I have a RH 10 Webhelp project, and need to add a print link or print button to each topic. Is there a way to do that?
See Snippets on my site..
Hi Peter,
Two problems:
1) I tried the steps on your site but I couldn't get it to work. Not sure where I went wrong. The print button only partially displays in the navigation pane, and it doesn't do anything.
Also, there is a second issue: My webhelp system is CSH, so when a user clicks the help link in the web app, they get just the single CSH topic, with no nav pane. There is a small Show link in the topic that opens up the nav pane but some users won't know what that is and might notice it. I was hoping for a print link or button that would show up on the single topic, in the area of the breadcrumbs. Might there be some javascript that I could add to each topic?
Hi there
You could add a link to the header area of a Master Page (or to a Snippet) that has a Javascript print command in it.
A typical code would look like this:
window.print();
Cheers... Rick
