1. Re: Forms fields changing them-selves?
GKaiseril Feb 4, 2014 12:36 PM (in response to BSisson)The value for a check box or radio button group that has no selection is "Off" so that value should not be be entered through the options window.
2. Re: Forms fields changing them-selves?
BSisson Feb 4, 2014 1:21 PM (in response to GKaiseril)Uhm... that might account for some strangeness, but it seems random
I have two cases I need to account for
1- Value doesn't matter
Had been using (Off) as the Export Value (.value) field entry. These are the field that are being flakey.
2 - Value DOES matter
Has a text Field "This is the text for button #x"
Where ".value" has text typed in it is stable.
I need something that I can put into the Export Value (.value) field that I can realiably count on so that if the Checkbox -IS- selected -AND- the field is that particular value I can skip it. Can I use "N/A" or "null (the word null)"
3. Re: Forms fields changing them-selves?
George_Johnson Feb 4, 2014 2:07 PM (in response to BSisson)You can use whatever you want for the export value of a check box, but you should not use "Off". In code, you can determine whether a check box is selected by comparing its value to "Off". If it is "Off" then the check box is not selected.
A field value cannot be equal to the special value of null. Comparing a check box field value to the string "N/A" would only make sense if that's what you set the export value to.
4. Re: Forms fields changing them-selves?
BSisson Feb 4, 2014 2:47 PM (in response to George_Johnson)Yup...found that out the hard way.
Ended up having to use a DOUBLE test because I have lots of checkboxes that aren't used for anything but "show"
Had to use Button.isBoxChecked && Button.value != "NA"
and THEN I had to worry about javascript precident in that if the first value is TRUE it doesn't evaluate the second.... so I had to re-order some of my tests...
Once I got rid of the "Off" which behaves like a reserved word -AND- got my logic clean, things started behaving.
