3 Replies Latest reply: Jan 27, 2014 1:04 PM by Josh_Corey RSS
    converting PDFs?
    DetroitTigers1 Community Member
      Can we edit or convert PDF to enable sorting etc?
        • 1. Re: converting PDFs?
          Josh_Corey Employee Hosts
          Hi;
          I am not really clear on what you are asking.  Can you describe your work flow a little more?  Where is the PDF from?  Is it a PDF from FormsCentral or one you want to use in FormsCentral using the Import PDF feature?
          Josh
          • 2. Re: converting PDFs?
            Hi Josh,
            It would be an import and is an OEM form (from one of our Manufacturers) with equipment data by model and coverage expiration. We would like to be able to Sort and/or Filter in excel.
            I hope this helps.
            Mark Mansour
            • 3. Re: converting PDFs?
              Using the Import PDF feature the form submissions are collected by FormsCentral and available in a Table on the "View Response" tab that can be sorted and filtered like in Excel, and can also be exported to Excel from their.
              This tutorial goes over exporting data from the View Responses tab in FormsCentral to Excel (also PDF and CSV): http://forums.adobe.com/docs/DOC-1383
              This is a tutorial of the Import PDF feature: http://forums.adobe.com/docs/DOC-2654
              You can also try the Import PDF feature out in a Free account to see how it works for your form.
              The ability to export to Excel from your PDF or how you can sort/filter in Excel isn't changed by using the Import PDF featuer in FormsCentral, to learn more about exporting data and sorting in Excel you might post in the Acrobat Forms forum: http://forums.adobe.com/community/acrobat/forms
              Josh
