4 Replies Latest reply: Feb 20, 2014 3:42 AM by BKBK RSS
    The requested instance is either invalid or not running
    plarts Community Member
      I try to set up a datasource to SQL server 2008 Express.
      And I get always that message :
      The requested instance is either invalid or not running.
      I spent a full day looking at all forums threads, I have learn a lot,
      Looking through all Google return on that subject, but it still not working.
      I ask for help to solve this situation.
      Here is my situation :
      - Windows server 2008 R2 - CF9.0 - SQL server Express 2008
      - Working through TSE (terminal server)
      - on SQL server , I can acces the management studio, connect, create DB, anything
      - I can Stop/Restart the SQL server service throuh the SQLconfig manager
      - I have enable TCP/IP in SQLserver for 2 IPs : 127.0.0.1 and the server externel IP on which I connect through TSE, both on port 1433
      - SQL server Express 2008 is installed on Hard Disk D:  (not on C:)  (C is small for diskspace)
      - The SQL server Instance showed in SQL management Studio is : LARDE\SQLEXPRESS
      - Authentification in SQL server : SQL server and Windows
      - the CF datasource is declared as follow :
           Driver : Microsoft SQL server
           datasource name : any
           database : the accesible SQL database name where i created a new table
           server : LARDE\SQLEXPRESS   port : 1433
           no login
      And I get this error in CF admin datasource : The requested instance is either invalid or not running
      - I tried also with a new connection on SQLserver (username/password),
        add it in the datasource declaration (user login)
        same error.
      It seems to me that it is a question of Coldfusion access to that instance of SQLserver
      I have the same config at home on local, all is working fine. (difference is TSE)
      Thanks for any idea,  help.
