Try this instead:
SELECT DISTINCT cbd.budgetId, bl.BudgetShortDescription
FROM dbo.ContractBudgetDistribution cbd
INNER JOIN dbo.BudgetList bl ON cbd.BudgetId = bl.BudgetID
ORDER BY LEFT(bl.BudgetShortDescription, 4) DESC,
HTH,
Carl
francois-yanick wrote:
> Hi everyone,
> I guest this is a very advanced question concerning
ORDER BY with an SQL query
> as I intend to have 2 type of order from the same table.
> Here it is: I have a table with 2 fiels:
> field 1 = BudgetShort Description which is a varchar and
it is unique
> field 2 = BudgetAmountAvailable wich is a float
> the field BudgetShortDescription is contain a structure
like this:
> [year].[program
area].[area].[project].[activity].[action].[task]
> e.g.: 2007.6.1.2.4.5.2
> it is long story to explain how this table is generated
but, in this issue, I
> need to use it where I would like to order by year DESC
(so 2007 will come
> first and than 2006, 2005, etc...). But, I also want to
order by the budget's
> structure (after the year) in an ascendant way so IU can
have 2007.6.1.2.4.5.2,
> 2007.6.1.2.4.5.3, 2007.6.1.2.4.5.4, etc...
> I thought about creating a first query (the one that
take the information from
> the table in the database) where I created a new
variable in my query:
> SELECT distinct dbo.ContractBudgetDistribution.budgetId,
> dbo.BudgetList.BudgetShortDescription AS
> LEFT(dbo.BudgetList.BudgetShortDescription, 4) AS
BudgetYear
> FROM dbo.ContractBudgetDistribution INNER JOIN
dbo.BudgetList ON
> dbo.ContractBudgetDistribution.BudgetId =
dbo.BudgetList.BudgetID
> ORDER BY BudgetYear DESC
> This work okay. But, after this, my idea was to go with
a query of a query,
> just like this:
> SELECT *
> FROM qGetBudgetList
> ORDER BY BUDGETSHORTDESCRIPTION
> But it is not doing what I want. Of course because the
system does not
> understand how to split such a same field. The solution
to add a new field in
> the table for the year still an option but the problem
will still the same as
> well as I still (a lot of still here) need to order in
two ways what I got.
> Any help will be appreciated here!
> Thank's
