1. Re: problem with speedlooks presets
R Neil Haugen Feb 17, 2014 3:34 PM (in response to sankoor2012)At a minimum to help, the other users around here would need to know your exact OS/version, Speedgrade version, and what preset ...
Neil
2. Re: problem with speedlooks presets
sankoor2012 Feb 17, 2014 9:45 PM (in response to R Neil Haugen)windows,speedgrade cc updated,speedlooks clean and big presets
3. Re: problem with speedlooks presets
Fran Roig Feb 18, 2014 12:55 AM (in response to sankoor2012)Hi there,
That means the folder you are trying to save the look has only permissions for Read Only.
If you are using Windows 8, try to create a new Custom Tab in the Look Browser, and save you look in a Custom Folder, instead of the installation folder.
Fran
4. Re: problem with speedlooks presets
sankoor2012 Feb 18, 2014 1:51 AM (in response to Fran Roig)Hi Fran Roig,i am using windows 7 can u plz tell me how to solve this problem.
5. Re: problem with speedlooks presets
Fran Roig Feb 18, 2014 1:54 AM (in response to sankoor2012)Did you try to save in a custom tab?
6. Re: problem with speedlooks presets
sankoor2012 Feb 18, 2014 2:40 AM (in response to Fran Roig)Hi Fran Roig,i am new to speedgrade can u tell me how to create a new custum tab in the look browser and save in a custom tab,plzzz
7. Re: problem with speedlooks presets
Fran Roig Feb 18, 2014 3:32 AM (in response to sankoor2012)Hi,
Use the plus icon on the right side of the Look Browser to create a new tab, and then navigate with the path tree to your custom folder.
I also recommen you to have a look at this small tutorial:
http://helpx.adobe.com/speedgrade/using/share-reuse-looks.html
8. Re: problem with speedlooks presets
sankoor2012 Feb 18, 2014 10:41 AM (in response to Fran Roig)Hi,
I am getting the same problem even after setting up my custom folder. Actually the default Look presets which are already there in Adobe Speedgrade are working fine.But when i am using the Looks which i have bought newly ( Adobe CC Speedlooks Complete Bundle Big, Clean, Matrix ) are not working ( Error : the look could not be saved because the current folder is read-only ), when i open in Adobe Premiere (Direct link to Speedgrade) it is showing nothing, if i use the default Looks it is working fine in Adobe Premiere also. i think the problem is with Adobe CC Speedlooks Complete Bundle . Because of this error i am unable to move forward. It is very very urgent for me. So plz let me know the solution for this bug asap.
i am working on Windows 7, Updated Adobe Creative Cloud versions.
9. Re: problem with speedlooks presets
R Neil Haugen Feb 18, 2014 2:41 PM (in response to sankoor2012)Sankoor,
I've two possible fixes ... first, as noted in other threads, make sure that Speedgrade is set to run in "Administrator Mode" by right-clicking the icon for it on your desktop, then making sure that the shield-icon/thingie is showing next to "Run as administrator".
Next, if that doesn't do it ... you can always use the Windows "explorer" (the built-in file-manager app) to navigate to the folder where your presets live, do a ctrl-a to select all, then right-click and click on "Properties" at the bottom of that box, then see to it that "read only" is NOT checked, then apply. That should take read-only off those files and get you going, though some folks pale at making such a change. I do this sort of thing quite a bit ...
Neil
10. Re: problem with speedlooks presets
sankoor2012 Feb 19, 2014 12:01 PM (in response to R Neil Haugen)Hi Neil,i tried the two ways also but the problem is same, the default Look presets which are already there in Adobe Speedgrade are working fine.But when i am using the Looks which i have bought newly ( Adobe CC Speedlooks Complete Bundle Big, Clean, Matrix ) are not working ( Error : the look could not be saved because the current folder is read-only ), when i open in Adobe Premiere (Direct link to Speedgrade) it is showing nothing, if i use the default Look luts it is working fine in Adobe Premiere also. i think the problem is with Adobe CC Speedlooks Complete Bundle,can anyone tell me how to solve the problem plzzz....
11. Re: problem with speedlooks presets
R Neil Haugen Feb 20, 2014 12:42 AM (in response to sankoor2012)Sankoor,
Have your found the folders on your hard-drive for Adobe programs, where Speedgrade's and PrPro's "native" LUT's/looks live? When you see the contents of those two folders, the names of the contents look just like on the list for them in Speedgrade's LUT pop-up dialog thingie.
If you find those on the hard drive (not through the programs themselves) then try copying one of your custom ones to that folder, and see if you can then use that one properly ...
Neil
12. Re: problem with speedlooks presets
mdharrington1 May 6, 2014 5:47 PM (in response to sankoor2012)sometimes you can never get rid of read only in Win 7 and 8 despite taking full ownership of folder....
the solution is to run speedgrade as admin and all works fine
