradients in your recording area:
How much does this really affect the final size? Is it closer
to .05% reduction or 50% reduction? I can see how this may be
appropriate for simple slideshows, but what if the animations are
graphically intensive, do the color gradients really matter then?
Is this point outdated with the increasing complexity of
animations?
4. When recording in "Full Motion" format, Captivate converts
the recording from AVI format to static screen shots. This
increases the overall file size more than a traditional
recording:
Again, in producing a thoroughly enthralling animation, with
3D graphics and voiceovers, etc, full motion is a necessity. If the
Full Motion Recording options (which is only briefly mentioned in
the demonstration) are altered, is there a proven relationship
between all the settings (Smoother Movie/Video Quality/Video Color
Mode) and the final size of that recording?
5. Remove any extra slides that do not add any value to the
presentation:
Sounds like a sensible idea. Is there anywhere where we can
see the size of an actual slide?
6. If you insert large images, expect your Captivate file size
to grow more than if you insert small images:
Like point 1, what's the magic formula? Even a ballpark
figure would help. David mentions SWF files and the file size
should increase only by about the same amount as the inserted SWF
file. That's good stuff - a tangible amount.
7. On the Start and End tab:
Okay, but I'm definitely going to need those. Again is there
anywhere where we can find out how big they are?
8. Advanced movie compression: Select this option to compress
slide data shared between slides, thereby reducing overall file
size:
Sweet, consider it done. How much did it just save me?
9. Compress compiled SWF file: Do not deselect this option.
I won't. In fact I am not sure why it's even an option!
10. Include Breeze metadata: This option, which is selected by
default, increases the size of the project. If you are not going to
use the project with Macromedia Breeze, deselect the option to
decrease the size of the finished project file (SWF). However, if
there is the possibility that the output file (SWF) may be used in
Breeze, it is best to select this option.
Bit of a crap shoot at this stage. If I knew just how much I
was saving in the file size, I would be better informed to know
whether to include it or not.
11. 508 compliance: Publishing 508-compliant output increases
your file size. If audience analysis concludes that are no learners
with disabilities that need to access your content—or if you
are not otherwise required to comply with Section 508 government
regulations—you can safely turn off 508 support.
C'mon sevens! Again if only I knew the real impact on my
filesize, I would know whether to just leave it checked, just in
case it will one day be needed.
12. Frames per second: The default setting is 30 Flash frames
per second (fps) and this is appropriate in most cases. Note:
Decreasing the number of frames per second does not significantly
decrease the size of your Captivate project and therefore is not
recommended. For example, decreasing the fps rate by half does not
halve the file size. Also, reducing the fame rate of Captivate is
not the same as reducing the frame rate of an AVI. Lowering the
frame rate of an AVI removes static images from the file, which
reduces its size. Removing a single frame from a Captivate project
where no change takes place does not reduce the file size.
Mine defaults to 10 fps, is that bad? Now I'm confused! So
what is the best frame rate, and just how much does it reduce the
file size when changed?
13. Movie background color: Depending upon the type of slide and
how you took screen shots, the background color might not appear on
all slides. Double-click the color box to open the color picker,
and select a new color. Remember that using a bright background
color will increase the file size.
Does this ~really~ matter if I have 3D Virtual models and
constant audio? Or is it like worrying about if the temperature in
Antarctica is 70 below or 71 below?
14. JPEG image quality: Adjust this setting depending upon the
images used in your movie. Lowering your image quality to as low as
50% (from the default 75%) is often not noticeable to the naked
eye. Higher percentage values allow for very high quality images.
Of course, this also increases file size.
Okay, but numbers would be good again.
15. Play tap audio for recorded typing when movie is generated:
This option plays tapping sounds in the final movie whenever keys
are pressed during recording. Including this option adds a small
audio file to your project and does increase the file size, but
only by a small amount.
No sure how much they'll hear the taps with me talking over
them the whole way through it, but I can turn them off. I think a
lot of people finding them slightly annoying anyway, but how much
did I just gain with that happy move?
16. Including a playback control bar increases the file size by
a small amount. If your users do not need a playback
control—as is often the case with simulations and
quizzes—select None from the menu.
Well they are going to need to play these things back
somehow, but I may have that created separately. What's the average
size of a playback control bar anyway? And how does You Tube get
away with all this stuff?
I am not trying to be cynical, I'm really not, but I am
surprised that this has been raised and addressed by
Macromedia/Adobe already. I would assume that as users develop more
engaging and interactive content, these will become more important.
Is there any hope or support for someone like myself, who wants to
know every shortcut there is in order to deliver the best possible
animations?
As always, any help from any of the experts here, would be
gratefully received!
Thanks and I look forward to your replies.
Cheers,
spritc.
