I downloaded the latest CF10 installer from Adobe. Installed it on Windows Server 2012 and it works fine for regular port 80 web traffic. But, I get a connection error when I try to use https (port 443). I have bindings in IIS 8 for both http and https.
Does anyone have any ideas on how to troubleshoot this?
If you already has installed the SSL certificate and enabled the SSL on the site, check the windows firewall or antivirus.
Thank you for your reply, but I still have the problem with Firewall and AntiVirus turned off.
I would call your hosting company and check if they have a hardware firewall running. Maybe they have port 443 blocked on that device.
To test this firewall idea further, I created a virtual directory in IIS and then dropped in some working dot net code. It works fine as a https connection from my desktop.
ROFL
one of the devlopers had put this code into the the root directory index page
<cfif CGI.HTTPS EQ 'ON'>
<cflocation url="http://#CGI.SERVER_NAME#/index.cfm?1" />
</cfif>
No wonder it didn't work.
