5 Replies Latest reply: Feb 19, 2014 11:29 AM by PBWT id RSS
    AirHelp formatting
    PBWT id Community Member
      I have a published WebHelp site being hosted on SharePoint on the company intranet.  The goal is to publish a stand-alone version of the same project as an AirHelp application that can be easily accessed by having it pinned to the Windows 7 taskbar.  However, when the AirHelp App was published all of the topics lost their indentation at the left, such that they appeared as though the text started at the boundary separating the TOC from the actual topics.  In other words, there was no space buffer between the boundary and the text.  I consulted the Help Desk but they informed me that this was the difference in generated output.  The alternative was to create a duplicate project and re-format it so that the left margin was indented and looked appropriate in AirHelp.  I did that and it looks fine, but this raises a dilemma.  The help system is evolving, and so this would add to the amount of work if I had two duplicate projects that had to be updated each time a topic was added, modified, or deleted.  Is there a way around this so that I can use one project?  I am using RoboHelp 10.
      Thank You in advance for any feedback on this.
      Jason
        • 1. Re: AirHelp formatting
          Peter Grainge CommunityMVP
          Discussion moved to AIRHelp category.
          There is no need to create a duplicate project. Create a copy of your CSS file and rename it. MyStylesheetAIR.css for example.
          In the body tag add a margin. In your AIR Help layout, select that CSS to override the usual topic css.
          See AIR Help on my site.
          @petergrainge
          • 2. Re: AirHelp formatting
            Very cool, I can't thank you enough.  This worked out well.
            • 3. Re: AirHelp formatting
              Develop@11 Community Member
              I have run into another issue.  In my Air.css, which is exactly like my default.css except for the margins in the body tag, my numbered headings are now indented about an inch to the right.  I have checked the OL class and numerous other settings to no avail.  I cannot even tell the CSS to indent the left margin of the OL class negatively.  I'm not sure what could be causing this, the Web Help output looks good.  Thanks in advance for any clues.
              • 4. Re: AirHelp formatting
                ermphd Community Member
                Hello,
                I have read the dialog between you and Peter and his solution makes sense. The only Q I have is which version of the AIR run time are you using? If not current, update and see if it looks the same. I'd avoid fiddling with the classes and only do that as a last resort. Work on the CSS
                Cheers
                Ed Martino, PhD
                Instructional Designer
                • 5. Re: AirHelp formatting
                  Yes, the latest version is installed.  The CSS was the answer.
