I can not install my version of Presenter 7 on my PC which now uses window 8
The message is "Power Point can not be detected..."
Can someone explain how to solve this problem please.
Presenter 7 is a 32 bit application and could be installed with PPT 03 and 07. If you have Presenter 7.0.7, I believe it does support PPT 2010, but PPT 2013 (Office365) is not supported.
http://www.adobe.com/support/documentation/en/presenter/releasenotes.html
What version of PPT are you using?
Power Point 2013 ! ! !
Never mind.
Looks like it is time to upgrade to a newer version of Presenter!
Of course,
Being now retired from active research, updating Presenter 7 and Acrobat pro 9, is just too expensive to be justifiable.
I will just have to manage.
Thanks for you help.
Stephen William Rowe CEng FIET FSEE
If you still have an older version of PPT, installing that may solve the problem for now.
I still have Office 2007, will this work with windows 8 ?
I can at least try.
Thanks for your help.
I'm running Office 07 on Windows 8.1 with no issue.
Should work for you as well.
