4 Replies Latest reply: Jan 30, 2014 7:34 PM by thanser RSS
    Yet Another Convert AS1 to AS3
    thanser Community Member
      Shouldn't be too hard!
      I adopted someone else's older Flash project, and I need to update it.
      I have a map featuring several buttons on various cities. One button, with many instances, named accordingly.
      Roll over a button instance, and it goes to the appropriate label on a MC timeline, showing the appropriate text.
      How do I update this to AS3?
      _root.seattle.onRollOver = function ()
      _root.text.gotoandstop("seattle");
      Seattle is the button instance name, text is the MC name and the seattle is the MC label name.
      I'll end up with this code repeated many times, for each of the different buttons.
      Any help?
      Thanks.
        • 1. Re: Yet Another Convert AS1 to AS3
          moccamaximum Community Member
          import flash.events.MouseEvent;
          root.seattle.addEventListner(MouseEvent.ROLL_OVER, roHandler);
          function roHandler(e:MouseEvent):void{
          root.text.gotoAndStop("seattle");
          • 2. Re: Yet Another Convert AS1 to AS3
            Thank you!  Making progress.
            I fixed your typo Listner to Listener, but I get two compile errors:
            Scene 1, Layer 'Actions', Frame 1, Line 191119: Access of possibly undefined property text through a reference with static type flash.display:DisplayObject.
            Scene 1, Layer 'Actions', Frame 1, Line 151119: Access of possibly undefined property seattle through a reference with static type flash.display:DisplayObject.
            My code:
                 stop();
                 /* Rollover button command
                 root.seattle.addEventListener(MouseEvent.ROLL_OVER, roHandler);
            When I test this movie, it loops endlessly. I have stop commands in place (main timeline AND the MC), but...what am I missing?
            Thanks again.
            • 3. Re: Yet Another Convert AS1 to AS3
              its not a good idea to name a movieclip exactly like a common property.
              try renaming it to CityLabels or sth.
              Honestly, I have difficulties to understand what you are tring to communicate here.
              if Seattle is a SimpleButton instance, you should convert it to a MovieClip, since SimpleButtons have some drawbacks when trying to overlay your own eventlisteners.
              There is also sth. wrong with the nesting of your string component
              • 4. Re: Yet Another Convert AS1 to AS3
                Well, as I'm not exactly a developer nor am I very fluent in AS3, I did my best to communicate my needs and my current code.
                I'm going to go in another direction with this project, and try roll over buttons that go to a different frame with text on it.  On roll out, go back to frame 1 and stop.  I don't know how else to do it.
                The project file I have now is AS1, and a button instance commands a MC to go to a frame number, but I don't know how to get a button and a MC to work together.
                Thank you.
