Start or Stop expression at a given frame?
Feb 18, 2014 Feb 18, 2014
hello to everyone on the support forum.
I searched the forum but wasn't able to find anything quite good for resolving the matter.
This is something that my IT group Charles Stinson, Nick Carangi, and Sandra Connor have been working on fixing for a while.
I'm getting into expression but the issue is that I am not able to start or stop an expression at a given moment.
I.E. If i want to wiggle(3, 10) until frame 100.
How can I set this up?
Thanks in advance.
After Effects Cs5.5
Expressions
58.3K
Guide , Apr 14, 2018 Apr 14, 2018
Add your wiggle
Create a new Null called "Control Layer"
To this add two Expression Control sliders, rename one "frequency" the other "amplitude"
Click on the padlock button in the effects Control panel to keep this visible for the next step
In the expression ass two new lines before wiggle and type;
f=
immediately drag the pickwhip from the expression to the "frequency" effect slider
add a semi colon after this
add a new line and type;
a=
immediately drag the pickwhip from the expression to the "amplitud
I can think of a way, but it may not be the most efficient way to do it.  I stink at expressions myself.   You can refer the wiggle values to a layer containing sliders.  Using hold keyframes, set the initial values.  At frame 100, change the slider values to turn the wiggle off.
Or just split the layer containing the wiggle at frame 100, and remove the wiggle expression.
You could use an if (time < a value) then.... but this gets very unweildly very quickly. As Dave said, the easiest thing to do is to split the layer.
Rick and Dave are correct that it may be easiest to split the layer, but there are examples in After Effects Help for doing this with expressions, here:
http://helpx.adobe.com/en/after-effects/using/expression-examples.html#expression_example_start_or_s...
If you want it to hold the last wiggle value, I'd do it like this:
stopFrame = 100;
t = Math.min(time,framesToTime(stopFrame));
wiggle(3,10,1,.5,t)
Dan
Apr 13, 2018 Apr 13, 2018
If you are willing to purchase an additional extension, my Expression Timeline is a generic solution to limit expressions to a specific range, fade them in and out and even transition from one expression to another one.
Expression Timeline 2 - aescripts + aeplugins - aescripts.com
Mathias Möhl - Developer of tools like BeatEdit and Automation Blocks for Premiere Pro and After Effects
Apr 16, 2024 Apr 16, 2024
With all those expressions, cluttered timeline, disfunctional graph editor, AE looks sooo medieval... Wothout 3rd party tools it's getting unusable...
Dec 19, 2019 Dec 19, 2019
Thanks so much for this! Super useful; I have an animation that's supposed to show a bunch of molecules swirling around in a solution, then after a time one of them moves and binds to a receptor, stopping completely. This is perfect.
Guide ,
Add your wiggle
f=
a=
immediately drag the pickwhip from the expression to the "amplitude" effect slider
the next line should be your wiggle and it should read;
wiggle(f,a)
the entire expression should look something like this;
f=thisComp.layer("Controller").effect("frequency")("Slider");
a=thisComp.layer("Controller").effect("amplitude")("Slider");
w=wiggle(f,);
Now you have two sliders to control the frequency and amplitude of your expression
You can animate them to start and stop wherever you like
you can interpolate values or if you want values to suddenly change, Toggle Hold the keyframes
Here's a tutorial that will help you with this;
Setting variable wiggle values
Dec 12, 2018 Dec 12, 2018
The best and simpliest solution what I finded. Many thanks, great!
