3 Replies Latest reply: Feb 13, 2014 10:58 AM by BSisson RSS
    How do I grab the left 50 char of a field.
    BSisson Community Member
      I am trying to make "pretty" reports that wrap neatly.
      The Report consists of GeneralNotes.1..GeneralNotes.50
      I loop through all of my conditions, and when a section needs to have its ExportData move to the report I get the handles (getField) for the current line and the current line on the report.
      I copy one to the other, increment the line on the report and continue....
      This works fine....
      HOWEVER, if the lines are LONG, they get trunkated, shrunk in font, or something else.
      If the lines are long, I want to split the line into two pieces, and process them
      f is the current incomming report line  (field)to be processed
      s is the current line (field) on the report page
            if f.value.length > 70
               { var firstpart  = this.f.slice(0,70);       //this -SHOULD- be the first 70 char
                var leftover   = this.f.slice(71);          //this -SHOULD- be the remainder.
                s.value = firstpart.value;
                 position = position +1;
                 s = this.getField("GeneralNotes."+position);
                 f.value = leftover.value;
      //else
               {s.value = f.value;                                              //stuff Export value into currnet Summary field
      //continue with the rest of the loop stuff...
      The Real code works very well and builds a nice pretty report so long as f.value is less than 70 char long.
      I get no errors, -BUT- both lines on the report come out as "undefined" when the line is too long.
      Putting in some console.println statements the "slice" widget doesn't seem to be supported...or I am using it wrong....
      So the logic works.  The .length part works
      but the "slice" portion doesn't seem to work.
      The "slice" documentation I used came from w3school.com   http://www.w3schools.com/jsref/jsref_slice_string.asp
      Since this doesn't seem to be supported, is there another function or field widget I can use to split a 'field.value' into two pieces?
      Or can someone tell me where my syntax is wrong?
        • 1. Re: How do I grab the left 50 char of a field.
          George_Johnson CommunityMVP
          It seems to me it should be more like:
              if (f.valueAsString.length > 70) {
                  var firstpart = f.valueAsString.slice(0,70);       //this -SHOULD- be the first 70 char
                  var leftover = f.valueAsString.slice(71);          //this -SHOULD- be the remainder.
                  s.value = firstpart;
                  position += 1;
                  s = this.getField("GeneralNotes."+ position);
                  s.value = leftover;
              } else {
                  s.value = f.valueAsString;                              //stuff Export value into currnet Summary field
                  position += 1;
          • 2. Re: How do I grab the left 50 char of a field.
            GKaiseril CommunityMVP
            Maybe there is some other issue with your code.
            Variables do not have a value property. They only have a value.
            Have you tried adding some console.println statements to see what your code is doing and at what line it is failing?
            if (f.value.length > 70) {
                    console.show();
                     console.clear();
                     console.println("length: " + f.value.length);
                     console.println("firstpart: " + firstpart);
                       console.println(("leftover: " + leftover);
                       console.println("set field value to " + firstpart.value);
                      } else {
            • 3. Re: How do I grab the left 50 char of a field.
              Aha... the 'valueAsString' did it...
              There was one more "position = position +1" needed as it was over writing the 2nd line with the next entry, but that was my error.
              Now I have a summary form that builds its self conditionally from  750+ fields, and writs a nice summary that will nicely format response that are anywhere from 1-2 lines long.
