FM11 hanging/crashing with FrameScript 5
Feb 11, 2014 Feb 11, 2014
Hi
My setup: FM11; Framescript 5.2 (5.2R1p251); Windows 7
FM11 is working fine ... but when l use FrameScript, the script runs OK until the end, then FM hangs for ages.
Eventually the FM file reopens but cannot be saved, scrolled .... and sometimes even shows only blank pages!!
Above applies to a file in a book, or a standalone file.
Tried an uninstall/reinstall of FrameScript but problem persists 😞
Anyone know a solution/workaround?
Would really appreciate any help!!
Mervyn
[Thread moved to FrameMaker Scripting Forum by moderator]
Scripting
699
Community Beginner , Feb 14, 2014 Feb 14, 2014
Thanks to all who replied to my question.
And to Rick Quatro for the prompt diagnosis!
I have been using the same script since 2005 (to produce linked callouts in a Parts Catalog).
Although nothing has changed in the script itself, the issue is apparently the behavior of FM11 in handling document display commands - which now necessitates changes the script (actually, a set of them).
Rick writes: They changed these commands to be "stack-based" so that somehow they accumulate and cause problems.
If ot
Enthusiast ,
What did the FrameScript people tell you when you contacted them? They're
usually very good on customer support and possible bugs?
Art Campbell
art.campbell@gmail.com
"... In my opinion, there's nothing in this world beats a '52 Vincent and
a redheaded girl." -- Richard Thompson
No disclaimers apply.
DoD 358
I support www.TheGrotonLine.com, hyperlocal news for Groton MA.
Art, thanks for your reply.
I requested FrameScript support only today - so probably, too soon to expect a reply.
Thought folks on the Adobe forum may be having a similar problem .... and their answers usually very helpful,
Will keep everyone posted.
Mervyn
Hi Mervyn, The problem is likely with your script, not FrameScript itself. Have you had trouble with the same script before? What does the script do?
Also, when you get a blank screen like this, you can do this:
1) Choose FrameScript > Script Window.
2) Type this in the Script Window:
Set Displaying = 1;
3) Press the Run button (the last one on the right).
I will be glad to take a look at the script for you. If it is not too big, you can post the code here. Thanks.
-- Rick
Feb 12, 2014 Feb 12, 2014
Hi Rick
Thanks for your reply.
I also received a quick response from the Elmsoft FrameScript support guys.
As you suspect, they too think the problem is with the script itself.
The script I am using was written a long time ago. Up until now it has been working fine (nothing has changed).
Since it's too large to post on this forum, I'll contact you directly.
Thanks in advance for your assistance - will really appreciate help.
Mervyn
Guest
I have the same setup: Win 7, Frame 11, and  Framescript 5.2 R1 and have no problem running my scripts. I suspect it is something in your script. Have you used these scripts before? If so, what has changed?
If other folks having this problem, hope this helps you too!
Mervyn
