quote:
Originally posted by: emmim44
<cfset a =" \h12\|ctr10|img0.dgn|doc1, \h13\|ctr12|img0.dgn|doc2, \h13\|ctr13|img0.dgn|doc3, \h13\|ctr10|img0.dgn|doc40, \h13\|ctr15|img0.dgn|doc2, \h13\|ctr12|img0.dgn|doc2 " >
Is that more clear now ?
I wan the list to be like this.
<cfset a ="
\h13\|ctr12|img0.dgn|doc3,
What do you mean by Use q of q to sort it.?
quote:
Originally posted by: Dan Bracuk
Once you have your query populated, select all the fields and use the order by clause to sort it.
I have created the 4 column but I received errr...
The err:::
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
Error casting an object of type to an incompatible type. This usually indicates a programming error in Java, although it could also mean you have tried to use a foreign object in a different way than it was designed.
<cfset qLetter.sort(columnId, 1)>
