Save image path to MySQL and store file
Oct 07, 2011 Oct 07, 2011
Hi there,
I have a form that saves data to a MySQL db. In this form there are four input type file to upload images.
Everything is made with the Dreamweaver wizard.
What I need to do is to store the file path into MySQL and the file into a folder of the website.
I assume that I need to change in GetSQLValueString($_POST['variable'], "text"), but I don't know how to do it.
Anyone can help???
Thank you VERY mcuh
Jaume
Server side applications
43.1K
LEGEND , Oct 14, 2011 Oct 14, 2011
Can this be done with dreamweaver????
That is not the question.  You should ask "Can this be done with PHP", and the answer is yes, sure.  Google "PHP image resize" - you'll find lots....
Oct 10, 2011 Oct 10, 2011
Hi Jaume,
I can't claim credit for this - I got it from here
So want you want to do is upload an image, saving the image itself within your site and the image name in your database.
I haven't figured a way to do this in Dreamweaver wizards, without amending the code, but it's quite straightforward.
Assuming you have a form for people to upload an image, and a new folder within your 'images' folder named 'uploads'...
Using the Dreamweaver server behaviours will have added loads of hidden code to the top of your page, so you need to use the 'code' view to see this (or 'split' if you'd prefer to see both code and design views).
On your form page (mine's called add.php), within the code at the very top of your page which will begin with <?php
and end with
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
Add in the following code:
$target = "../images/uploads/";  //This is the directory where images will be saved//
$target = $target . basename( $_FILES['image']['name']);   //change the image and name to whatever your database fields are called//
Your Dreamweaver wizard will have created the $_POST details needed for each field.  You need to change the one related to your image to a $_FILES rather than $_POST - look for the line that says something like this (depending on your fields):
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form1")) {
  $insertSQL = sprintf("INSERT INTO database_name (name, Product_No, image) VALUES (%s, %s, %s)",
                       GetSQLValueString($_POST['Name'], "text"),
                       GetSQLValueString($_POST['Product_No'], "text"),
                       GetSQLValueString($_POST['image'], "text"));
And change the last line to this:
GetSQLValueString($_FILES['image']['name'], "text"));
That tells the form to insert the file to a specified location, and to insert the image's name - as text - into the database.  Now you need to specifiy the location:
  //This code writes the photo to the server//
if(move_uploaded_file($_FILES['image']['tmp_name'], $target))
//And confirms it has worked//
echo "The file ". basename( $_FILES['uploadedfile']['name']). " has been uploaded, and your information has been added to the directory";
else {
//Gives error if not correct//
echo "Sorry, there was a problem uploading your file.";
So your amended php will now look like this:
else {
Now in your HTML within the form, your code should look something like this:
<label for="image">Image</label>
      <input name="image" type="file" id="image" value="<?php echo $row_add['image']; ?>" />
    </p>
    <p>
      <input type="Submit" name="Add" id="add" value="Add" />
      <input type="hidden" name="MM_insert" value="form1" />
  </form>
To display the uploaded images on your website, just put in the location and echo the image field, remembering your ALT tag:
<img src="images/uploads/<?php echo $row_get['image']; ?>" alt="<?php echo $row_get['name']; ?>" /></a>
Good luck!
Oct 11, 2011 Oct 11, 2011
Becca, thank you very much!!!
I have some problems though, maybe you can help me 😉
I don't know where to place the
$target = "../images/uploads/";  //This is the directory where images will be saved// $target = $target . basename( $_FILES['image']['name']);   //change the image and name to whatever your database fields are called//
I think everything else I understand quite well.
I copy the code here so maybe you can have al look to it.
Thank you once again
Jaume.
<?php require_once('Connections/Conexion1.php'); ?>
<?php
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
  if (PHP_VERSION < 6) {
    $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
  $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch ($theType) {
    case "text":
      $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
      break;
    case "long":
    case "int":
      $theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case "double":
      $theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case "date":
      break;
    case "defined":
      $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
      break;
  return $theValue;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
  $editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_update"])) && ($_POST["MM_update"] == "UpdateForm")) {
  $updateSQL = sprintf("UPDATE detailsmachines SET Hours=%s, StateCons=%s, Accesory1=%s, Accesory2=%s, Accesory3=%s, Image1=%s, Image2=%s, Image3=%s, Image4=%s WHERE ID=%s",
                       GetSQLValueString($_POST['HoursEdit'], "int"),
                       GetSQLValueString($_POST['State'], "text"),
                       GetSQLValueString($_POST['Accesory1'], "text"),
                       GetSQLValueString($_POST['Accesory2'], "text"),
                       GetSQLValueString($_POST['Accesory3'], "text"),
                       GetSQLValueString($_POST['Image1'], "text"),
                       GetSQLValueString($_POST['Image2'], "text"),
                       GetSQLValueString($_POST['Image3'], "text"),
                       GetSQLValueString($_POST['Image4'], "text"),
                       GetSQLValueString($_POST['id'], "int"));
  mysql_select_db($database_Conexion1, $Conexion1);
  $Result1 = mysql_query($updateSQL, $Conexion1) or die(mysql_error());
  $updateGoTo = "Message Pages/Thanks.html";
    $updateGoTo .= (strpos($updateGoTo, '?')) ? "&" : "?";
    $updateGoTo .= $_SERVER['QUERY_STRING'];
  header(sprintf("Location: %s", $updateGoTo));
$colname_DetailRS1 = "-1";
if (isset($_GET['recordID'])) {
  $colname_DetailRS1 = $_GET['recordID'];
$query_DetailRS1 = sprintf("SELECT * FROM detailsmachines WHERE ID = %s", GetSQLValueString($colname_DetailRS1, "int"));
$DetailRS1 = mysql_query($query_DetailRS1, $Conexion1) or die(mysql_error());
$row_DetailRS1 = mysql_fetch_assoc($DetailRS1);
$totalRows_DetailRS1 = mysql_num_rows($DetailRS1);
?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
</head>
<body>
<form action="<?php echo $editFormAction; ?>" method="POST" enctype="multipart/form-data" name="UpdateForm" id="UpdateForm">
  <p>
    <label for="id"></label>
    <input name="id" type="hidden" id="id" value="<?php echo $row_DetailRS1['ID']; ?>" />
  </p>
  <table border="1" align="center">
    <tr>
      <td>Family</td>
      <td><?php echo $row_DetailRS1['Family']; ?></td>
    </tr>
    <tr>
      <td>Chasis</td>
      <td><?php echo $row_DetailRS1['Chasis']; ?></td>
    </tr>
    <tr>
      <td>Model</td>
      <td><?php echo $row_DetailRS1['Model']; ?></td>
    </tr>
    <tr>
      <td>Price</td>
      <td><?php echo $row_DetailRS1['Price']; ?></td>
    </tr>
    <tr>
      <td>Hours</td>
      <td><label for="HoursEdit"></label>
        <label for="HoursEdit2"></label>
      <input name="HoursEdit" type="text" id="HoursEdit2" value="<?php echo $row_DetailRS1['Hours']; ?>" /></td>
    </tr>
    <tr>
      <td>Warehouse</td>
      <td><?php echo $row_DetailRS1['Warehouse']; ?></td>
    </tr>
    <tr>
      <td>StateCons</td>
      <td><label for="State"></label>
      <input name="State" type="text" id="State" value="<?php echo $row_DetailRS1['StateCons']; ?>" /></td>
    </tr>
    <tr>
      <td>Accesory1</td>
      <td><label for="Accesory1"></label>
      <input name="Accesory1" type="text" id="Accesory1" value="<?php echo $row_DetailRS1['Accesory1']; ?>" /></td>
    </tr>
    <tr>
      <td>Accesory2</td>
      <td><input name="Accesory2" type="text" id="Accesory2" value="<?php echo $row_DetailRS1['Accesory2']; ?>" /></td>
    </tr>
    <tr>
      <td>Accesory3</td>
      <td><input name="Accesory3" type="text" id="Accesory3" value="<?php echo $row_DetailRS1['Accesory3']; ?>" /></td>
    </tr>
    <tr>
      <td>Accesory4</td>
      <td><input name="Accesory4" type="text" id="Accesory4" value="<?php echo $row_DetailRS1['Accesory4']; ?>" /></td>
    </tr>
    <tr>
      <td>Image1</td>
      <td><label for="Image1"></label><input name="Image1" type="file" id="Image1" value="<?php $row_DetailRS1['Image1']->file_src_pathname; ?>"/>
      </td>
    </tr>
    <tr>
      <td>Image2</td>
      <td><label for="Image2"></label>
      <input name="Image2" type="file" id="Image2" value="<?php echo $row_DetailRS1['Image2']; ?>" /></td>
    </tr>
    <tr>
      <td>Image3</td>
      <td><label for="Image3"></label>
      <input name="Image3" type="file" id="Image3" value="<?php echo $row_DetailRS1['Image3']; ?>" /></td>
    </tr>
    <tr>
      <td>Image4</td>
      <td><label for="Image4"></label>
      <input name="Image4" type="file" id="Image4" value="<?php echo $row_DetailRS1['Image4']; ?>" /></td>
    </tr>
  </table>
  <p align="center">
    <input type="submit" name="Submit" id="Submit" value="Update" />
  </p>
  <input type="hidden" name="MM_update" value="UpdateForm" />
</form>
<p> </p>
</body>
</html><?php
mysql_free_result($DetailRS1);
Hi Jaume,
The $target bit on mine is inbetween the $editFormAction  and the if ((isst... To be honest I don't know that it matters where it goes, but it works there on mine!
So that bit of code would look like this:
If it has worked, you'll end up with just the image's name (eg image.jpg) in your database field and the image file itself within your Dreamweaver site's images folder.
Advocate ,
Oct 12, 2011 Oct 12, 2011
Just for something to think about, I've always been divided/uncertain if saving the path with the filename is the best way to go. If anything, I think I would at least store the filename in a separate column. The reason being that often, you don't always know where the page will be that will eventually link to the file and document relative links then may not work.
The path can be added to the image source string at any time - either as a static or dynamic value.
I would never store the pathname like that.  Just add it in the static HTML on the page.
Oct 13, 2011 Oct 13, 2011
Thank you Lon and Murray for your comments.
I'd like to know, though, how would you do it.
My website is a "used machine info" site. I would like to show the machines we have for sale with 4 pics and a table with the specs of each one.
It is generated dynamically, so when I pick one it shows the details.
There is also an admin panel where the staff can upload the pics.
I thought it would be hard to store the pic in the MySQL so I decided to upload the file to ther server and save the path in the db.
What do you think???
Is there any other way to do it??
how about a flickr API?
Once again thankl you VERY much for all your help
Jaume
I think this is the right way to do it, except just save the image NAME - put the path in the static HTML, e.g.,
<img src="path_to_the_image_location/<?php echo $image_file_name; ?>"
That way if you ever change the image location, you only have to change that one line not every record in the database.
Advocate ,
And, to go fully not state the obvious, the image file name value will come from a recordset in most situations.
One way to do it if you're working with a detail page for example, is to create the recordset as you normally would for a detail page, using the unique recordID that's passed from the master page. Insert an image placeholder and for the source, click the lightning bolt icon for dynamic data and select the image file name column from the recordset. Then add the path in manually so it ends up like what Murray posted.
The image placeholder will also add height and width attributes that default to 32x32. So if all the images are the same size, change the attributes accordingly. If they're not the same size, and here's something I should know - will removing those attributes altogether just display the image in it's native dimensions?
Yes.  If the various images are going to have different dimensions, then you will either have to also store the dimensions in the database, or just remove them from the image tag altogether as you have suggested. You can also use PHP to get the image's dimensions, but that seems like a long walk around the park for this purpose.
Advocate ,
Then comes the issue of what the dimensions of the images actually are. Going back to the top of the thread, they are user uploaded images, so that means they can come in just about any size and resolution. So the uploading process should also include resizing to a maximum width and/or height.
Certainly - always.
Gentelmen, thanks a lot again!!
I haven't realized about what Lon says. And it is ABSOLUTELY true.
I will need to resize the big images to a certain size.
Any ideas?
Jaume
Oct 16, 2011 Oct 16, 2011
Oct 17, 2011 Oct 17, 2011
VERY nice but expensive 😞
Thank you VERY much anyway!!!
Yes if this is the only time you are going to do that I'm agreeing with you, it is very expensive. But for a regular webdesigner I don't think it is worth to spend days to find a solution on the internet expecially when you have to face situations like that many times and any time with different details, if it is true that "time is money" it would be much more expensive to spend weeks or months to find a solution that you could have at your finger tips. After all regular webdesigners don't love coding.
Of course I don't know your state so, in one way such a solution may be expensive on the other way it is not, but that was just a suggestion.
Thanks to you
You are right plus the library is AWESOME!!!!!!!
Shame I do this just for once.
Thanks for the tip 😉
Jaume
Feb 07, 2013 Feb 07, 2013
Hi, sorry for my english, my english is very bad
My code, as the code is exposed:
// Variables
# Definiendo la carpeta #
$target = "productos/";
# Definiendo la variable IMAGEN #
$mat_img = $_FILES['mat_img']['name'];
# Haciendo que funcione! #
$target = $target . basename( $_FILES['mat_img']['name']);
// Insert dreamweaver
// change $_FILES['mat_img']['name'], "text"),
GetSQLValueString($_FILES['mat_img']['name'], "text"),
// And finish
if(move_uploaded_file($_FILES['mat_img']['tmp_name'], $target))
mysql_select_db($database_adis, $adis);
# Ejectutar la consulta para insertar! #
  $Result1 = mysql_query($insertSQL, $adis) or die(mysql_error());
  $insertGoTo = "bien.php";
    $insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
    $insertGoTo .= $_SERVER['QUERY_STRING'];
  header(sprintf("Location: %s", $insertGoTo));
# Si todo salio exito!, mostar mensaje! #
echo "The file ". basename( $_FILES['mat_img']['name']). " has been uploaded, and your information has been added to the directory";
else {
# Y si no, mostrar un mensaje! #
// Code Complete
<?php
  switch ($theType) {
    case "text":
      break;
    case "long":
    case "int":
      break;
    case "double":
      break;
    case "date":
      break;
    case "defined":
      break;
  return $theValue;
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form")) {
  $insertSQL = sprintf("INSERT INTO material (mat_tipo, mat_fecha, mat_numero, mat_codigo, mat_deta1, mat_deta2, mat_img, idcolaborador, idciudad, idlocal, direccion, hora, costo, fechapanel, idestado) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
                       GetSQLValueString($_POST['mat_tipo'], "int"),
                       GetSQLValueString($_POST['mat_fecha'], "text"),
                       GetSQLValueString($_POST['mat_numero'], "text"),
                       GetSQLValueString($_POST['mat_codigo'], "text"),
                       GetSQLValueString($_POST['mat_deta1'], "text"),
                       GetSQLValueString($_POST['mat_deta2'], "text"),
                       GetSQLValueString($_POST['idcolaborador'], "int"),
                       GetSQLValueString($_POST['idciudad'], "int"),
                       GetSQLValueString($_POST['idlocal'], "int"),
                       GetSQLValueString($_POST['direccion'], "text"),
                       GetSQLValueString($_POST['hora'], "text"),
                       GetSQLValueString($_POST['costo'], "text"),
                       GetSQLValueString($_POST['fechapanel'], "text"),
                       GetSQLValueString($_POST['idestado'], "int"));
# Si todo salio OK, copiar la imagen a la carpeta definida #
else {
$query_disertante = "SELECT * FROM colaboradores";
$disertante = mysql_query($query_disertante, $adis) or die(mysql_error());
$row_disertante = mysql_fetch_assoc($disertante);
$totalRows_disertante = mysql_num_rows($disertante);
$query_ciudad = "SELECT * FROM ciudades";
$ciudad = mysql_query($query_ciudad, $adis) or die(mysql_error());
$row_ciudad = mysql_fetch_assoc($ciudad);
$totalRows_ciudad = mysql_num_rows($ciudad);
$query_locales = "SELECT * FROM locales";
$locales = mysql_query($query_locales, $adis) or die(mysql_error());
$row_locales = mysql_fetch_assoc($locales);
$totalRows_locales = mysql_num_rows($locales);
Hope you are useful!
Participant ,
Feb 09, 2014 Feb 09, 2014
Hello Goldbecca and ALL:
Please I need your assistance.
I followsed the procedues head to toll but my images are not uploading. Please could you go through and kindly advice. I have spent all night working on this but its not uploading to the upload folder inside the Image folder.
Here is the fiest part ofd the code on the same page
$target = "images/uploads/";  //This is the directory where images will be saved//
          $target = $target . basename( $_FILES['Projimg1']['name']);
          $target = $target . basename( $_FILES['Projimg2']['name']);
          $target = $target . basename( $_FILES['Projimg3']['name']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "submitpage")) {
  $insertSQL = sprintf("INSERT INTO tbl_projects (projcode, projname, projdesc, projdateentered, projcommunity, projlga, projstate, projcost, projtype, projbaselinedata, Projexpoutcome, adultmen, adultfem, totalchildren, totalben, projteamlead, projdepteamlead, projofficer, projliasonofficer, projmeeting1, projmeeting2, projmeeting3, projmousigndate, projstartdate, projenddate, Projdoc1, Projdoc2, Projdoc3, Projimg1, Projimg2, Projimg3) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
                       GetSQLValueString($_POST['projcode'], "text"),
                       GetSQLValueString($_POST['projname'], "text"),
                       GetSQLValueString($_POST['projdesc'], "text"),
                       GetSQLValueString($_POST['projdateentered'], "date"),
                       GetSQLValueString($_POST['projcommunity'], "text"),
                       GetSQLValueString($_POST['projlga'], "text"),
                       GetSQLValueString($_POST['projstate'], "text"),
                       GetSQLValueString($_POST['projcost'], "double"),
                       GetSQLValueString($_POST['projtype'], "text"),
                       GetSQLValueString($_POST['projbaselinedata'], "text"),
                       GetSQLValueString($_POST['Projexpoutcome'], "text"),
                       GetSQLValueString($_POST['adultmen'], "int"),
                       GetSQLValueString($_POST['adultfem'], "int"),
                       GetSQLValueString($_POST['totalchildren'], "int"),
                       GetSQLValueString($_POST['totalben'], "int"),
                       GetSQLValueString($_POST['projteamlead'], "text"),
                       GetSQLValueString($_POST['projdepteamlead'], "text"),
                       GetSQLValueString($_POST['projofficer'], "text"),
                       GetSQLValueString($_POST['projliasonofficer'], "text"),
                       GetSQLValueString($_POST['projmeeting1'], "date"),
                       GetSQLValueString($_POST['projmeeting2'], "date"),
                       GetSQLValueString($_POST['projmeeting3'], "date"),
                       GetSQLValueString($_POST['projmousigndate'], "date"),
                       GetSQLValueString($_POST['projstartdate'], "date"),
                       GetSQLValueString($_POST['projenddate'], "date"),
                       GetSQLValueString($_POST['Projdoc1'], "text"),
                       GetSQLValueString($_POST['Projdoc2'], "text"),
                       GetSQLValueString($_POST['Projdoc3'], "text"),
                       GetSQLValueString($_FILES['Projimg1']['name'], "text"),
                       GetSQLValueString($_FILES['Projimg2']['name'], "text"),
                       GetSQLValueString($_FILES['Projimg3']['name'], "text"));
  mysql_select_db($database_ProjMonEva, $ProjMonEva);
  $Result1 = mysql_query($insertSQL, $ProjMonEva) or die(mysql_error());
  $insertGoTo = "projects.php";
if(move_uploaded_file($_FILES['Projimg1']['tmp_name'], $target))
echo "The file ". basename( $_FILES['Projimg1']['name']). " has been uploaded, and your information has been added to the directory";
else {
if(move_uploaded_file($_FILES['Projimg2']['tmp_name'], $target))
echo "The file ". basename( $_FILES['Projimg2']['name']). " has been uploaded, and your information has been added to the directory";
else {
if(move_uploaded_file($_FILES['Projimg3']['tmp_name'], $target))
echo "The file ". basename( $_FILES['Projimg3']['name']). " has been uploaded, and your information has been added to the directory";
else {
and the second part on the same page
<fieldset>
      <legend>Review & Submit</legend>
      <form id="submitpage" name="submitpage" method="POST" action="<?php echo $editFormAction; ?>">
        <div align="center">
          <table width="500" border="0" cellspacing="0" cellpadding="0">
            <tr>
              <td colspan="2"><strong>Core  Project Details</strong></td>
            </tr>
            <tr id="rowlines">
              <td width="235"><p>Project Code:
                <input name="projcode" type="text" id="projcode" value="<?php echo $_POST['projcode']; ?>" />
              </p></td>
              <td width="265"><p>
                <label for="projcode"></label>
                Project Name:
                <input name="projname" type="text" id="projname" value="<?php echo $_POST['projname']; ?>" />
              </p></td>
            </tr>
            <tr id="rowlines">
              <td colspan="2"><p>Project Description:<span id="description"></span></p>                <p>
                  <label for="projdesc"></label>
                  <textarea name="projdesc" id="projdesc" cols="60" rows="8"><?php echo $_POST['projdesc']; ?></textarea>
              </p></td>
            </tr>
            <tr id="rowlines">
              <td><p>Project Year:
                <input name="projdateentered" type="text" id="projdateentered" value="<?php echo $_POST['projdateentered']; ?>" />
              </p></td>
              <td><p>Project LGA:
                <input name="projlga" type="text" id="projlga" value="<?php echo $_POST['projlga']; ?>" />
              </p></td>
            </tr>
            <tr id="rowlines">
              <td><p>Project Community:
                <input name="projcommunity" type="text" id="projcommunity" value="<?php echo $_POST['projcommunity']; ?>" />
              </p></td>
              <td><p>Project State:
                <input name="projstate" type="text" id="projstate" value="<?php echo $_POST['projstate']; ?>" />
              </p></td>
            </tr>
            <tr id="rowlines">
              <td colspan="2"><p>Project Baseline Data:</p>                <p>
                  <textarea name="projbaselinedata" id="projbaselinedata" cols="60" rows="8"><?php echo $_POST['projbaselinedata']; ?></textarea>
              </p></td>
            </tr>
            <tr id="rowlines">
              <td colspan="2"><p>Expected Outcome Of Project:</p>                <p>
                  <textarea name="Projexpoutcome" id="Projexpoutcome" cols="60" rows="8"><?php echo $_POST['Projexpoutcome']; ?></textarea>
              </p></td>
            </tr>
            <tr id="rowlines">
              <td><p>Project Cost:
                <input name="projcost" type="text" id="projcost" value="<?php echo $_POST['projcost']; ?>" />
              </p></td>
              <td><p>
                Project Type:
                  <input name="projtype" type="text" id="projtype" value="<?php echo $_POST['projtype']; ?>" />
              </p></td>
            </tr>
            <tr>
              <td colspan="2"><strong>Beneficiaries</strong></td>
            </tr>
            <tr id="rowlines">
              <td><p>Adult Men Beneficiaries:
                <input name="adultmen" type="text" id="adultmen" value="<?php echo $_POST['adultmen']; ?>" />
              </p></td>
              <td><p>Adult Female Beneficiaries:
                <input name="adultfem" type="text" id="adultfem" value="<?php echo $_POST['adultfem']; ?>" />
              </p></td>
            </tr>
            <tr id="rowlines">
              <td><p>Adult Children Beneficiaries:
                <input name="totalchildren" type="text" id="totalchildren" value="<?php echo $_POST['totalchildren']; ?>" />
              </p></td>
              <td><p>Total Beneficiaries:
                <input name="totalben" type="text" id="totalben" value="<?php echo $_POST['totalben']; ?>" readonly="readonly" />
              </p></td>
            </tr>
            <tr>
              <td colspan="2"><strong>Project Team</strong></td>
            </tr>
            <tr id="rowlines">
              <td><p>Project Team Leader:
                <input name="projteamlead" type="text" id="projteamlead" value="<?php echo $_POST['projteamlead']; ?>" />
              </p></td>
              <td><p>Deputy Team Leader:
                <input name="projdepteamlead" type="text" id="projdepteamlead" value="<?php echo $_POST['projdepteamlead']; ?>" />
              </p></td>
            </tr>
            <tr id="rowlines">
              <td><p>Project Officer:
                <input name="projofficer" type="text" id="projofficer" value="<?php echo $_POST['projofficer']; ?>" />
              </p></td>
              <td><p>Liason Officer:
                <input name="projliasonofficer" type="text" id="projliasonofficer" value="<?php echo $_POST['projliasonofficer']; ?>" />
              </p></td>
            </tr>
            <tr>
              <td colspan="2"><strong>Meeting Dates</strong></td>
            </tr>
            <tr id="rowlines">
              <td><p>First Project Meeting Date:
                <input name="projmeeting1" type="text" id="projmeeting1" value="<?php echo $_POST['projmeeting1']; ?>" />
              </p></td>
              <td><p>Third Project Meeting Date:
                <input name="projmeeting3" type="text" id="projmeeting3" value="<?php echo $_POST['projmeeting3']; ?>" />
              </p></td>
            </tr>
            <tr id="rowlines">
              <td><p>Second Project Meeting
              Date:
                  <input name="projmeeting2" type="text" id="projmeeting2" value="<?php echo $_POST['projmeeting2']; ?>" />
              </p></td>
              <td><p> </p></td>
            </tr>
            <tr>
              <td colspan="2"><strong>Other Dates</strong></td>
            </tr>
            <tr id="rowlines">
              <td><p>Project Start Date:
                  <label for="projstartdate"></label>
                  <input name="projstartdate" type="text" id="projstartdate" value="<?php echo $_POST['projstartdate']; ?>" />
              </p></td>
              <td><p>MoU Signing Date:
                <input name="projmousigndate" type="text" id="projmousigndate" value="<?php echo $_POST['projmousigndate']; ?>" />
              </p></td>
            </tr>
            <tr id="rowlines">
              <td><p>Project End Date:
                  <input name="projenddate" type="text" id="projenddate" value="<?php echo $_POST['projenddate']; ?>" />
              </p></td>
              <td><p> </p></td>
            </tr>
            <tr>
              <td> </td>
              <td> </td>
            </tr>
            <tr id="moredetails">
              <td colspan="2" id="moredetails"><strong>Upload Initial Project Documents/Pictures</strong></td>
            </tr>
            <tr>
              <td id="formcells"><p>Document/Picture One:
                <label for="Projdoc1"></label>
                <input type="file" name="Projdoc1" id="Projdoc1" />
              </p></td>
              <td id="formcells"><p>Document/Picture Four:
                <label for="Projimg1"></label>
                <input type="file" name="Projimg1" id="Projimg1" />
              </p></td>
            </tr>
            <tr>
              <td id="formcells"><p>Document/Picture Two:
                <label for="Projdoc2"></label>
                <input type="file" name="Projdoc2" id="Projdoc2" />
              </p></td>
              <td id="formcells"><p>Document/Picture Five:
                <label for="Projimg2"></label>
                <input type="file" name="Projimg2" id="Projimg2" />
              </p></td>
            </tr>
            <tr>
              <td id="formcells"><p>Document/Picture Three:
                <label for="Projdoc3"></label>
                <input type="file" name="Projdoc3" id="Projdoc3" />
              </p></td>
              <td id="formcells"><p>Document/Picture Six:
                <label for="Projimg3"></label>
                <input type="file" name="Projimg3" id="Projimg3" />
              </p></td>
            </tr>
            <tr>
              <td colspan="2"> </td>
            </tr>
          </table>
          <p>
            <input type="submit" name="btn_submit" id="btn_submit" value="Save & Submit" />
          </p>
        </div>
        <!-- end .content -->
        <input type="hidden" name="MM_insert" value="submitpage" />
      </form>
    </fieldset>
In the future, you should probably not reply to a 3 year old post and expect to get many replies - especially when that post was marked as 'Resolved'.
The first thing I noticed is that you have not set the correct enctype for file uploads.
You need to have the enctype="multipart/form-data" in your form tag. I haven't really looked further, there may be other problems.
Feb 10, 2014 Feb 10, 2014
1. Agreed. Amend the line:
to:
                <form id="submitpage" name="submitpage" method="POST" enctype="multipart/form-data" action="<?php echo $editFormAction; ?>">
2. Also, is this file in the same directory as your images folder? If not, this line won't work:
It needs to be relative to the path, or make it absolute (http://www.yoursite.com/images/uploads/)
3. I also think, and this was written so long ago that I can't really remember, the three lines relating to confirmation eg:
Should say:
           //Tells you if its all ok
Ie, I don't think you need the image field here, just the word 'uploadedfile'. Though I can't find where this would relate to so I could be wrong
Participant ,
Hi Goldbecca,
Thank you for your response.
I followed your corrections but the upload still did not go through. Just to be sure I did all things well, on this line
am I supposed to put the image path is double quote like this "http://localhost/projmoneva/images/uploads/" or should I just live it like this http://localhost/projmoneva/images/uploads/?
Thank you
Mik
I really don't know much about php, but I'd be surprised if a file based function like move_uploaded_file() works with an absolute url. Really, I think you are much better off referencing the document root:
target_path = $_SERVER['DOCUMENT_ROOT'] . "/uploads/" . basename( $_FILES['Projimg1']['name']).
Of course - you are populating a variable with a string.
What error message if any are you getting? Do you have error reporting enabled?
Participant ,
I am also having errors on lines
and this ones aswell
See image below
http://www.netdataflow.com/rbme/images/upload.gif
