1. Re: How do I adjust the 'Check' size in checkboxes?
try67 Jan 29, 2014 9:53 AM (in response to BSisson)In Acrobat/Reader this will only happen if you change the size of the field.
2. Re: How do I adjust the 'Check' size in checkboxes?
try67 Jan 29, 2014 9:55 AM (in response to BSisson)Actually, you can also change the font size, but if the font size exceeds
the size of the field the check-mark will simply get truncated...
3. Re: How do I adjust the 'Check' size in checkboxes?
BSisson Jan 29, 2014 10:26 AM (in response to BSisson)OK, in going back and forth and back and forth I found the solution and it wasn't even close to what I thought it was....
The checkbox that you SEE is -NOT- the actual checkbox, is is part of the TEXT FIELD or Helper text.
Then over that "text" of the box, is an INVISIBLE (no borders) much larger checkbox that has a big enough "check" you can see it.
I had to go through the old file and find un-unedited field, and then I saw that when I deleted the checkbox, the box remained, as it wasn't part of the checkbox, it was just a symbol in a text field.
