Win7 Pro 64 bit. Firefox 27.0. There had been comments from websites since many months: flash player is out of date. Again today. So, I uninstalled the older versions : It seemed clear that these (there were two) had failed to install correctly, if at all. So, right now, no FPlayer installed at all. I activated the Java plug in so that it is always 'on'. Same result: FP will NOT download so therefore will not install. Wits end! (That is not a title for a TV show!) Remedies???
Download the Adobe Flash Player installer directly by clicking one of the following links.
Flash Player for ActiveX (Internet Explorer)
Flash Player Plug-in (All other browsers)
Those are offline installers, so "Save" them, close your browser and THEN run them.
Thanks! Yes! This works! Now I need only to verify that it is indeed
installed! Many thanks for the timely and practical advice!!!
I have the same problem but even the direct download link will not work. I constantly get failed to download. I even tried other download load programs and they all come up with server error. I searched out two of adobes developers programs that have this file in it and the same thing happens, This has me at a total loss on now to fix.
Hello,
Can you please start a new thread with your issue. This one is fairly old.
BTW, you appear to be interchanging the online installer with the offline installer and it's hard to tell what you've done, or not done, with one or the other. When posting, please provide the information as per this FAQ: Please read this before you post! It will help in troubleshooting your issue.
Thank you.
Maria
