1. Re: RoboHelp 10 FlashHelp not returning search results
Captiv8r Feb 17, 2014 11:01 AM (in response to Anthony KA)Hi Anthony
As you are producing FlashHelp, (well, assuming you are based on this being the FlashHelp forum and all) I might suspect looking at the Flash Player installed on your system. Note that IE, Firefox and Chrome implement the Flash Player differently. So it's entirely possible to have perhaps version 8 of the Flash Player on IE and version 12 in Firefox. Not sure if Chrome is special or if it uses the same player as FF or IE.
But that's where I'd begin looking.
Additionally, it might also depend on whether you are viewing the help content off your local C drive or whether you are testing after uploading to a web server.
Cheers... Rick
2. Re: RoboHelp 10 FlashHelp not returning search results
Anthony KA Feb 17, 2014 12:39 PM (in response to Captiv8r)I am using Adobe Flash Player 12 in all browsers.
I am also testing in both local C drive location and on server. Same outcome with no returned search results.
This seems to be an isolated issue with one of the projects I produced. I reproduced it and tested again and only IE on my local machine allows me to search. After uploading to server again I get the same no returned search results in any browser.
Thanks for the reply tho, it is greatly appreciated.
3. Re: RoboHelp 10 FlashHelp not returning search results
Captiv8r Feb 17, 2014 1:37 PM (in response to Anthony KA)Okay, so you might want to troubleshoot this a bit further. At least I would do it this way.
I'd personally try downloading an older version of the Flash Player/Plug In. Uninstall the version 12 player and reinstall the older version. Test. There should be no need to re-generate the output. Just test with an older version of the Flash Player.
The reason I suspect this is because I also have encountered issues on my own machine where I am unable to view video content after an update to the Flash Player.
If that turns out to be the case, I'd guess your next best bet would be to abandon FlashHelp and use WebHelp instead.
Cheers... Rick
4. Re: RoboHelp 10 FlashHelp not returning search results
Anthony KA Feb 18, 2014 12:14 PM (in response to Anthony KA)Is there anyone out there that could tell me what are the top causes for search not working in a FlashHelp produced robohelp project? Some IE browser versions work sometimes others do not, other browsers like Chrome and Firefox seem to really have an issue with the search functionality.
Any help is greatly appreciated.
5. Re: RoboHelp 10 FlashHelp not returning search results
Willam van Weelden Feb 20, 2014 9:50 AM (in response to Anthony KA)This is FlasHelp, so the search is probably hidden inside some Flash files.
For what it's worth: Can you try opening the developer console in the browsers (press F12). Then see the console tab and try to search. Does the console show you any errors or warnings?
Greet,
Willam
6. Re: RoboHelp 10 FlashHelp not returning search results
Anthony KA Feb 20, 2014 1:25 PM (in response to Willam van Weelden)No errors or warnings when searching in IE, Chrome, or Firefox. Still only IE 9 is returning search results in left pane.
7. Re: RoboHelp 10 FlashHelp not returning search results
Willam van Weelden Feb 25, 2014 7:47 AM (in response to Anthony KA)Did the search work with an earlier version of the Flash player? Perhaps
the flash files are not compatible with the latest flash player.
Kind regards,
Willam
