I just downloaded Reader XI this morning, and it said to changes the update preferences after installation. I have a MiFi with a VERY limited data cap & need everything on MANUAL update.
I've been thru Properties (right click on icon) and scoured the FAQS. Anybody know where I can change the automatic update preference, PLEASE?!?!?!
Frank
Wow - re-searching as a logged in user, I found my answer! THANKS STEVE CORDERO!
Steve Cordero, Oct 30, 2013 12:46 PM in reply to Starship Report
Go to the Edit menu
At the bottom of the Edit menu there is a menu item named "Preferences"
Select the "Preferences" menu item
A window with the name "Preferences" at the top will appear
On the left side of the "Preferences" window there will be a window pane named "Catagories"
Scroll all the way down until you see the list item named "Updater"
Select the "Updater" item
In the right side of the "Preferences" window the content will change.
You will have the option to turn OFF the updater
Select it
Click the OK button at the bottom of the "Preferences" window
