Using Robohelp 9, Baggage files have been added to project and links created to them but linked baggage files will not open when project is generated. Using local drive and have attempted display in IE10, IE10 (compatability mode), IE9, IE8 but get same result.
Are you using Mark Of The Web? If so, that will cause links to baggage files to fail when viewing locally.
Cheers... Rick
Cheers... Rick
Rick, Thanks! Yes, I am using Mark of the Web. Checked a previously published/posted project with the same baggage files and they are displaying properly. Unforutnately for me, testing a project on the web is not a simple process but i am working on that.
Thanks for your help.... your answer was right on target.
Don
You can always “roll your own” fake webserver by using the method offered by Peter Grainge (http://www.grainge.org/pages/snippets/snippets.htm#browsers) from these guys http://www.helpandmanual.com/hm2go.html
This was helpful information. We publish to a server and so all our outputs have Add Mark of the Web selected. However, I just create a duplicate SSL, deselect Add Mark of the Web, and then generate.
Carol
