So correct me if I'm wrong. I have a file structure that looks like this:
models
> framework
>> alpha.cfc
application.cfc
I am executing from application.cfc. In it, I have created a mapping (NOTE THE DIFFERENCE IN SINGULAR/PLURAL):
<cfset this.mappings[ '/model' ] = expandPath( '/models/framework' ) />
When I dump the this.mappings structure, I expectedly get:
c:\path\to\webroot\models\framework
So I now dump this code:
<cfdump var="#fileExists( expandPath( '/model/alpha.cfc' ) )#" />
And sure, enough, I get: YES
So here's my problem. I had always thought that in dot notation syntax, ColdFusion looked at the first value provided and did a mapping check on it. However, when I run:
<cfset myNewAlpha = new model.alpha() />
I get a message saying the CFC cannot be found. Only by typing the following:
<cfset myNewAlpha = new '/model.alpha'() />
Does it actually work and find the CFC through dot notation my using the this-scope mapping.
So, is there something I'm missing as to why I can't just call nameOfMapping.path.to.cfc rather than having to make a literal string out of it?
Well, status update. Even after doing an: applicationStop() and for all practical puposes, killing the application, it seems ColdFusion, the service, holds onto those mappings and caches them. I actually had to RESTART THE COLDFUSION APPLICATION SERVICE to get it to release those mappings, and now I can use the: new model.alpha() syntax as expected.
Sheesh!
You are right: it should work as you expect! Since it fails, this might be an indication that expandPath( '/models/framework' ) and c:\path\to\webroot\models\framework\ are not the same.
To verify, I would test with
<cfset this.mappings[ '/model' ] = "c:\path\to\webroot\models\framework\" />
together with
