1. Re: CRM Resources
Christopher L Rogers Feb 16, 2014 7:38 PM (in response to Webgroove)As far as I know the records created referencing the client will remain with the client as the clients Unique ID will be the key used in history to related these entries. Equally, the records recorded referencing the Company will remain with the Company as the Company's Unique ID will be the key that relates those data entries.
This being the case when a new owner is associated with an existing company you should be able to review all historical records for that Company and expect to see the records entered for both the old owner and the new owner.
However, those records that are related to the owner specifically will not be visible by looking at the company because those records are not related to the company but rather to the individual.
If you want data entires to be available regardless of company ownership then those entries should be added to the Company rather than the client (individual) then all records will be available by looking at the company's history.
If you want the data entry to be related to the client only then add those entires to the client (individual) and they will be available by looking up the cleint's history.
Hope this helps in some small way!
Cheers,
Christopher L. Rogers
Quantum Leap OBS LLC.
