Hi deidrelynn
Of course I'm not KCWebPlaza, but maybe I can help. For CD
distribution, you need a file present that is named quite simply
autorun.inf. When a Windows PC senses a CD-ROM has been
inserted, it normally looks for this file to start an application.
Keep in mind that this only works on Windows based PCs. I don't
believe it will work if the PC is an Apple or LInux machine.
Additionally, some administrators may disable the autorun function
because they see it as a security risk.
If you are using Captivate 1, only the .EXE output has the
option for creating the autorun.inf file. For Captivate 2, the
option exists for both .SWF and .EXE outputs.
If you are going down the autorun path, you should know or
realize that you need to be a tad persnickety with your naming
conventions. You should avoid using long file names for your
Captivate movie that launches initially. I've seen it happen
regularly where autorun is trying to launch something named perhaps
My Favorite Movie In the Whole world and it fails. But when that
movie is renamed to something like MyFavMov it begins working just
dandy. You are safest if you stick with something called "The DOS
8.3 naming convention". This means you use 8 characters for the
main part of the file name, and 3 characters for the file
extension. (normally the extension is either .SWF or .EXE, so you
are pretty safe there. All you need to worry about is really the 8
character File Name).
So once you have it all in one place, you simply copy the
group of files to the CD and you should be set.
Cheers... Rick
