1. Re: "internal software error:\Vobulator\TitlePlanner\CGOPGrouper.cpp line 410
Stan Jones Jan 25, 2014 8:35 PM (in response to wbcarey200)One of the less common of the vobulator type errors.
Based on limited info, I would check/consider the following:
Because this is unusual and because you have orphan timelines, I would not worry about trying to idenify a single cause, and I would move to "do over" quickly.
I assume you are using Encore CS6.
Make sure you are "running as admnistrator."
Do not put multiple videos on one timeline.
Do not have any gaps in your videos (e.g. in Premiere).
If you are using dynamic link from Premiere, don't.
It might help for you to post a screenshot of your flowchart.
Are you using overrides? If so, it is much harder for you to get an error free project.
This is the only adobe Encore forum thread I found, and there were no others elsewhere on the web.
http://forums.adobe.com/message/3155616#3155616
3. Re: "internal software error:\Vobulator\TitlePlanner\CGOPGrouper.cpp line 410
Neil Wilkes Jan 28, 2014 12:16 PM (in response to wbcarey200)What Stan said.
