I have the following query that looks up customer accounts:
SELECT ACCOUNT_ID, SUBSCRIBER_ID, PKG_CODE
FROM Accounts
WHERE ACCOUNT_DESC LIKE '%Eye%'
GROUP BY ACCOUNT_ID
Which gives me the following result..
1. ACCOUNT_ID, SUBSCRIBER_ID, PKG_CODE
2. ---------- -------------- -------
3. 11016869, 10016598, N
4. 11015922, 10015713, N
5. 11015062, 10014878, N
6. 11018312, 10017973, Y
7. 11018310, 10017973, N
8. 11018309, 10017973, N
9. 11018308, 10017973, N
Question: How do I display a "1" in a Flag column if "any one" of the "SUBSCRIBER_ID's" have a value of "Y" in the PKG_CODE column?
Here are the query results that I'm trying to get to for this example (notice that the last 4 records need to be flagged a "1" because one of them had a "Y" for PKG_CODE and matching SUBSCRIBER_ID's..
I tried the following, but it only flags the "Y" records? I need it to also check the SUBSCRIBER_ID" column value..
, IF(PKG_CODE = 'Y', "Y", "N") AS FLAG
FROM Accounts
GROUP BY ACCOUNT_ID
If this can be done on the CF page, that would work as well instead of in the query.. i just need the Flagged values to display alongside each record.
SELECT ACCOUNT_ID, SUBSCRIBER_ID, PKG_CODE, IF(SUBSCRIBER_ID IN
(SELECT SUBSCRIBER_ID
FROM Accounts
WHERE ACCOUNT_DESC LIKE '%Eye%' AND PKG_CODE = 'Y'), 1, 0) AS flag
FROM Accounts
GROUP BY ACCOUNT_ID
You are on the right track. I actually expected something like
SELECT ACCOUNT_ID, SUBSCRIBER_ID, PKG_CODE, IF(PKG_CODE = 'Y', 1, 0) AS FLAG
Updated.. but it still is not working right..I need it to also check the SUBSCRIBER_ID" column value..
Here is what I get now using the code: IF(PKG_CODE = 'Y', 1, 0) AS FLAG
- Notice that lines 7 & 8 did not go to "1" ?
- But the "10017973" value matches the first one with a PKG_CODE = 'Y'
- I needed those two lines to also go to "1" because they share a common value AND PKG_CODE = 'Y'
FROM Accounts
FROM Accounts
GROUP BY ACCOUNT_ID
@BKBK, thanks for the SubQuery.. that did the trick!
Cheers! I have just seen something that could make it more efficient, namely
SELECT DISTINCT SUBSCRIBER_ID
