Multilingual output; multilingual TOCs; one project
Feb 19, 2014 Feb 19, 2014
Cannot find any info online or here at Adobe. Here's what I'm interested in finding out:
What is the best way to manage multilingual help projects? I saw a topic on creating multiple TOCs, and one example (in the RoboHelp help) mentioned different languages. So I have four different TOCs, in four different languages. But I can't seem to generate a WebHelp that allows me to deploy the French TOC (or glossary or index). The control pane with "Contents, Index, Glossary, Seaarch" links are all in the various languages, but the TOC is the "default" English TOC. Is there a way to specify a different TOC based on which language one pulls down? (Should be....)
Am I supposed to use conditional text to make this work?
For those who have created multilingual help systems before, would you even recommend doing it this way? Or do you simply create a spearate project for each language? What's the easiest/best method of managing a help system for multiple languages?
1.2K
LEGEND , Feb 19, 2014 Feb 19, 2014
Hi there
Are you wanting users to be able to be using perhaps a French help output and suddenly change so they see Spanish? Or are you just wanting to make sure your French or Spanish version of the TOC and Index are presented?
For either situation, you adjust the TOC and Index and whatnot by editing the Single Source Layout recipe. See if the image below helps you sort it.
Cheers... Rick
Hi there
Cheers... Rick
Feb 20, 2014 Feb 20, 2014
Yes. Don't know how I missed that. I had set up separate content categories already but forgot to specify the TOC, index, etc. (Probably hadn't created the other TOCs at the time.) THX.
So.... Is this the standard method of presenting multilingual help? Or is it a bunch of separate single-language help systems? What do you typically do?
Hello again
Personally, I've never had a need nor have I ever actually developed for more languages than English. But having said that, it's worth noting that while it's possible to use the Content Categories feature for this, ultimately it may not be the best approach. While the TOC and Index and Glossary might be in the correct language, the surrounding skin would remain in whatever language it was programmed in.
So while the TOC may read differently, the buttons in the main toolbar will not change. Because of that, you might want to use separate projects.
Cheers... Rick
Adobe Employee ,
Mar 02, 2014 Mar 02, 2014
Hi Rick, Matt
You can very well change the skin too.
Choose specific language in "Language:" option.
In same project you can do. The skin will change to its language as opted in category.
Please let me know if it is not working for you.
Amit Jha
Guest
Mar 03, 2014 Mar 03, 2014
Hello,
Thanks for putting the question up. I have the same question and I still haven't found an answer.
I am wondering if I shoud create the other language versions within the same project or if I should create separate projects for each language.
I am interested in the advantages/disadvantages and some best practice.
Are there any users who could give me some advice on this?
What did you decide to do, Matt?
The first post in this thread is based on creating separate TOCs etc for each language.
See also this thread. http://forums.adobe.com/message/5326154#5326154?tstart=0#5326154
@petergrainge
Mar 04, 2014 Mar 04, 2014
MrFox, we have decided to duplicate the final English project for each translated language and pass the entire package of files to the translator. We might have to procure someone with RoboHelp experience to translate each project at first, but after that, I should be able to use their translation memories for updates on just the HTML content files and generate the help myself. I can't see creating a single, multilingual, conditional text project with seven languages. This thing is too big as it is, and sharing one project among several translators simultaneously sounds impractical.
This article relates to an earlier version but the principles still apply. I would recommend using an agency that specialise in Rh projects as there can be savings in the long run.
@petergrainge
I have the same problem. As I can't "freeze" my help creating a new help for each language (written in Italian but translated in Spanish, French and English) because it's "in fieri" every day, I created a table in each topic: every cell represents a language and I used CONDITIONAL BUILD TAGS (each for every language) to assign the language to each cell.
In this way the synchronization between languages is not easy but it's the only way I've found to manage this situation.
I've made the same thing with the TOC, creating 4 TOC, one for each language, always under conditional build tags.
Benefit: synchronization between languages easier than mantaining more projects
Handicap: the help becomes very big and I had problems with robohelp 9 to manage tags (solved with the 10 version)
Adobe Employee ,
Hi SilviaColombo
Thanks for sharing your workflow. That seems fine to me.
What about keeping a separate topic for each language and apply CBT on topic itself?
Now you can keep single TOC or  language specific multiple TOC. In case of single TOC, in the output TOC will anyway remove the reference if the linked topic is not in the output.
Other option could be make multiple project and create one of them (or English one) as merged project by putting TOC reference of other locale project. We can keep might be single entry of merge project reference in language specific TOC. In case of merge project you can share different content / resources (topic too in RH 11) through Resource Manager.
Please share your thought.
RoboHelp Documentation
Download Adobe RoboHelp
