SOLVED
How to restrict pdf printing on a condition
Avatar
Level 1
Hello,
We generate the pdf and distribute it to the user immediately. I've a business requirement to allow the user to print the pdf a maximum of 3 times. I was able to add the javascript to the pdf to make a webservice call that would keep a track of prints(by getting the pdf blessed by the livecycle readerextensions). Now, I've two questions :
1.How can I disable printing on the pdf document when max number of reprints is reached?
2.The pdf throws security warning when it makes the webservice call. Is there anyway to supress it?
Thanks in advance for the responses.
Feroz.
1 Accepted Solution
Avatar
Correct answer by
Employee
This can be achieved by protecting the documents via  Rights Management. Please see sample at http://help.adobe.com/en_US/livecycle/9.0/samples/SDKRightsManagementExternalAuthorization.html to restrict Print to only once.
Avatar
Correct answer by
Employee
Avatar
Level 1
Thanks Neerava. I tried compiling the project in the link you provided and I'm getting the following error:
build-project:
     [copy] Copying 1 file to C:\ExternalAuthorization 2\output
     [echo] ExternalAuthorization: C:\ExternalAuthorization 2\build.xml
    [javac] C:\ExternalAuthorization 2\build.xml:46: warning: 'includeantruntime' was not set, defaulting to build.syscl
asspath=last; set to false for repeatable builds
    [javac] Compiling 2 source files to C:\ExternalAuthorization 2\output
    [javac] warning: [options] bootstrap class path not set in conjunction with -source 1.5
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\BootstrapImpl.java:3: error: package
com.adobe.idp.dsc.component does not exist
    [javac] import com.adobe.idp.dsc.component.Bootstrap;
    [javac]                                   ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\BootstrapImpl.java:4: error: package
    [javac] import com.adobe.idp.dsc.component.BootstrapContext;
    [javac]                                   ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\BootstrapImpl.java:6: error: cannot
find symbol
    [javac] public class BootstrapImpl implements Bootstrap {
    [javac]                                       ^
    [javac]   symbol: class Bootstrap
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\BootstrapImpl.java:8: error: cannot
find symbol
    [javac]     private BootstrapContext m_ctx;
    [javac]             ^
    [javac]   symbol:   class BootstrapContext
    [javac]   location: class BootstrapImpl
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\BootstrapImpl.java:10: error: cannot
find symbol
    [javac]     public void setBootstrapContext(BootstrapContext aCtx) {
    [javac]                                     ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:3: error:
package com.adobe.edc.server.spi.authorization does not exist
    [javac] import com.adobe.edc.server.spi.authorization.*;
    [javac] ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:4: error:
package com.adobe.idp does not exist
    [javac] import com.adobe.idp.Context;
    [javac]                     ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:5: error:
package com.adobe.idp.dsc.clientsdk does not exist
    [javac] import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
    [javac]                                   ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:6: error:
package com.adobe.livecycle.rightsmanagement.client does not exist
    [javac] import com.adobe.livecycle.rightsmanagement.client.RightsManagementClient;
    [javac]                                                   ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:7: error:
    [javac] import com.adobe.livecycle.rightsmanagement.client.EventManager;
    [javac]                                                   ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:8: error:
package com.adobe.livecycle.rightsmanagement.client.infomodel does not exist
    [javac] import com.adobe.livecycle.rightsmanagement.client.infomodel.Event;
    [javac]                                                             ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:9: error:
    [javac] import com.adobe.livecycle.rightsmanagement.client.infomodel.EventSearchFilter;
    [javac]                                                             ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:19: error
: cannot find symbol
    [javac] public class PrintServiceSPISample implements ExternalAuthorizer
    [javac]                                               ^
    [javac]   symbol: class ExternalAuthorizer
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:21: error
    [javac]     private EventManager           _evt_manager = null;
    [javac]             ^
    [javac]   symbol:   class EventManager
    [javac]   location: class PrintServiceSPISample
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:22: error
    [javac]     private ServiceClientFactory   _sc_factory  = null;
    [javac]             ^
    [javac]   symbol:   class ServiceClientFactory
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:23: error
    [javac]     private RightsManagementClient _rm_client   = null;
    [javac]             ^
    [javac]   symbol:   class RightsManagementClient
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:25: error
    [javac]     public ExternalAuthPropertyDTO[] getProviderProperties()
    [javac]            ^
    [javac]   symbol:   class ExternalAuthPropertyDTO
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:30: error
    [javac]     public ExternalAuthResultDTO evaluate( ExternalAuthDTO auth_info )
    [javac]                                            ^
    [javac]   symbol:   class ExternalAuthDTO
    [javac]            ^
    [javac]   symbol:   class ExternalAuthResultDTO
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:27: error
    [javac]     return new ExternalAuthPropertyDTO[0];
    [javac]                ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:32: error
    [javac]     ExternalAuthResultDTO ret_val = new ExternalAuthResultDTO();
    [javac]     ^
    [javac]                                         ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:54: error
    [javac]         Context context = (Context)auth_info.getContext();
    [javac]         ^
    [javac]   symbol:   class Context
    [javac]                            ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:102: erro
r: cannot find symbol
    [javac]         EventSearchFilter print_search = new EventSearchFilter();
    [javac]         ^
    [javac]   symbol:   class EventSearchFilter
    [javac]                                              ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:118: erro
    [javac]         Event[] out_events = _evt_manager.searchForEvents( print_search, 10 );
    [javac]         ^
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:148: erro
    [javac]         _sc_factory  = ServiceClientFactory.createInstance();
    [javac]                        ^
    [javac]   symbol:   variable ServiceClientFactory
    [javac] C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java:149: erro
    [javac]         _rm_client   = new RightsManagementClient( _sc_factory );
    [javac]                            ^
    [javac] Note: C:\ExternalAuthorization 2\com\adobe\livecycle\samples\rightsmanagement\PrintServiceSPISample.java use
s or overrides a deprecated API.
    [javac] Note: Recompile with -Xlint:deprecation for details.
s unchecked or unsafe operations.
    [javac] Note: Recompile with -Xlint:unchecked for details.
    [javac] 29 errors
    [javac] 1 warning
BUILD FAILED
