I've looked in all the sections in the Settings dialog, but I don't see anything that will allow me to make the font size larger. I just want to enlarge the TOC books and page listings on the left.
Please tell me that RH allows you to do something this simple...
Can you tell us what output you are generating?
i'm working with WebHelp.
when i choose File >Generate > Primary Layout, i'm looking in this Settings dialog for a way to set the font size.
You'll need to amend your skin. Double click the skin in the Project Setup pod. This opens the Skin Editor. Click on the Navigation tab and then the Font button.
ok - i see how that works - thank you!
now, what if i'm not using a skin at all? there must be some way to change the font size of the TOC for (Traditional style - no skin), right?
Just make the change in the Default skin. If you haven't selected any other skins Default is probably what you're using.
