Windows 7, Firefox. I have tried to install an updated version of the flash player and I am getting the connection issues when it is downloading. I then try the 17 meg version and it stalls right at the end, eventually it finishes (or times out) and when I try to run it, it tells me I don't have a valid win-32 application. Thinking that my current version might have been corrupt, I uninstalled it using your instructions on the uninstall-flash-player page. I uninstalled, verified that it was uninstalled, but my install still isn't working. I have turned off my McAfee firewall, etc. Help!
Bypass the GUI downloader/installer
Use the FULL offline installer here: Flash Player 12.0.0.43 Plug-in (All other browsers)
Close Firefox and then run it.
Okay, I have done this but again the downloader gets to the end of the download and then pauses, and then finishes (times-out?) When I try to execute the file, it tells me I don't have a valid win-32 application. Is there something in firefox I need to change to let this download, or are there some Adobe files that need to be cleaned up prior to downloading.
Thanks for your help.
"Not a valid Win32 application" is almost ALWAYS a bad download. Usually cause by Antivirus deleting a portion of it because of poor or outdated definitions.
Disable your Antivirus completely (not just the firewall - the scan will delete things and corrupt them even with the firewall off - McAfee and Norton are the worst) and THEN download and install from that link.
OK - so I had two programs doing overlapping tasks - McAfee and YAC (Yet Another Cleaner). I disabled everything I could find for McAfee and uninstalled YAC (which I actually liked). Once I did these two things, I was able to download and run the installer. Thanks. Thought you might like to read some good news.
