7 Replies Latest reply: Feb 5, 2014 5:11 PM by SOLpubs RSS
    Cross-refs, images in FM inset broken/missing in RH output
    SOLpubs Community Member
      TCS 4
      Linked FrameMaker book
      HTML Help output
      In several FM text insets, I have added a cross-reference to a topic outside of the inset.
      In the HTML Help output from RoboHelp, some (but not all) of the cross references are broken--they look like links, but the cursor does not change to a pointing finger and no jump occurs when you click.
      And although the FM "Heading & Page" cross-refs are set to convert to <$paratext> in RH, the broken HTML Help links retain the "on page x" part of the FM style. Again, other cross-refs in the insets convert correctly and are active. Even within the same inset, some cross-refs convert correctly, and some don't.
      Finally, I have some FM insets that have table cells with images in anchored frames (toolbar buttons with descriptions). The images are missing in the HTML Help output.
      Are these cross-ref and image issues fixable, or is this a limitation of the FM --> RH integration?
      Thanks.
