I opened an existing project to make an addition that the SME
wanted. It requires that I add a bit of audio (which works fine)
and a couple of highlight boxes to one slide. I added the highlight
boxes, set the timing and transparency, previewed in edit mode and
it works perfectly. If I preview the project the highlight boxes
will not show. I made sure they were not residing in the background
for some reason by bringing them to the front and made sure they
each had the fade in and out transition I wanted. I checked slide
properties, nothing there. So I deleted them and added them again.
No luck. I closed Captivate and reopened. No luck. I deleted them
again and replaced them with arrow animations. They won’t
show either, except in edit mode and they preview just fine there,
timing and all. I deleted them and replaced them with text boxes.
Still no luck, they don't show either, except in edit preview.
Everything I try is invisible in preview project mode, but okay in
the edit mode preview. All of this happens on one slide. The other
slides are fine.
Any ideas?
