I can't install Flash. It says I don't have permission yet I signed on as administrator using both exployer and Fire fox. I have also enabled script
Right click the installer, and choose "Run as Administrator".
Sometimes you need to do this, even if you're logged on as an admin.
Nope.
tried it.
It still says "user doesn't have sufficient privileges to run adobe Flash"
Thanks anyway
Do a "Clean Install"
http://forums.adobe.com/message/4041846
Usually Windows has changed permissions on the System32 or SysWOW64 folder and that causes it.
YES !
That worked !
CLEAN INSTALL !
Peter
