(FM 11, Win XP)
When you query ComponentType for an FM document book component, you get hexadecimal 0x200 which happens to equal Constants.FV_BK_FILE. However, the documentation says that this property should return one of:
• Constants.FV_BK_FOLDER (0x02) - Folder
• Constants.FV_BK_GROUP (0x40) - Group
• Constants.FV_BK_FM (0x8) - FrameMaker document
• Constants.FV_BK_MIF (0x10) - MIF document
• Constants.FV_BK_XML (0x20) - XML document
Given the supposed MIF and XML options, I'm not sure if there is a bug in ES or if the documentation is just wrong. An XML component also returns 0x200. Any thoughts?
Russ
Hi Russ,
same issue here (FM 11, Win7). I'm not sure, but in my opinion it's an error in the documentation. The values for ComponentType should be:
Additionally you could check the sort of file type via BookComponentFileType (FM, MIF, XML, Ditamap).
In a short test script for traversing a hierarchical book the BookComponentFileType has some more values:
The main difference between ComponentType and BookComponentFileType seems to be the more detailed information about the file type.
Best Regards, Andreas
Message was edited by: justBE
