OS 10.9.1
iMac 27-inch, Late 2009
AdobeFlashPlayerInstaller_12au_ltrosxd_aaa_aih.dmg
Install Adobe Flash Player Version 3.3.9.0 (3.3.9.0)
Safari Version 7.0.1 (9537.73.11)
Hi:
I keep getting the above error when attempting the installation. I used the uninstall program from Adobe, but when I try to reinstall the same error occurs. Any advice appreciated!
Thank you
Spotlight search “Flash Player.plugin” (Search “This Mac” and choose "Show All in Finder")
Right click the Plugin and select “Open Enclosing Folder” Trash the Flash Player.plugin and flashplayer.xpt files.
Go to: [user]/Library/Preferences.
Note: You'll need to hold the "Option" key when you click "Go" from the Finder menu to access the [user] Library:
Without the "Option" key
And WITH
Trash the Macromedia folder there.
Go to: Mac HD/Library/Application Support. Trash the Macromedia folder there.
Go to
...Copy link to clipboard
And WITH
Go to: Mac HD/Library/Preference Panes (not Preferences, but Preference Panes). Trash the Flash Player.prefpane file there.
Empty the trash.
Download the Flash Player (For Mac OS X) again if necessary.
Quit Safari and go to your downloads folder. Double click the DMG to “mount it”. (It's an old screenshot - Yours will be FP 12)
It will appear on your desktop and a small window will open.
Double click the installer. If you see a warning, click “Open” to let it run.
Click “I have read and agree… etc.” and click “Install”. Enter your password when asked.
You may see the following: click “Force Close All” if you do, and then click “Retry”.
The installer will run.
Choose your update preference, and click “Done”.
Open Safari again and click Safari>Preferences (Cmd+,)
Go to the Security tab. Make sure “Allow plug-ins” is checked.
Worked like a charm. Thanks for the great instructions!
