4 Replies Latest reply: Feb 2, 2014 2:09 PM by BSisson RSS
    How do I Section a form??
    BSisson Community Member
      My form is broken into logical sections.  I would like to break the PDF into the same sections, but currently the only breaks are PAGE breaks
      Page1
      -field1
      -field2
      -field3
      -field4
      Page2
      field
      field
      field
      I would LIKE to break it into logic sections that follow my form
      Page1
      -field1
      -field2
      -field3
      Subsection 1
      -field4
      Subsection 2
      Page2
      Subsectiom 3
      field
      field
      field
      Subsection 4
      The idea would be that if I needed to dissable an entire section, it would be easy as I could just act upon the section atributes rather than on each individual field -in- the subsection.
      Is there an easy way to do this in ACROBAT PRO XI?
      thanks
        • 1. Re: How do I Section a form??
          George_Johnson CommunityMVP
          You say you want to disable sections, but what exactly does that mean? Do you want to make the fields read-only, hide the fileds, make the fields and the underlying page contents disappear, or something else?
          • 2. Re: How do I Section a form??
            My form has sections already, grounds, heating, cooling, plumbing, etc....
            Occasionally, a section "Doesnt Apply" and I want to grey out, hide, dissable or otherwise skip the entire section.
            Since I must account for the worst case platform (reader) I can't hide entire sections, or use some of the other neat features.
            I could put a "Grey filled box" over the extire section if the "N/A" box was checked and make sure that I cleared all the checkboxes in that section as well.  Seems ineligant, but sometimes the simplist is the best.
            Any other ideas on how to "Skip" and entire section of a form?
            PS...glad to send you a copy of my "proof_of_concept" form...just PM me an email I can send a PDF to.
            • 3. Re: How do I Section a form??
              OK. This can be done fairly easily if yuo use a hierarchical naming system for you form fields. For example, prefix all of your fields in section 1 with "S1.", tso they have names like: "S1.cust_name", "S1.address", "S1.city", etc. You can then hide all of the fields in a group with a single line of JavaScript:
              // Hide all of the secition 1 fields
              getField("S1").display = display.hidden;
              If you include an opaque button to cover all of the section (e.g., set the background to white and make it read-only), you can hide the underlying page contents by doing:
              // Show the section 1 button
              getField("S1_cover").display = display.visible;
              In this case don't include the "S1." prefix.
              Do the same type of thing for the other sections. You can then set up a general function in a document-level JavaScript to show/hide any section, something like:
              function hideFormSection(section, hide) {
                  // Determine whether to show or hide the fields
                  var disp = hide ? display.hidden : display.visible;
                  // Dtermine whether to show of hide the cover button
                  var disp_cover = hide ? display.visible : display.hidden;
                  // Show/Hide the fields
                  getField(section).display = disp;
                  // Show/Hide the cover button
                  // Each section cover button is named: prefix + "_cover". Example: "S1_cover"
                  getField(section + "_cover").display = disp_cover;
              And you could call it like this:
              // Hide section 1
              hideFormSection("S1", true);
              // Show section 3
              hideFormSection("S3", false);
              • 4. Re: How do I Section a form??
                Wow that looks easy.
                I was already going to name my fields Checkbox.section.field_number.
                This is how I can build a summary very easily later, by looping through Section and Field Number and extracting the "Export Data" into a text field on the summary page.
                I already have some button-up scripts that make a fied required if they say they have a component.... I can just do something similar for the entire section and add a Text-box over it with a grey fill.  More stuff for my Proof-of-concept form.
                thanks.
