The system has attempted to use an undefined value, which usually indicates a programming error, either in your code or some system code.
Null Pointers are another name for undefined values.
The error occurred inC:/ColdFusion10/cfusion/wwwroot/TESTONLINE/END.CFM: line 19 | |
17 : <cfcookie name = "cfid" 18 : value = "#Now()#" 19 : expires = "NOW"> 20 : <cfcookie name = "cftoken" 21 : expires = "NOW"> |
Please can any body help me out
Tayyab Hussain
Your code seems to span 5 lines, as follows:
You should rewrite it as:
<cfcookie name = "cfid" value = "#Now()#" expires = "NOW">
<cfcookie name = "cftoken" expires = "NOW">
Dear BKBK,
Still recieving the same error
Regards
Tayyab Hussain
At which line of code do you receive the error?
Hi again,
If you look at the main post the message received at line 19 which is Expires="now"
Regards
Tayyab
You should not be receiving that same error message. That is because the code is now as follows:
Line 17: <cfcookie name = "cfid" value = "#Now()#" expires = "NOW">
Line 18: <cfcookie name = "cftoken" expires = "NOW">
