13 Replies Latest reply on Jan 31, 2014 11:50 AM by MikkelMadsen
    SEO and edge animate
    MikkelMadsen
      Hey there adobe forum
      I would like to know, how the best way of implementing edge animate to your html files for seo.
      as for now, I just publish on the adobe cdn and as static html.
      it looks like this as for now:
      <script src="edgefile.edgePreload"></script>
      <html>
      <body>
      <div id="stage1(we have around 4 compositions) class="edge_menu"></div>
      <body>
      <html>
      But? Should I put the whole html output from the static file adobe genereates in my html file?
      Hope this makes sense hehe.
      Mikkel Madsen
        • 1. Re: SEO and edge animate
          darsh136
          Hey Mikkel,
          You can publish your file in static html for a better seo result. Did you already try to do it ?
          1 person found this helpful
          • 2. Re: SEO and edge animate
            MikkelMadsen Level 1
            Yes I just don't know how to implement is correctly. Just the div for the edge or the whole html from the static file edge animate makes.
            • 3. Re: SEO and edge animate
              heathrowe Most Valuable Participant
              Mikke
              Go to File > Publish Settings > tick Web and toward the bottom tick Publish content as static HTML.
              See capture
              Then click Save in the same window, then File > Publish whenever you are complete.
              In this regard you will want to apply Titles and or Tab Index from the Properties > Accessibility area on selected elements for better SEO results.
              Darrell
              • 4. Re: SEO and edge animate
                elainecc Adobe Employee
                As context, Mikkel reached out to me via private message and I asked him to post here on the main forums.  The thrust of his question is not only how to use static publishing, but also how to integrate the Edge Animate project into his existing index.php file so that it can be indexed.  As is mentioned in other threads, you can either place the file in an iframe (which has some issues with indexing, as others have pointed out) or you can wire the result into your file by hand.
                If you choose to wrie the result into your file by hand, you will have some maintainability problems, as this is not something you can round-trip.  So with that caveat:
                You will need two parts: the runtime reference files in the <head> tag, and the Stage <div> and all of its contents.  First, copy everything between <!-- Adobe Edge Runtime--> into your index.php file's <head> section.  Then, you can place the <div id="Stage"...> tag and everything inside of it (which includes your text!) into your index.php file.
                Then, you should be able to open your index.php file and have your Animate file run.
                Hope that helps,
                -Elaine
                • 5. Re: SEO and edge animate
                  darsh136 Level 2
                  What I'm doing is to write my own html code as an alternative for SEO but it's a bit more tedious.
                  p.s: Don't forget if you don't have a lot of content in your edge movie, even if you publish it as static html, the seo result won't be as great as expected.
                  • 6. Re: SEO and edge animate
                    Many thanks Elaine! I get problem doing that. Even though I changed the stage IDs to be different from eachother some of the animation wont work. It works when I remove all the html content, and only put in the stage div:S why is that?
                    And the content of the animation is showed 2 times instead of 1, if i post all the divs etc etc.
                    • 7. Re: SEO and edge animate
                      Hi, Mikkel-
                      There's a distinct possibility that there's something in your parent file that is interfering with the Animate comp.  If you can post your entire file, we can try to troubleshoot, but the best thing for you to do is to see if you get a console error.  I use Chrome Inspector or Firebug to debug quite often; you might want to try to see if that will give you a hint as to what might be happening.
                      Hope that helps,
                      -Elaine
                      • 8. Re: SEO and edge animate
                        <!DOCTYPE html>
                        <html>
                        <head>
                                  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
                                  <meta http-equiv="X-UA-Compatible" content="IE=Edge"/>
                                  <title>footer</title>
                        <!--Adobe Edge Runtime-->
                            <script type="text/javascript" charset="utf-8" src="footer_edgePreload.js"></script>
                            <style>
                                .edgeLoad-footer { visibility:hidden; }
                            </style>
                        <!--Adobe Edge Runtime End-->
                        </head>
                        <body style="margin:0;padding:0;">
                                  <div id="footer_edge" class="footer">
                                <div id="Stage_Text2" class="edgeLoad-footer">CRAFTHOUSE I/S</div>
                                <div id="Stage_Text2Copy" class="edgeLoad-footer">Kontakt</div>
                                <div id="Stage_Text2Copy2" class="edgeLoad-footer">Hold dig updateret her</div>
                                <div id="Stage_Text3" class="edgeLoad-footer">Udviklet af</div>
                                <div id="Stage_Text4" class="edgeLoad-footer">Mjøsensgade 14, 1.sal tv</div>
                                <div id="Stage_Text4Copy" class="edgeLoad-footer">2300 København S</div>
                                <div id="Stage_Text4Copy2" class="edgeLoad-footer">Danmark</div>
                                <div id="Stage_Text4Copy9" class="edgeLoad-footer">CVR-nr: 35128638 </div>
                                <div id="Stage_homepage" class="edgeLoad-footer">
                                    <div id="Stage_homepage_Text4Copy3">www.crafthouse.dk</div>
                                </div>
                                <div id="Stage_Text4Copy7" class="edgeLoad-footer">+45 60 24 75 98</div>
                                <div id="Stage_Text4Copy6" class="edgeLoad-footer">info@crafthouse.dk</div>
                                <div id="Stage_Text4Copy4" class="edgeLoad-footer">© Crafthouse I/S 2013</div>
                                <div id="Stage_phone_logo" class="edgeLoad-footer"></div>
                                <div id="Stage_mail_ikon" class="edgeLoad-footer"></div>
                                <div id="Stage_logo" class="edgeLoad-footer">
                                    <div id="Stage_logo_wrapper"></div>
                                    <div id="Stage_logo_logo_footer_hover"></div>
                                    <div id="Stage_logo_logo_footer"></div>
                                </div>
                                <div id="Stage_Rectangle3" class="edgeLoad-footer"></div>
                                <div id="Stage_Rectangle3Copy" class="edgeLoad-footer"></div>
                                <div id="Stage_Rectangle3Copy2" class="edgeLoad-footer"></div>
                                <div id="Stage_Rectangle3Copy5" class="edgeLoad-footer"></div>
                                <div id="Stage_Rectangle3Copy4" class="edgeLoad-footer"></div>
                                <div id="Stage_Rectangle3Copy3" class="edgeLoad-footer"></div>
                                <div id="Stage_Rectangle4" class="edgeLoad-footer"></div>
                                <div id="Stage_Rectangle4Copy" class="edgeLoad-footer"></div>
                                <div id="Stage_facebook_ikon_hover2" class="edgeLoad-footer"></div>
                                <div id="Stage_googleplus_ikon_hover" class="edgeLoad-footer"></div>
                                <div id="Stage_footer_blog_icon" class="edgeLoad-footer"></div>
                            </div>
                        </body>
                        </html>
                        <-- This is the file edge gives me. When I but the needed html in my main file, the text shows double, it is really weird. And I used the style .hidden aswell -->
                        • 9. Re: SEO and edge animate
                          Sorry, can you post your entire project, including the parent HTML and your source composition files (everything including the .an file)?
                          -Elaine
                          • 10. Re: SEO and edge animate
                            HTML file:
                            <!DOCTYPE html>
                            <html>
                            <head>
                                <style>
                                </style>
                            </head>
                                      <div id="Stage" class="footer">
                                      </div>
                            </body>
                            </html>
                            footer_edge.js
                            * Adobe Edge: symbol definitions
                            (function($, Edge, compId){
                            //images folder
                            var im='images/';
                            var fonts = {};    fonts['doppio-one, sans-serif']='<script src=\"http://use.edgefonts.net/doppio-one:n4:all.js\"></script>';
                                fonts['Oxygen, sans-serif']='<link href=\'http://fonts.googleapis.com/css?family=Oxygen\' rel=\'stylesheet\' type=\'text/css\'>';
                            var opts = {};
                            var resources = [
                            var symbols = {
                            "stage": {
                                version: "3.0.0",
                                minimumCompatibleVersion: "3.0.0",
                                build: "3.0.0.322",
                                baseState: "Base State",
                                scaleToFit: "none",
                                centerStage: "none",
                                initialState: "Base State",
                                gpuAccelerate: false,
                                resizeInstances: false,
                                content: {
                                        dom: [
                                            type: 'text',
                                            rect: ['96px', '165px','326px','99px','auto', 'auto'],
                                            text: "CRAFTHOUSE I/S",
                                            align: "left",
                                            font: ['doppio-one, sans-serif', 24, "rgba(0,0,0,1)", "400", "none", "normal"]
                                            type: 'text',
                                            text: "Kontakt",
                                            align: "left",
                                            type: 'text',
                                            text: "Hold dig updateret her",
                                            align: "left",
                                            type: 'text',
                                            rect: ['0px', '148px','196px','19px','auto', 'auto'],
                                            text: "Udviklet af",
                                            align: "left",
                                            font: ['Oxygen, sans-serif', 12, "rgba(255,255,255,1.00)", "normal", "none", "normal"]
                                            type: 'text',
                                            rect: ['1px', '214px','227px','19px','auto', 'auto'],
                                            text: "Mjøsensgade 14, 1.sal tv",
                                            align: "left",
                                            font: ['Oxygen, sans-serif', 14, "rgba(255,255,255,1.00)", "normal", "none", "normal"]
                                            type: 'text',
                                            rect: ['1px', '250px','227px','19px','auto', 'auto'],
                                            text: "2300 København S",
                                            align: "left",
                                            type: 'text',
                                            rect: ['1px', '286px','227px','19px','auto', 'auto'],
                                            text: "Danmark",
                                            align: "left",
                                            type: 'text',
                                            rect: ['409px', '287px','227px','19px','auto', 'auto'],
                                            text: "CVR-nr: 35128638 ",
                                            align: "left",
                                            type: 'rect',
                                            rect: ['1', '323','auto','auto','auto', 'auto'],
                                            cursor: ['pointer']
                                            type: 'text',
                                            rect: ['443px', '214px','109px','19px','auto', 'auto'],
                                            text: "+45 60 24 75 98",
                                            align: "left",
                                            type: 'text',
                                            rect: ['443px', '249px','131px','19px','auto', 'auto'],
                                            text: "info@crafthouse.dk",
                                            align: "left",
                                            type: 'text',
                                            rect: ['409px', '323px','227px','19px','auto', 'auto'],
                                            text: "© Crafthouse I/S 2013",
                                            align: "left",
                                            font: ['Oxygen, sans-serif', 14, "rgba(255,255,255,1.00)", "900", "none", "normal"]
                                            type: 'image',
                                            rect: ['409px', '213px','20px','20px','auto', 'auto'],
                                            fill: ["rgba(0,0,0,0)",im+"phone_logo.png",'0px','0px']
                                            type: 'image',
                                            rect: ['409px', '248px','20px','20px','auto', 'auto'],
                                            fill: ["rgba(0,0,0,0)",im+"mail_ikon.png",'0px','0px']
                                            type: 'rect',
                                            rect: ['1', '35','auto','auto','auto', 'auto'],
                                            cursor: ['pointer']
                                            type: 'rect',
                                            rect: ['1px', '241px','166px','1px','auto', 'auto'],
                                            fill: ["rgba(102,102,102,1.00)"],
                                            stroke: [0,"rgb(0, 0, 0)","none"]
                                            type: 'rect',
                                            rect: ['1px', '277px','166px','1px','auto', 'auto'],
                                            type: 'rect',
                                            rect: ['1px', '314px','166px','1px','auto', 'auto'],
                                            type: 'rect',
                                            rect: ['409px', '241px','166px','1px','auto', 'auto'],
                                            type: 'rect',
                                            rect: ['409px', '277px','166px','1px','auto', 'auto'],
                                            type: 'rect',
                                            rect: ['409px', '314px','166px','1px','auto', 'auto'],
                                            type: 'rect',
                                            rect: ['437px', '214px','1px','15px','auto', 'auto'],
                                            fill: ["rgba(71,71,71,1.00)"],
                                            type: 'rect',
                                            rect: ['437px', '250px','1px','15px','auto', 'auto'],
                                            type: 'image',
                                            rect: ['785px', '212px','43px','43px','auto', 'auto'],
                                            cursor: ['pointer'],
                                            fill: ["rgba(0,0,0,0)",im+"facebook_ikon_hover.png",'0px','0px']
                                            type: 'image',
                                            rect: ['851px', '212px','43px','43px','auto', 'auto'],
                                            fill: ["rgba(0,0,0,0)",im+"googleplus_ikon_hover.png",'0px','0px']
                                            type: 'image',
                                            rect: ['917px', '212px','43px','43px','auto', 'auto'],
                                            fill: ["rgba(0,0,0,0)",im+"footer_blog_icon.png",'0px','0px']
                                        symbolInstances: [
                                            symbolName: 'logo',
                                            autoPlay: {
                                            symbolName: 'homepage',
                                            autoPlay: {
                                states: {
                                    "Base State": {
                                        "${_Text4Copy6}": [
                                            ["style", "top", '249px'],
                                            ["style", "width", '131px'],
                                            ["style", "height", '19px'],
                                            ["color", "color", 'rgba(255,255,255,1.00)'],
                                            ["style", "font-family", 'Oxygen, sans-serif'],
                                            ["style", "left", '443px'],
                                            ["style", "font-size", '14px']
                                        "${_Text2Copy}": [
                                            ["style", "top", '163px'],
                                            ["style", "width", '186px'],
                                            ["style", "font-weight", '400'],
                                            ["style", "height", '31px'],
                                            ["style", "font-family", 'doppio-one, sans-serif'],
                                            ["style", "left", '409px'],
                                            ["style", "font-size", '16px']
                                        "${_googleplus_ikon_hover}": [
                                            ["style", "top", '212px'],
                                            ["style", "left", '851px'],
                                            ["style", "cursor", 'pointer']
                                        "${_Rectangle3Copy2}": [
                                            ["color", "background-color", 'rgba(102,102,102,1.00)'],
                                            ["style", "top", '314px']
                                        "${_Text2}": [
                                            ["style", "font-size", '16px'],
                                            ["style", "left", '0px'],
                                        "${_Text2Copy2}": [
                                            ["style", "height", '29px'],
                                            ["style", "left", '785px'],
                                            ["style", "width", '175px']
                                        "${_Rectangle4Copy}": [
                                            ["style", "top", '250px'],
                                            ["style", "height", '15px'],
                                            ["color", "background-color", 'rgba(71,71,71,1.00)'],
                                            ["style", "left", '437px'],
                                            ["style", "width", '1px']
                                        "${_Text4Copy}": [
                                        "${_Rectangle3Copy4}": [
                                            ["style", "top", '277px'],
                                        "${_Rectangle4}": [
                                            ["style", "top", '214px'],
                                        "${_Text4}": [
                                            ["style", "left", '1px'],
                                        "${_Text3}": [
                                            ["style", "top", '148px'],
                                            ["style", "font-size", '12px']
                                        "${_logo}": [
                                            ["style", "top", '47px'],
                                            ["style", "cursor", 'pointer'],
                                            ["transform", "scaleX", '1.0144']
                                        "${_Text4Copy9}": [
                                            ["style", "top", '287px'],
                                        "${_phone_logo}": [
                                            ["style", "top", '213px']
                                        "${_Rectangle3Copy3}": [
                                            ["style", "top", '314px'],
                                        "${_facebook_ikon_hover2}": [
                                        "${_footer_blog_icon}": [
                                            ["style", "left", '917px'],
                                        "${_Rectangle3Copy5}": [
                                            ["style", "top", '241px']
                                        "${_Rectangle3}": [
                                        "${_Rectangle3Copy}": [
                                        "${_Text4Copy4}": [
                                            ["style", "top", '323px'],
                                            ["style", "font-weight", '900'],
                                        "${_homepage}": [
                                        "${_Stage}": [
                                            ["color", "background-color", 'rgba(255,255,255,0.00)'],
                                            ["style", "width", '960px'],
                                            ["style", "height", '400px'],
                                            ["style", "overflow", 'hidden']
                                        "${_Text4Copy2}": [
                                            ["style", "top", '286px'],
                                        "${_Text4Copy7}": [
                                            ["style", "width", '109px'],
                                        "${_mail_ikon}": [
                                            ["style", "top", '248px']
                                timelines: {
                                    "Default Timeline": {
                                        fromState: "Base State",
                                        toState: "",
                                        duration: 0,
                                        autoPlay: true,
                                        timeline: [
                                            { id: "eid11", tween: [ "style", "${_Text2Copy}", "height", '31px', { fromValue: '31px'}], position: 0, duration: 0 },
                                            { id: "eid5", tween: [ "style", "${_Text2}", "height", '31px', { fromValue: '31px'}], position: 0, duration: 0 },
                                            { id: "eid42", tween: [ "style", "${_logo}", "top", '47px', { fromValue: '47px'}], position: 0, duration: 0 },
                                            { id: "eid6", tween: [ "style", "${_Text2}", "font-size", '16px', { fromValue: '16px'}], position: 0, duration: 0 },
                                            { id: "eid50", tween: [ "transform", "${_logo}", "scaleX", '1.0144', { fromValue: '1.0144'}], position: 0, duration: 0 },
                                            { id: "eid38", tween: [ "style", "${_Text2}", "top", '163px', { fromValue: '163px'}], position: 0, duration: 0 },
                                            { id: "eid66", tween: [ "style", "${_Text2Copy2}", "width", '175px', { fromValue: '175px'}], position: 0, duration: 0 },
                                            { id: "eid9", tween: [ "style", "${_Text2Copy}", "font-size", '16px', { fromValue: '16px'}], position: 0, duration: 0 },
                                            { id: "eid72", tween: [ "style", "${_Text2Copy2}", "top", '163px', { fromValue: '163px'}], position: 0, duration: 0 },
                                            { id: "eid51", tween: [ "style", "${_logo}", "left", '0px', { fromValue: '0px'}], position: 0, duration: 0 },
                                            { id: "eid67", tween: [ "style", "${_Text2Copy2}", "left", '785px', { fromValue: '785px'}], position: 0, duration: 0 },
                                            { id: "eid2", tween: [ "style", "${_Text2}", "left", '0px', { fromValue: '0px'}], position: 0, duration: 0 },
                                            { id: "eid20", tween: [ "style", "${_Text2Copy2}", "font-size", '16px', { fromValue: '16px'}], position: 0, duration: 0 },
                                            { id: "eid54", tween: [ "gradient", "${_Stage}", "background-image", [270,[['rgba(255,255,255,0.00)',0],['rgba(255,255,255,0.00)',100]]], { fromValue: [270,[['rgba(255,255,255,0.00)',0],['rgba(255,255,255,0.00)',100]]]}], position: 0, duration: 0 },
                                            { id: "eid64", tween: [ "style", "${_Text2Copy}", "top", '163px', { fromValue: '163px'}], position: 0, duration: 0 },
                                            { id: "eid13", tween: [ "style", "${_Text2Copy}", "width", '186px', { fromValue: '186px'}], position: 0, duration: 0 },
                                            { id: "eid55", tween: [ "color", "${_Stage}", "background-color", 'rgba(255,255,255,0.00)', { animationColorSpace: 'RGB', valueTemplate: undefined, fromValue: 'rgba(255,255,255,0.00)'}], position: 0, duration: 0 },
                                            { id: "eid22", tween: [ "color", "${_Text2Copy2}", "color", 'rgba(255,255,255,1.00)', { animationColorSpace: 'RGB', valueTemplate: undefined, fromValue: 'rgba(255,255,255,1.00)'}], position: 0, duration: 0 },
                                            { id: "eid18", tween: [ "color", "${_Text2}", "color", 'rgba(255,255,255,1.00)', { animationColorSpace: 'RGB', valueTemplate: undefined, fromValue: 'rgba(255,255,255,1.00)'}], position: 0, duration: 0 },
                                            { id: "eid62", tween: [ "style", "${_Text2Copy}", "left", '409px', { fromValue: '409px'}], position: 0, duration: 0 },
                                            { id: "eid17", tween: [ "color", "${_Text2Copy}", "color", 'rgba(255,255,255,1.00)', { animationColorSpace: 'RGB', valueTemplate: undefined, fromValue: 'rgba(255,255,255,1.00)'}], position: 0, duration: 0 },
                                            { id: "eid40", tween: [ "style", "${_Text2Copy2}", "height", '29px', { fromValue: '29px'}], position: 0, duration: 0 },
                                            { id: "eid4", tween: [ "style", "${_Text2}", "width", '186px', { fromValue: '186px'}], position: 0, duration: 0 }            ]
                            "logo": {
                                version: "3.0.0",
                                build: "3.0.0.322",
                                scaleToFit: "none",
                                content: {
                                        dom: [
                                                type: 'image',
                                                rect: ['0px', '0px', '200px', '80px', 'auto', 'auto'],
                                                fill: ['rgba(0,0,0,0)', 'images/logo_footer.png', '0px', '0px']
                                                type: 'image',
                                                rect: ['0', '0', '200px', '80px', 'auto', 'auto'],
                                                fill: ['rgba(0,0,0,0)', 'images/logo_footer_hover.png', '0px', '0px']
                                                rect: ['0px', '1px', '200px', '80px', 'auto', 'auto'],
                                                stroke: [0, 'rgb(0, 0, 0)', 'none'],
                                                type: 'rect',
                                                fill: ['rgba(192,192,192,1)']
                                        symbolInstances: [
                                states: {
                                    "Base State": {
                                        "${_wrapper}": [
                                            ["style", "opacity", '0']
                                        "${_logo_footer_hover}": [
                                        "${_logo_footer}": [
                                            ["style", "top", '0px']
                                        "${symbolSelector}": [
                                            ["style", "height", '80px'],
                                            ["style", "width", '200px']
                                timelines: {
                                        toState: "",
                                        duration: 500,
                                        autoPlay: false,
                                        timeline: [
                                            { id: "eid16", tween: [ "style", "${_logo_footer_hover}", "opacity", '1', { fromValue: '0'}], position: 0, duration: 500 }            ]
                            "homepage": {
                                version: "3.0.0",
                                build: "3.0.0.322",
                                scaleToFit: "none",
                                content: {
                                        dom: [
                                                rect: ['0px', '0px', '138px', '19px', 'auto', 'auto'],
                                                font: ['Oxygen, sans-serif', 14, 'rgba(255,255,255,1.00)', '900', 'none', 'normal'],
                                                text: 'www.crafthouse.dk',
                                                align: 'left',
                                                type: 'text'
                                        symbolInstances: [
                                states: {
                                    "Base State": {
                                        "${_Text4Copy3}": [
                                            ["style", "top", '0px'],
                                            ["style", "font-size", '14px'],
                                            ["color", "color", 'rgba(255,255,255,1)'],
                                            ["style", "width", '138px']
                                timelines: {
                                        toState: "",
                                        duration: 500,
                                        autoPlay: false,
                                        timeline: [
                                            { id: "eid45", tween: [ "color", "${_Text4Copy3}", "color", 'rgba(87,182,221,1.00)', { animationColorSpace: 'RGB', valueTemplate: undefined, fromValue: 'rgba(255,255,255,1)'}], position: 0, duration: 500 }            ]
                            Edge.registerCompositionDefn(compId, symbols, fonts, resources, opts);
                            * Adobe Edge DOM Ready Event Handler
                            $(window).ready(function() {
                                 Edge.launchComposition(compId);
                            })(jQuery, AdobeEdge, "footer");
                            footer_EdgeActions.js
                            * Adobe Edge Animate Composition Actions
                            * Edit this file with caution, being careful to preserve
                            * function signatures and comments starting with 'Edge' to maintain the
                            * ability to interact with these actions from within Adobe Edge Animate
                            var Composition = Edge.Composition, Symbol = Edge.Symbol; // aliases for commonly used Edge classes
                               //Edge symbol: 'stage'
                               (function(symbolName) {
                                  Symbol.bindElementAction(compId, symbolName, "${_facebook_ikon_hover2}", "click", function(sym, e) {
                                     // Navigate to a new URL in the current window
                                     // (replace "_self" with appropriate target attribute for a new window)
                                     window.open("https://www.facebook.com/pages/Mysoleshop/553274264767573?fref=ts", "_blank");
                                  //Edge binding end
                                  Symbol.bindElementAction(compId, symbolName, "${_googleplus_ikon_hover}", "click", function(sym, e) {
                                     window.open("https://plus.google.com/117807343087553474293/posts", "_blank");
                                  //Edge binding end
                                  Symbol.bindElementAction(compId, symbolName, "${_homepage}", "click", function(sym, e) {
                                     window.open("http://www.crafthouse.dk", "_blank");
                                  //Edge binding end
                                  Symbol.bindElementAction(compId, symbolName, "${_footer_blog_icon}", "click", function(sym, e) {
                                     window.open("http://www.mysoleshopblog.dk", "_blank");
                                  //Edge binding end
                               })("stage");
                               //Edge symbol end:'stage'
                               //Edge symbol: 'logo'
                                  Symbol.bindElementAction(compId, symbolName, "${_wrapper}", "click", function(sym, e) {
                                     // insert code for mouse click here
                                     window.open("http://www.mysoleshop.dk", "_top");
                                  //Edge binding end
                                  Symbol.bindElementAction(compId, symbolName, "${_wrapper}", "mouseover", function(sym, e) {
                                     // insert code to be run when the mouse hovers over the object
                                     sym.play();
                                  //Edge binding end
                                  Symbol.bindElementAction(compId, symbolName, "${_wrapper}", "mouseout", function(sym, e) {
                                     // insert code to be run when the mouse is moved off the object
                                     sym.playReverse();
                                  //Edge binding end
                               })("logo");
                               //Edge symbol end:'logo'
                               //Edge symbol: 'homepage'
                                  Symbol.bindElementAction(compId, symbolName, "${_Text4Copy3}", "mouseover", function(sym, e) {
                                     sym.play();
                                  //Edge binding end
                                  Symbol.bindElementAction(compId, symbolName, "${_Text4Copy3}", "mouseout", function(sym, e) {
                                     sym.playReverse();
                                  //Edge binding end
                               })("homepage");
                               //Edge symbol end:'homepage'
                            edge_edgePreload.js
                            * Adobe Edge Preloader
                            * Do Not Edit this file
                            window.AdobeEdge = window.AdobeEdge || {};
                            // Include yepnope
                            if(!AdobeEdge.yepnope) {
                            /*yepnope1.5.x|WTFPL*/
                            (function(a,b,c){function d(a){return"[object Function]"==o.call(a)}function e(a){return"string"==typeof a}function f(){}function g(a){return!a||"loaded"==a||"complete"==a||"uninitialized"==a}function h(){var a=p.shift();q=1,a?a.t?m(function(){("c"==a.t?B.injectCss:B.injectJs)(a.s,0,a.a,a.x,a.e,1) },0):(a(),h()):q=0}function i(a,c,d,e,f,i,j){function k(b){if(!o&&g(l.readyState)&&(u.r=o=1,!q&&h(),l.onload=l.onreadystatechange=null,b)){"img "!=a&&m(function(){t.removeChild(l)},50);for(var d in y[c])y[c].hasOwnProperty(d)&&y[c][d].onload()}}var j=j||B.errorTimeout,l=b.createElement(a),o=0,r=0,u={t:d,s:c,e:f,a:i,x:j};1===y[c]&&(r=1,y [c]=[]),"object"==a?l.data=c:(l.src=c,l.type=a),l.width=l.height="0",l.onerror=l.onload=l. onreadystatechange=function(){k.call(this,r)},p.splice(e,0,u),"img"!=a&&(r||2===y[c]?(t.in sertBefore(l,s?null:n),m(k,j)):y[c].push(l))}function j(a,b,c,d,f){return q=0,b=b||"j",e(a)?i("c"==b?v:u,a,b,this.i++,c,d,f):(p.splice(this.i++,0,a),1==p.length&&h ()),this}function k(){var a=B;return a.loader={load:j,i:0},a}var l=b.documentElement,m=a.setTimeout,n=b.getElementsByTagName("script")[0],o={}.toString,p= [],q=0,r="MozAppearance"in l.style,s=r&&!!b.createRange().compareNode,t=s?l:n.parentNode,l=a.opera&&"[object Opera]"==o.call(a.opera),l=!!b.attachEvent&&!l,u=r?"object":l?"script":"img",v=l?"script" :u,w=Array.isArray||function(a){return"[object Array]"==o.call(a)},x=[],y={},z={timeout:function(a,b){return b.length&&(a.timeout=b[0]),a}},A,B;B=function(a){function b(a){var a=a.split("!"),b=x.length,c=a.pop(),d=a.length,c={url:c,origUrl:c,prefixes:a},e,f,g;for(f =0;f<d;f++)g=a[f].split("="),(e=z[g.shift()])&&(c=e(c,g));for(f=0;f<b;f++)c=x[f](c);return c}function g(a,e,f,g,h){var i=b(a),j=i.autoCallback;i.url.split(".").pop().split("?").shift(),i.bypass||(e&&(e=d(e)?e :e[a]||e[g]||e[a.split("/").pop().split("?")[0]]),i.instead?i.instead(a,e,f,g,h):(y[i.url] ?i.noexec=!0:y[i.url]=1,f.load(i.url,i.forceCSS||!i.forceJS&&"css"==i.url.split(".").pop() .split("?").shift()?"c":c,i.noexec,i.attrs,i.timeout),(d(e)||d(j))&&f.load(function(){k(), e&&e(i.origUrl,h,g),j&&j(i.origUrl,h,g),y[i.url]=2})))}function h(a,b){function c(a,c){if(a){if(e(a))c||(j=function(){var a=[].slice.call(arguments);k.apply(this,a),l()}),g(a,j,b,0,h);else if(Object(a)===a)for(n in m=function(){var b=0,c;for(c in a)a.hasOwnProperty(c)&&b++;return b}(),a)a.hasOwnProperty(n)&&(!c&&!--m&&(d(j)?j=function(){var a=[].slice.call(arguments);k.apply(this,a),l()}:j[n]=function(a){return function(){var b=[].slice.call(arguments);a&&a.apply(this,b),l()}}(k[n])),g(a[n],j,b,n,h))}else!c&&l()}v ar h=!!a.test,i=a.load||a.both,j=a.callback||f,k=j,l=a.complete||f,m,n;c(h?a.yep:a.nope,!!i) ,i&&c(i)}var i,j,l=this.yepnope.loader;if(e(a))g(a,0,l,0);else if(w(a))for(i=0;i<a.length;i++)j=a[i],e(j)?g(j,0,l,0):w(j)?B(j):Object(j)===j&&h(j,l);els e Object(a)===a&&h(a,l)},B.addPrefix=function(a,b){z[a]=b},B.addFilter=function(a){x.push(a )},B.errorTimeout=1e4,null==b.readyState&&b.addEventListener&&(b.readyState="loading",b.ad dEventListener("DOMContentLoaded",A=function(){b.removeEventListener("DOMContentLoaded",A, 0),b.readyState="complete"},0)),a.yepnope=k(),a.yepnope.executeStack=h,a.yepnope.injectJs= function(a,c,d,e,i,j){var k=b.createElement("script"),l,o,e=e||B.errorTimeout;k.src=a;for(o in d)k.setAttribute(o,d[o]);c=j?h:c||f,k.onreadystatechange=k.onload=function(){!l&&g(k.read yState)&&(l=1,c(),k.onload=k.onreadystatechange=null)},m(function(){l||(l=1,c(1))},e),i?k. onload():n.parentNode.insertBefore(k,n)},a.yepnope.injectCss=function(a,c,d,e,g,i){var e=b.createElement("link"),j,c=i?h:c||f;e.href=a,e.rel="stylesheet",e.type="text/css";for( j in d)e.setAttribute(j,d[j]);g||(n.parentNode.insertBefore(e,n),m(c,0))}})(this,document);Ado beEdge.yepnope = window.yepnope;
                            // end yepnope
                            (function(compId){
                               var htFallbacks;
                            var testEle=document.createElement("div");function isSupported(a){var d=testEle.style,b;for(i=0;i<a.length;i++)if(b=a[i],void 0!==d[b])return!0;return!1}function supportsRGBA(){testEle.cssText="background-color:rgba(150,255,150,.5)";return 0==(""+testEle.style.backgroundColor).indexOf("rgba")?!0:!1}
                            var hasTransform=isSupported(["transformProperty","WebkitTransform","MozTransform","OTransfor m","msTransform"]),hasSVG=!!document.createElementNS&&!!document.createElementNS("http://www.w3.org/2000/svg","svg").createSVGRect,hasRGBA=supportsRGBA(),hasJSON=window.JSON&&window.JSON.parse&&wind ow.JSON.stringify,readyToPlay=!1;function safeColor(a){a=""+a;if(!hasRGBA&&0==a.indexOf("rgba")){var d=a.lastIndexOf(",");0<d&&(a="rgb("+a.substring(5,d)+")")}return a}
                            AdobeEdge._preloaders=AdobeEdge._preloaders||[];AdobeEdge._preloaders.push(function(){file sToLoad&&(loadResources(filesToLoad),filesToLoad=void 0)});function doLoadResources(){for(var a=0;a<AdobeEdge._preloaders.length;a++)AdobeEdge._preloaders[a]()}AdobeEdge._readyplayers =AdobeEdge._readyplayers||[];AdobeEdge._readyplayers.push(function(){readyToPlay&&AdobeEdg e.okToLaunchComposition(compId)});
                            function playWhenReady(){AdobeEdge._playWhenReady=!0;for(var a=0;a<AdobeEdge._readyplayers.length;a++)AdobeEdge._readyplayers[a]()}function edgeCallback(a,d,b){htFallbacks[a]&&(a=htFallbacks[a]);AdobeEdge.preload.got[a]=!0;a==Ado beEdge.preload.last&&(!AdobeEdge.bootstrapLoading||AdobeEdge._playWhenReady?AdobeEdge.okTo LaunchComposition(compId):readyToPlay=!0,AdobeEdge.preload.busy=!1,0<AdobeEdge.preload.q.l ength&&(a=AdobeEdge.preload.q.pop(),AdobeEdge.requestResources(a.files,a.callback)))}
                            AdobeEdge.requestResources=AdobeEdge.requestResources||function(a,d){AdobeEdge.yepnope.err orTimeout=4E3;AdobeEdge.preload.busy=!0;AdobeEdge.preload.got=AdobeEdge.preload.got||{};va r b,k=a.length,f=[],c;for(b=0;b<k;b++){c=a[b];if("string"===typeof c)0===c.indexOf("//")&&0===window.location.href.indexOf("file://")&&(c="http:"+c),url=c,c ={load:url};else if(c.load&&0===c.load.indexOf("//")&&0===window.location.href.indexOf("file://")&&(c.load ="http:"+c.load),url=c.yep||c.load,c.callback){var g=c.callback;
                            c.callback=function(a,b,c){g(a,b,c)&&d(a,b,c)}}c.callback||(c.callback=d);AdobeEdge.preloa d.got[url]||(f.push(c),AdobeEdge.preload.last=url)}f.length&&AdobeEdge.yepnope(f)};var filesToLoad,dlContent,preContent,doDelayLoad,signaledLoading,loadingEvt,requiresSVG,htLoo kup={},aLoader,aEffectors,plSTF,ctrPlS,minPlW,maxPlW,plHeight,plWidth;
                            function loadResources(a,d){AdobeEdge.preload=AdobeEdge.preload||[];AdobeEdge.preload.q=AdobeEdge. preload.q||[];d||!isCapable()?filesToLoad=a:AdobeEdge.preload.busy?AdobeEdge.preload.q.pus h({files:a,callback:edgeCallback}):AdobeEdge.requestResources(a,edgeCallback)}function splitUnits(a){var d={};d.num=parseFloat(a);"string"==typeof a&&(d.units=a.match(/[a-zA-Z%]+$/));d.units&&"object"==typeof d.units&&(d.units=d.units[0]);return d}
                            function defaultUnits(a){var d=a;"auto"!==a&&((a=splitUnits(a))&&a.units||(d+="px"));return d}function findNWC(a,d){if(-1!=String(a.className).indexOf(d))return a;for(var b=a.childNodes,k=0;k<b.length;k++){var f=findNWC(b[k],d);if(!1!=f)return f}return!1}function parent(a){return a.parentElement}function offset(a){a=a.getBoundingClientRect();return{left:a.left+window.pageXOffset,top:a.top+win dow.pageYOffset}}function width(a){return a.offsetWidth}function height(a){return a.offsetHeight}
                            function isWrapped(a){return/center-wrapper/.test(parent(a).className)}function wrapForStageScaling(a){if(!isWrapped(a)){var d=document.createElement("div"),b=document.createElement("div");d.className="flow-wrapper ";b.className="center-wrapper";d.style.width="1px";d.appendChild(b);parent(a).insertBefore (d,a);b.appendChild(a)}}
                            function bindPSS(a,d){if(!isWrapped(a)){var b=function(){var b=isWrapped(a),f=b?parent(parent(parent(a))):parent(a),c=width(f),g=height(f),h=width(a), n=height(a),m=window.innerHeight,e=1,l=a.style;(f="body"===f.nodeName.toLowerCase())&&(g=m );c=Math.round(c);g=Math.round(g);c/=h;g/=n;"both"===d?e=Math.min(c,g):"height"===d?e=g:"w idth"===d&&(e=c);void 0!==maxPlW&&(e=Math.min(e,parseInt(maxPlW,10)/h));void 0!==minPlW&&(e=Math.max(e,parseInt(minPlW,10)/h));g="scale("+e+")";l.transformOrigin="0 0";l.oTransformOrigin=
                            "0 0";l.msTransformOrigin="0 0";l.webkitTransformOrigin="0 0";l.mozTransformOrigin="0 0";l.oTransformOrigin="0 0";l.transform=g;l.oTransform=g;l.msTransform=g;l.webkitTransform=g;l.mozTransform=g;l.oT ransform=g;if(!f||b)parent(a).style.height=Math.round(n*e)+"px",parent(a).style.width=Math .round(h*e)+"px";b&&(b=parent(parent(a)),b.style.height=Math.round(n*e+offset(a).top-offse t(b).top))};wrapForStageScaling(a);window.addEventListener("resize",function(){b()});b()}}
                            function centerThePreloadStage(a,d){isWrapped(a)&&(a=parent(a));var b=a.style;/^both$|^horizontal$/.test(d)&&(b.position="absolute",b.marginLeft="auto",b.mar ginRight="auto",b.left="0",b.right="0");/^both$|^vertical$/.test(d)&&(b.position="absolute ",b.marginTop="auto",b.marginBottom="auto",b.top="0",b.bottom="0")}
                            function simpleContent(a,d,b){var k=document.getElementsByTagName("body")[0],f=b||findNWC(k,compId),c,g,h;f?"absolute"!=f.s tyle.position&&"relative"!=f.style.position&&(f.style.position="relative"):f=k;plHeight&&( f.style.height=plHeight);plWidth&&(f.style.width=plWidth);/^height$|^width$|^both$/.test(p lSTF)&&d&&!b&&bindPSS(f,plSTF);/^vertical$|^horizontal$|^both$/.test(ctrPlS)&&d&&!b&&cente rThePreloadStage(f,ctrPlS);for(var n=0;n<a.length;n++){b=a[n];"image"===b.type?(k=document.createElement("img"),
                            k.src=b.fill[1]):k=document.createElement("div");k.id=b.id;h=k.style;if("text"==b.type){if (c=b.font)c[0]&&""!==c[0]&&(h.fontFamily=c[0]),"object"!=typeof c[1]&&(c[1]=[c[1]]),c[1][1]||(c[1][1]="px"),c[1][0]&&""!==c[1][0]&&(h.fontSize=c[1][0]+c[ 1][1]),c[2]&&""!==c[2]&&(h.color=safeColor(c[2])),c[3]&&""!==c[3]&&(h.fontWeight=c[3]),c[4 ]&&""!==c[4]&&(h.textDecoration=b.font[4]),c[5]&&""!==c[5]&&(h.fontStyle=b.font[5]);b.alig n&&"auto"!=b.align&&(h.textAlign=b.align);b.position&&(h.position=b.position);
                            (!b.rect[2]||0>=b.rect[2])&&(!b.rect[3]||0>=b.rect[3])&&(h.whiteSpace="nowrap");k.innerHTM L=b.text}d&&(k.className=d);h.position="absolute";c=b.rect[0];g=b.rect[1];if(b.transform&& b.transform[0]){var m=b.transform[0][0],e=splitUnits(m);if(e&&e.units&&(m=e.num,"%"==e.units&&b.rect[2])){var e=b.rect[2],l=splitUnits(b.rect[2]);l&&l.units&&(e=l.num,"%"==l.units&&(e=e/100*f.offsetW idth));m=m/100*e;0<f.offsetWidth&&(m=m/f.offsetWidth*100)}if(e=splitUnits(c))c=e.num;c+=m; e.units||(e.units="px");c+=e.units;
                            if(1<b.transform[0].length){m=b.transform[0][1];(e=splitUnits(m))&&e.units&&(m=e.num,"%"== e.units&&b.rect[3]&&(e=b.rect[3],(l=splitUnits(b.rect[3]))&&l.units&&(e=l.num,"%"==l.units &&(e=e/100*f.offsetHeight)),m=m/100*e,0<f.offsetHeight&&(m=m/f.offsetHeight*100)));if(e=sp litUnits(g))g=e.num;g+=m;e.units||(e.units="px");g+=e.units}}h.left=defaultUnits(c);h.top= defaultUnits(g);h.width=defaultUnits(b.rect[2]);h.height=defaultUnits(b.rect[3]);b.linkURL &&(htLookup[k.id]=b,k.onclick=function(){var a=htLookup[this.id];
                            a.linkTarget?window.open(a.linkURL,a.linkTarget):window.location.href=a.linkURL},h.cursor= "pointer");f.appendChild(k);if(b.c)for(h=0;h<b.c.length;h++)simpleContent(b.c[h],d,k)}}var fnCycle=function(a){a?fnCycle&&setTimeout(fnCycle,20):a={event:"loading",progress:0};load ingEvt&&loadingEvt(a)},aBootcompsLoaded=[];window.AdobeEdge.bootstrapListeners||(window.Ad obeEdge.bootstrapListeners=[]);
                            window.AdobeEdge.bootstrapCallback=function(a){window.AdobeEdge.bootstrapListeners.push(a) ;if(0<aBootcompsLoaded.length)for(var d=0;d<aBootcompsLoaded.length;d++)a(aBootcompsLoaded[d])};window.AdobeEdge.preloadComplet e||(window.AdobeEdge.preloadComplete={});
                            window.AdobeEdge.preloadComplete[compId]=function(a){AdobeEdge.$_(".edgePreload"+a).css("d isplay","none");fnCycle=null;loadingEvt&&loadingEvt({event:"done",progress:1,reason:"compl ete"});aBootcompsLoaded.push(a);for(var d=window.AdobeEdge.bootstrapListeners.length,b=0;b<d;b++)try{window.AdobeEdge.bootstrapLi steners[b](a)}catch(k){console.log("bootstrap error "+k)}};function isCapable(){return hasTransform?requiresSVG&&!hasSVG?!1:!0:!1}
                            function onDocLoaded(a){window.AdobeEdge.loaded=!0;fnCycle({event:"begin"});isCapable()?(preConten t&&preContent.dom&&preContent.dom.length&&simpleContent(preContent.dom,"edgePreload"+compI d),filesToLoad&&!signaledLoading&&(loadResources(filesToLoad),filesToLoad=void 0)):dlContent&&dlContent.dom&&(loadingEvt&&loadingEvt({event:"done",progress:1,reason:"do wnlevel"}),simpleContent(dlContent.dom))};
                            window.AdobeEdge.framework = 'jquery';
                            if(document.addEventListener ){
                               window.addEventListener("load", onDocLoaded, false);
                            } else if ( document.attachEvent ) {
                               window.attachEvent("onload", onDocLoaded );
                               requiresSVG=false;
                               doDelayLoad=false;
                               htFallbacks={
                               aLoader = [
                                  { load: "edge_includes/jquery-2.0.3.min.js"},
                                  { load: "edge_includes/edge.3.0.0.min.js"},
                                  { load: "footer_edge.js"},
                                  { load: "footer_edgeActions.js"}];
                            if (AdobeEdge.bootstrapLoading) { signaledLoading = true; AdobeEdge.loadResources=doLoadResources; AdobeEdge.playWhenReady=playWhenReady; }
                            loadResources(aLoader, doDelayLoad);
                            var plSTF="none",ctrPlS="none",minPlW="0",maxPlW=undefined,plWidth="960px",plHeight="400px";
                            preContent={
                                dom: [
                                    type: 'image',
                                    tag: 'img',
                                    rect: ['370px', '191px','220px','19px','auto', 'auto'],
                                    fill: ["rgba(0,0,0,0)",'images/loader-bar.gif','0px','0px']
                                }]};//simpleContent
                            dlContent={dom: [ ]};//simpleContent
                            })( "footer");
                            • 11. Re: SEO and edge animate
                              Hi, Mikkel-
                              Sorry, I wasn't clear.  Can you please ZIP up all of your files and post a link for me to download it so that I can open it in Animate?
                              -Elaine
                              • 12. Re: SEO and edge animate
                                Hehe sorry:P
                                Where do you add a zip file in this forum><?
                                • 13. Re: SEO and edge animate
