First time I tried this tag CFPDF to create images of each pages.
But, the quality result is fully unacceptable. Bad images, and text unreadable.
Loosing time. Why creating such tags ?
I am using CF v9.
Is there progress in next version ?
or is there someting which can be done to get the Quality ?
Also the scale at 100, is very small compared to original PDF.
it seems it does 50% at 100 scale ?
Thanks for any help.
I am vey desapointed.
(last message I have seen in the forum date of 2010, so I post this new)
Pierre.
You are using the hires option, right?
The scale issue is pretty well known, I think, not sure if there's a solution to that.
Rumor has it that ColdFusion 11 (release date unknown) has a completely revamped PDF generation.
Also, you could try using an external Java Class such as IcePDF.
http://www.painintheapps.com/2012/11/icepdf-alternative-to-cfpdf-for-high.html might help you quite a bit.
Thanks for your answer, I will look at that link.
I finaly used this UDF : http://pastebin.com/6gmmBT6U
And it is much better. It probably use the same technic as the proposed link.
I am running CF9
i will also see in the Railo side and CFML open source in coming weeks.
